by Karl_Brogger. 12/29/24 05:14 PM
It was a good night to race a catamaran #247491
04/26/12 08:35 AM
04/26/12 08:35 AM
Houston
carlbohannon Offline OP
Houston
After a month of light air on the Wed Night Races on Clear lake, we finally got a little wind. (Racing monohull dinghies in 5 kts sucks) Last night started with 8-20 and settled in to 12-16.
It was fun. Start high with speed and roll the fleet. Get caught by some friends in a V15 in the lighter air at the offset gate and then feed them dirty air and pass them on the downwind. After that just keep increasing your lead, trying not to do anything stupid, avoiding getting tangled wit the . Finish it off by passing the leader in fleet that started 3 minutes ahead, 200 yds from the finish line.
It could have better if there were 3 more Waves behind me
Re: It was a good night to race a catamaran [Re: carlbohannon] #250889
07/17/12 01:40 PM
07/17/12 01:40 PM
M
mrooke Offline
mrooke  Offline
M
Carl,
We have been sailing our Hobie Wave on Lake Buchanan (NW of Austin) and Texas City dike for over a year now. Last weekend we had a blast in up to 23 mph winds with the std jib on a 7 1/2 pole (like you suggested). Interestingly, the pole makes the Wave about as long as a Hobie 16 overall, but after this wild weekend we are ready for a larger head sail.
I have never raced before. My older son now lives in Pearland, so if you are planning on racing this Wed night(July 18), we will drive over to Clear Lake to watch and learn. Where do you launch on Clear Lake?
-Mark Rooke
Round Rock, Texas
Re: It was a good night to race a catamaran [Re: mrooke] #250905
07/17/12 05:29 PM
07/17/12 05:29 PM
Alachua, FL
Mugrace72 Offline
Mugrace72  Offline
Alachua, FL
Originally Posted by mrooke
Carl,
-Mark Rooke
Round Rock, Texas
You mean something like this?
Jack Woehrle
HCA-NA 5022-1
USSailing 654799E
Alachua FL/Put-In-Bay
Re: It was a good night to race a catamaran [Re: Mugrace72] #250908
07/17/12 09:24 PM
07/17/12 09:24 PM
X
xanderwess
xanderwess
X
What the hell is that? Bat-mo-wave?
Re: It was a good night to race a catamaran [Re: Mugrace72] #250910
07/18/12 01:28 AM
07/18/12 01:28 AM
M
mrooke Offline
mrooke  Offline
M
Jack,
Perhaps... and since you asked, I do have some questions about your beautiful sail smile
1. What material is it made of and how large is it?
2. Since it does not overlap the mast, can you easily sail solo from the stern (e.g., like with a large jib you don't have to roll up to tack)?
3. Does it need to be all out or all rolled up, or does a partially rolled Hooter act like a smaller jib?
4. Under what conditions do you find you need to roll it up?
5. How well does it perform upwind and on a reach/downwind versus the std Wave and/or a Hobie 16?
Thanks in advance,
-Mark
Re: It was a good night to race a catamaran [Re: mrooke] #250913
07/18/12 06:22 AM
07/18/12 06:22 AM
Alachua, FL
Mugrace72 Offline
Mugrace72  Offline
Alachua, FL
Jack,
3/4 oz spinnaker cloth
Made by Joe Waters at Waters Sails, Columbia, SC. Joe will make it any way you want it and it is scaleable. My pole is 10' which is a little radical. 7.5' seems to be what others are using. I am working with Joe on a semi-standard design for that pole length.
You might want to call him at (803) 957-5638 if you have any questions about the sail itself.
We designed it to sheet to a rachet block on the shroud chainplate. That way you do not need to cut a hole in the boat. Everything controls from your normal position. It does not need to be furled to gybe. Since I don't use it upwind, I haven't tried tacking. I'm going out today and will try that.
I have not experimented with it partly rolled up. That is a possibility. See above. I'll try that and report.
It was not designed as an upwind sail, but surprisingly, it can sail pretty close to the wind. I suspect that it would not be faster upwind that a well sailed conventional Wave.
I have only used this rig on a 38 mile distance race (Mug Race, Jacksonville Florida) and it was all down wind in light air. It was very fast...faster when there was more wind.
I will be doing more testing this week.
