I finally had a few hours to myself in a very long time and decided to pick up my old hobbie.
With the various reports and pictures I was able to compile this listing that connects teams with makes but I'm still missing a few combo's. Can anyone help me out with the last few white spaces ?
The names in red are first 3 youth teams
Re: Linking up teams with boat makes
[Re: Wouter]
#243543 02/04/1207:10 PM02/04/1207:10 PM
Couple of data points... I can confirm Reiss and Chu on the Viper - photo here . And from this video it looks like Bello and Brown were on a Falcon, not a Viper.
Lots more photos here and here that you can probably mine for further details.
[Re: Wouter]
#243547 02/04/1207:24 PM02/04/1207:24 PM
I also looked over the second series of pics and this is what I have so far. The purple and blank still need to be confirmed.
Looks like a fine mix of boats, indeed !
I'll allow myself one non-impartial remark. 6 non-Vipers in the top 10 with with 2 Falcons in top 3. Seems that the fleet is balancing out a bit after the last 18 months of Vipers dominating the top places. I'm sure that is also to some degree due to Falcon marine setting up their coaching program (as Vipers did a while back). Well done Matt and John !
[Re: Wouter]
#243570 02/05/1209:44 AM02/05/1209:44 AM
Wouter, Seth and Tina were indeed on a Falcon, that's one of your purple people on the list.
And JC on day two was 2, 2, 1, 2 on day two. His crew was the one who got a dog bone in the eye on day 1 so they came in early and missed most of day 1 racing. The guys at the bottom with all the DNS's were no-shows at the regatta.
Blade F16 #777
[Re: Wouter]
#243592 02/06/1207:09 AM02/06/1207:09 AM
Its a Vectorworks Blade F16 I have know for a while the boat was slow, but at Tradewinds got real dose of reality. I was fighting weather helm pulling the stick with my clenched hand to keep it going straight. I called Matt and discovered my rudder rake was over two inches off. I fixed the rudder rake for latest CABB race and was first to finish, but corrected 4th, the fleet was according apart and then together at the finish. Anyway still a bit to much helm and will correct it a bit more.
[Re: sail7seas]
#243612 02/06/1211:52 AM02/06/1211:52 AM
Raked forward (Rake Port+35mm.jpg ) +35mm in front of line from transom, but I will be going a bit more forward, for a bit less tug, now using a clenched two fingers.
[Re: Wouter]
#243619 02/06/1201:52 PM02/06/1201:52 PM
Awhile back there was some talk about bedding the rudder blade into the rudder housing, have you done that?
No. I am thinking about re-routing pull-down line to exit the housing instead of around the through-bolt, (remove through-bolt) in-order to more move the entire rudder forward 1/2" in the housing to lessen the amount needed to tip forward the rudder.
[Re: Wouter]
#243675 02/07/1203:29 PM02/07/1203:29 PM
Before you starting playing with rudder rake, definately check cunningham while sailing. On the F16 you easily have not enough cunningham when the wind picks up. Then the boat becomes a bit heavier on the rudder. Really easy to know if you're trim is more or less in the ballpark.
