| Broken battlestick #246047 03/24/12 06:48 PM 03/24/12 06:48 PM | Mac m OP
| Mac m OP
Unregistered | I broke the Carbon Battlestick on my Viper this afternoon. Best way to repair? ![[Linked Image]](http://i1178.photobucket.com/albums/x377/Lakewateree/30729ce7.jpg) | | | Re: Broken battlestick
[Re: ]
#246050 03/24/12 07:59 PM 03/24/12 07:59 PM |
Posts: 5,525 | I've given up on sticks, consider them expendable, and plan to replace about once a year.
Pete Pollard Blade 702
[Re: ]
#246056 03/24/12 08:39 PM 03/24/12 08:39 PM | Mac m OP
| Mac m OP
Unregistered | I've still got a hot stick in my spare stuff, guess I could convert over to it. I did like to quick connect thing on the Ronstan stick though. | | | Re: Broken battlestick
[Re: ]
#246069 03/25/12 10:06 AM 03/25/12 10:06 AM |
Posts: 3,293 Long Beach, California | Totally repairable, and will be cosmetically very subtle. Call Dennis Key of Barefoot Boats - he has experience with this.
[Re: ]
#246072 03/25/12 11:12 AM 03/25/12 11:12 AM | Mac m OP
| Mac m OP
Unregistered | Thanks all. I think I'm going to fix it using fiberglass as carbon fiber isn't readily available here and I need it fixed by next weekend, going to Spring Fever and the camp before hand. My only concern is getting it to set up straight.
What are the advantages of the long, fixed length Sticks as compared to the fiberglass adjustable ones, weight aside? I'm new to the Fixed length, it seemed to be in the way all the time when not trapped out.... | | | Re: Broken battlestick
[Re: ]
#246173 03/26/12 03:45 PM 03/26/12 03:45 PM |
Posts: 6,049 Sebring, Florida. | I've been thinking of going to Home Depot and getting a long piece of that white plastic (PVC) lawn sprinkler type pipe, about 1" OD, 8 feet long, and just drill a hole in one end, to pin it to my cross bar.
Light, flexible, and about 1/30th the cost of a $300 carbon fiber battle stick.
On all my previous cats I had a slide-adjustable stick, but on my Blade it's a fixed length. At first I thought it was a PITA when tacking and gybing, but now I'm used to it and I actually prefer it.
I never have to worry about it slipping in or out when I'm doing my thing.
Blade F16 #777
[Re: Timbo]
#246184 03/26/12 04:23 PM 03/26/12 04:23 PM |
Yep, I got a fixed length glass fibre tiller as well and I will never go back to telescopic setups.
You get used to it pretty quickly and now I prefer it.
Basically what you learn is to lay the tiller on your aft schoulder and steer with your thumb towards your face instead of pointing towards the crossbar.
This lifts the tip of the fixed length tiller sufficiently to clear marks and boats nearby.
Only when your crew is trapezing behind you or aft you is it in the way but this typically only happens under spinnaker and then I trail my tiller extension behind the boat.
[Re: ]
#246185 03/26/12 04:25 PM 03/26/12 04:25 PM |
For regards to the broken Tiller
I would just insert a piece of PVC or aly tubing and laminate the tiller back together after it has been slid out to its maximum length.
Make it into a fixed length tiller.
[Re: ]
#246257 03/27/12 12:23 PM 03/27/12 12:23 PM |
Posts: 4,119 Northfield Mn | Paint roller handles piss me off while painting. If I tried using one as a tiller extension I'm about sure that would end in bloodshed.
[Re: ]
#246258 03/27/12 12:33 PM 03/27/12 12:33 PM | Mac m OP
| Mac m OP
Unregistered | Plus using a paint roller as a tiller extension on this new of a boat just seems wrong | | | Re: Broken battlestick
[Re: ]
#246259 03/27/12 12:40 PM 03/27/12 12:40 PM |
Posts: 4,119 Northfield Mn | I use a Marstrom adjustable tiller extension and really like it.
NACRA has a similar unit that seems pretty nice, and I've heard good things about the Hobie Cat Europe adjustable ones too.
Two things I really like about the Marstrom one, its light, and its easy to replace just half of it. I don't like the price, I think list is $400. I'm not sure if the NACRA or Hobie ones you can replace just half. The NACRA one does come apart, so maybe?
I can't stand sailing with a fixed tiller. I singlehand a lot which means sitting forward of the beam when its light. I just can't stand swinging that big stick around the shrouds all the time.
Prepare for swinging stick jokes..........
[Re: ]
#246261 03/27/12 12:55 PM 03/27/12 12:55 PM |
Posts: 16 Satellite Beach, FL | Karl, where did you get the Marstrom stick? I've been looking for a picture of it with no luck. I too would like an adjustable carbon stick but with a Ronstan quick connector so that I don't have to modify my tiller crossbar.
George P. Harrison Falcon F16 - USA 236
[Re: ]
#246263 03/27/12 01:10 PM 03/27/12 01:10 PM |
Posts: 4,119 Northfield Mn | Red Gear Racing. Or, I can sell you one.
447
guests, and 169