Jack Woehrle
HCA-NA 5022-1
USSailing 654799E
Re: It was a good night to race a catamaran [Re: Mugrace72] #250914
07/18/12 06:52 AM
07/18/12 06:52 AM
RickWhite Offline
RickWhite  Offline
Take a look at this story and all the links in it. That will explain a lot. This was the Hooter system I developed for the Wave about 10 years ago. The concept was to make the Wave a two-person trainer boat for youth. Still has possibilities.
http://www.catsailor.com/waves/superwave_overall.html
I sell the Calvert Hooter and the entire system on our store. Here is the link:
http://www.catsailor.com/store/pc/viewPrd.asp?idproduct=9335&idcategory=0
http://www.catsailor.com/store/pc/viewPrd.asp?idproduct=8049&idcategory=0
About four years ago I had the sails built for the Super Hooter, which had a roller furling, self tacking jib, and a roller furling Hooter on a 9 foot pole.
I was passing a well-sailed Hobie 20 when it imploded. Since then I have beefed up the bow sprit.
What Jack has done is make an even longer bow sprit, however I am pretty sure 9' is plenty.
Hope to have the Super Hooter in the Sandusky Steeplechase coming up in a couple of weeks.
Rick
Rick White
www.onlinemarinestore.com
Re: It was a good night to race a catamaran [Re: mrooke] #250925
07/18/12 06:31 PM
07/18/12 06:31 PM
Alachua, FL
Mugrace72 Offline
Mugrace72  Offline
Alachua, FL
Jack,
Thanks in advance,
-Mark
OK, I just got in from sailing in about 10 knots.
Pointing and hooters should not be in the same discussion. A Wave is faster upwind (VMG) with its mainsail only. Neither a jib nor a hooter will give you enough extra speed to make up for the lower pointing ability.
However, I found it was very easy to tack from reach to reach if that is what you want to do . Gybing was even easier.
A hooter has value when close to broad reaching. It does not do well DDW or pointing.
I also think that it is not a tactical sail so much as a strategic device and is lots of fun just sailing around and showing off.
It is more suited to distance races where you can stay on a reach for long stretches.
Around the buoys I think a well sailed conventional Wave could be just as fast.
Jack Woehrle
HCA-NA 5022-1
USSailing 654799E
Re: It was a good night to race a catamaran [Re: Mugrace72] #250929
07/19/12 06:24 AM
07/19/12 06:24 AM
RickWhite Offline
RickWhite  Offline
Jack, with my original Hooter I could point as high and go almost as fast as a hobie 16 going upwind.
With the longer pole and bigger spin you may not be able to.
Rick
Rick White
Re: It was a good night to race a catamaran [Re: RickWhite] #250930
07/19/12 07:28 AM
07/19/12 07:28 AM
Alachua, FL
Mugrace72 Offline
Mugrace72  Offline
Alachua, FL
Rick
Right...we didn't want a sail that flat. It could be made flatter, but it depends on what you want to do with it. Actually, I can flatten it a lot with more halyard tension.
Last night I did't have it set that way. I will play around with it and see exactly what it is capable of.
Jack Woehrle
HCA-NA 5022-1
USSailing 654799E
Re: It was a good night to race a catamaran [Re: Mugrace72] #250943
07/19/12 10:48 PM
07/19/12 10:48 PM
M
mrooke Offline
mrooke  Offline
M
At the Clear Lake Wed Night races yesterday I was reminded of how beautiful spinnakers can be flying in the wind.
It would be great to see some photos or even videos of Waves with these Hooters actually in action smile
Re: Latest spinnaker report [Re: Mugrace72] #250961
07/20/12 01:53 PM
07/20/12 01:53 PM
Alachua, FL
Mugrace72 Offline
Mugrace72  Offline
Alachua, FL
We had our local fleet races last night around the standard Wave triangle with a windward leeward course.
I tried to stay out of the way of the rest of the boats, not passing to windward or contesting mark roundings.
Wind was 6-12 and shifty.
Upwind the boat clearly makes better VMG with the sail furled. The added windage makes it slightly slower than a "clean" Wave.
On reaches it is clearly faster, the windier it gets, the more the speed advantage.
Dead down wind you cannot make enough VMG to catch a Wave running free.
Any advantage I gained on the reaches was lost at mark roundings because there is so much extra to do.
