Re: Redecking mosquito [Re: Schnoogie84] #253744
10/21/12 07:04 PM
10/21/12 07:04 PM
Schnoogie84 Offline OP
Cheers Chris,
I can see my reflection in that water!
Re: Redecking mosquito [Re: Schnoogie84] #253746
10/21/12 11:29 PM
10/21/12 11:29 PM
On another note,
I went to purchase some SS bolts and the supplier only had 304 stainless steel bolts in stock. Are these OK to use for the beam and dolphin striker mounts, or should I try and find these in 316 stainless?
Re: Redecking mosquito [Re: Schnoogie84] #253747
10/21/12 11:55 PM
10/21/12 11:55 PM
Scarecrow
Scarecrow
From a structural point of view the advantage of 316 over 304 is so marginal that it doesn't matter. From a corrosions point of view 316 is significantly better so using 304 will get you on the water but 316 will mean you probably don't need to look at the bolts again while you own the boat.
0 registered members (), 205 guests, and 38 spiders.
