| Re: I think I've asked this before.
[Re: carlbohannon]
#246636 04/02/12 10:18 AM 04/02/12 10:18 AM |
Posts: 12,310 South Carolina | Wood CNC's..
If you are going to go to the trouble, why not machine a foil out of a block of laminated wood/composite. I don't remember anyone trying that.
Build your block out of wood or foam laminated with fiberglass, carbon, Kevlar, foam, aluminum... You could leave appropriate volumes hollow and except for your reference points, the finish could be sloppy.
Machine out the foil then machine out the skin(wood, carbon prepreg...) and glue them together
Or use a reinforced paper for the skin. Print it out on a large printer with little cutouts to make it lay flat. You could print whatever graphics you like. You could have a foil with your face on
I don't think this has been tried with a foil. I have heard of similar methods used for architectural pieces or high price furniture. You could be the first and lead the way if it shows promise. Phil's foils...he's been machining wood core foils for some time. I think he's since merged operations with CCI. http://fastcomposites.ca/publications/TankTalkPhilsFoils.pdfhttp://www.fastcomposites.ca/site/marine/design-tips-fabrication-overview/care-of-wood-cored-foil/
Jake Kohl | | | Re: I think I've asked this before.
[Re: catandahalf]
#246651 04/02/12 03:49 PM 04/02/12 03:49 PM |
Posts: 12,310 South Carolina | Hey Jake > I was just gonna say Phil's Foils or maybe mention Jim Bauman, from Recreational Composites. JB has done a few cat and tri foils as you know. He is about finished with restoring the C 24 and is willing to work for food Bauman is great - I had him clean up a pair of Nacra 20 foils for me once and he became standard to clean up our foils from then on. There's nothing worse than 500 miles on a boat that speed warbles a song through the water all day and night. A little touch up from Jim and they are silent!
#246658 04/02/12 09:27 PM 04/02/12 09:27 PM |
Joined: Jul 2005 Posts: 267 Ocean Springs, MS Capt_Cardiac
Posts: 267 Ocean Springs, MS | Jim's retired from epoxy work. Too much exposure. Sad to see a master retire.
Capt Cardiac Ocean Springs Yacht Club Sailor Nacra20 - Flight of Ideas #5 | | | Re: I think I've asked this before.
[Re: Karl_Brogger]
#246674 04/03/12 10:10 AM 04/03/12 10:10 AM |
Posts: 932 Solomon's Island, MD | For straight foils, you can get by with CNC cut foam cores (high density foam) and laminating carbon over them (lots of carbon). If people are interesting, I can cut 100 PSI foam on my CNC for reasonable prices.
The issue is when you go longer or curved; in these cases you need a CNC router machined core and a PVC based foam or wood core. Finding someone that will machine cores or molds for reasonable prices is not a trivial task, I have a few sources and may evaluate designing and building some curved A-Cat foils if the business case is justifiable.
As far as aluminum is concerned, built properly you can approach composites in weight and strength, but time wise it would take longer than the methods proposed above (unless you are THE metal guy). The corrosion issues posted above have never really been solved, take a look at any aluminum vessels (boats or seaplanes come to mind) after 10 years. Foils would not hold up very well to this abuse!
Scorpion F18
#246677 04/03/12 01:03 PM 04/03/12 01:03 PM |
Posts: 5,590 Naples, FL | Bauman is great - I had him clean up a pair of Nacra 20 foils for me once and he became standard to clean up our foils from then on. There's nothing worse than 500 miles on a boat that speed warbles a song through the water all day and night. A little touch up from Jim and they are silent!
I believe you could have used him on your 18 at Tradewinds. According to the Vid, those things were pretty dang loud!
[Re: Karl_Brogger]
#246693 04/04/12 07:41 AM 04/04/12 07:41 AM |
Posts: 571 Hamburg | Would a billet aluminium blades and boards work? Would they be stronger? Would they be lighter?
I'm gonna go out on a limb and say they'd be definitely cheaper. Once you've got the file, load up a blank in a 4 axis cnc mill and basically walk away. Plus polished boards would be frickin' cool. Or even anodized. Might want to make the top removable, a bent board could be trouble if you couldn't pull it out the top...... There are many alloys available, some are very strong, some not some have excellent corrosion behaviour, some not, and so on. But fact is that the right alloy is resistent to salt water and strong (as proven by thounds of masts). It has similar strength to hand layed up glasfibre, but less than carbon. Best production process would be extruding (if you can live with a straight board), not machining. Topcats use extrude alu rudders since ever. They have decent quality and are unkaputtbar (undestructable). At all the whole rudder system is a nice one on the Topcats. Not cheaper than some glass boards though. http://www.topcat.de/shop/index_e.htm . The rest of the boat is fairly outdated... Alu rudders wouldn't be particular heavy, about the same or a bit more than glass fibre boards of the same strength and size and maintenance free by the way. Cheers, Klaus | | |
1 registered members (soulofasailor),
1,976
guests, and 26
