I should make sure not to leave my helmet on the short bus.. #242656
01/19/12 03:08 PM
01/19/12 03:08 PM
Karl_Brogger Offline OP
I learned something new at Tradewinds, or at least while I was sailing around a few days before.
I have trouble consistently righting the boat singlehanded with just a line. So after drifting for 15 minutes, and about to give up and call the coach boat over I gave it another shot. Wrapped the line around my hook, leaned out, and threw one ARM over my head, and it came up. I could get the mast out of water before, but not past horizontal.
eYe feall dumbie.....
Re: I should make sure not to leave my helmet on the short bus.. [Re: Karl_Brogger] #242660
01/19/12 03:51 PM
01/19/12 03:51 PM
pgp Offline
pgp  Offline
Um, that's gotta be orientation to the wind. Sometimes the boat will swing under me almost 45 degrees before it comes up, then it almost rights itself.
btw- did you notice the round the horn guy was on the down hull and just rode it up, kept the boat from going all the way over.
Pete Pollard
Blade 702
Re: I should make sure not to leave my helmet on the short bus.. [Re: Karl_Brogger] #242662
01/19/12 04:08 PM
01/19/12 04:08 PM
Yeah, but Pete. You out weigh me like 2:1 laugh
Re: I should make sure not to leave my helmet on the short bus.. [Re: Karl_Brogger] #242665
01/19/12 04:33 PM
01/19/12 04:33 PM
pgp Offline
pgp  Offline
That was my point! Even with my weight the boat has to swing round to the correct orientation or it will just sit there.
If the air is light enough I might have to walk forward or backward on the hull to get it to pivot.
It's hard for me to believe the weight of one arm was sufficient to make the difference for you to right solo. Some of the lighter guys carry empty trash bags to scoop up enough water to right the boat.
Pete Pollard
Blade 702
Re: I should make sure not to leave my helmet on the short bus.. [Re: Karl_Brogger] #242699
01/20/12 10:25 AM
01/20/12 10:25 AM
I was oriented well, just couldnt get her to go. Threw my arm up and when it started to come up, all I could think was "you gotta be shittin' me"
Re: I should make sure not to leave my helmet on the short bus.. [Re: Karl_Brogger] #242701
01/20/12 10:47 AM
01/20/12 10:47 AM
It might have also been a good gust of wind getting under the mast, or a good wave, helping to right it. I righted my Inter 20 by myself several times, but it was really the wind getting under the mast that flipped it up...and sometimes right over the other way!
Re: I should make sure not to leave my helmet on the short bus.. [Re: Timbo] #242713
01/20/12 11:09 AM
01/20/12 11:09 AM
Daytona Beach Florida
O
orphan Offline
orphan  Offline
O
When right on the edge it does not take much to tip the scales.
Re: I should make sure not to leave my helmet on the short bus.. [Re: Karl_Brogger] #242732
01/20/12 01:34 PM
01/20/12 01:34 PM
and I had to be right on the edge. I capsized again, later that day and same results. Arm over the head, and up she came.
The good news is this saves me a bunch of money, I was thinking about putting a carbon mast on to make righting a squeak easier.
Re: I should make sure not to leave my helmet on the short bus.. [Re: Karl_Brogger] #242738
01/20/12 02:59 PM
01/20/12 02:59 PM
M
MarkMT
MarkMT
M
Were you using the under-tramp line or over the hull? (just curious - I realize it makes no difference to the righting moment.)
Re: I should make sure not to leave my helmet on the short bus.. [Re: Karl_Brogger] #242739
01/20/12 03:21 PM
01/20/12 03:21 PM
Or...maybe you've got really, really, fat arms!
Re: I should make sure not to leave my helmet on the short bus.. [Re: Karl_Brogger] #242753
01/20/12 06:30 PM
01/20/12 06:30 PM
Was it your left arm or right arm?
Re: I should make sure not to leave my helmet on the short bus.. [Re: Karl_Brogger] #242766
01/21/12 04:05 AM
01/21/12 04:05 AM
Perhaps you have a particularly heavy watch???
0 registered members (), 1,118 guests, and 41 spiders.