In my opinion, these sails are great for showing off and reaching back and forth with a lot of excitement. On a distance race with mostly reaching, it will outsail its handicap.
Rick claims his "hooter" will sail as fast and point as high (which isn't very high BTW) as a Hobie 16.
I don't believe it, but we will do some one on one testing, perhaps next week.
Jack Woehrle
HCA-NA 5022-1
USSailing 654799E
Re: Latest spinnaker report [Re: Mugrace72] #251081
07/29/12 08:44 AM
07/29/12 08:44 AM
Alachua, FL
Mugrace72 Offline
Mugrace72  Offline
Alachua, FL
Rick and I at Put-In-Bay yesterday ready to go "mono on mono".
However, Rick is still in the developing stages of his new rig and had trouble getting enough luff tension on the hooter.
He needs to lower the pole and I think it will be fine.
Mine has a shorter luff so I can get it pretty tight. That is needed to get it to furl properly.
Someone asked if you can sail with it partly unfurled and the answer is NO...absolutely not. It is either all in or all out. That is because the top tends to roll out more material than the bottom which is restrained but the furler drum. Trust me, it doesn't work well partly unfurled.
After Rick came back in to reconsider his design, I went out in 8-12 knots and sailed for several hours.
It is really amazing the speed that develops on a beam to broad reach. The boat literally leaps out of the water and skips over the waves. Note that this is in the famous Lake Erie chop.
There is no hope to gain an advantage upwind compared to a uni-rig Wave, opinion.
Jack Woehrle
HCA-NA 5022-1
USSailing 654799E
Re: Latest spinnaker report [Re: Mugrace72] #251100
07/30/12 07:49 AM
07/30/12 07:49 AM
Alachua, FL
Mugrace72 Offline
Mugrace72  Offline
Alachua, FL
I picked this up off the Hobie Forum.
Trinomite wrote:
Based on the simple idea of economic return for your investments, would it not make more sense to buy a Hobie Wild Cat and consider other means of 'flying' as simple as looking at a pilot's license and leave the 'toy boats' on the beginner's circle?
Regards
Tri
Both Rick and I have been sailing high performance cats for 40 years...Sharks, Tornados, Hobies, Nacras, etc.
We are not interested in faster and more complex boats anymore.
We are Wave sailors and we race them..several times a week, in fact.
How many folks that read this forum really race Waves in one-design fleets?
However, we also like to play around a little, that's all.
WE DO NOT CONSIDER THE WAVE AS A "TOY BOAT"!!!
_________________
Jack Woehrle
Wave #100
H20 #287 "Tallahassee Lassie" (down in FLA)
Jack Woehrle
HCA-NA 5022-1
USSailing 654799E
Re: Latest spinnaker report [Re: carlbohannon] #251357
08/13/12 09:41 PM
08/13/12 09:41 PM
Louisiana, Pcola Fl.
Mark Milam Offline
Mark Milam  Offline
Thanks Jack,
Very interesting summation.....I bet it is Fun to Play with on reaches....How did you do on the Mug Race with it on handicap???
I havent' done much sailing, other than the Wed. night wave racing....We had some bad luck...We went Paddleboarding on Lake Austin, and my wife Tammy decided to Swing off a rope swing, but forgot to lift her legs and Hit the lower set of Rocks, Breaking her leg...she could feel the lake water going in her leg...she also broke her wrist and had to have a 8 hour surgery on it to rebuild it.....so we are sort of shut down for 8 weeks at least....Full titanium rod from Knee to ankle.....She ain't a happy camper.
Mark Milam
Lafayette, La.
Wave # 113
Re: Latest spinnaker report [Re: carlbohannon] #251464
08/17/12 11:16 AM
08/17/12 11:16 AM
Albenarle NC
jackbr549 Offline
jackbr549  Offline
Albenarle NC
Any news from the Put in Bay races ?
Re: Latest spinnaker report [Re: jackbr549] #251467
08/17/12 11:38 AM
08/17/12 11:38 AM
RickWhite Offline
RickWhite  Offline
Got stormed out the last day, but still got in 9 races. Doug Seib and I tied for first, broke in his favor. Jim Glanden was 3rd, followed by John Sherry, Ray Matuszak, Jack Woehrle, Betty Bliss, Mark Scarpelli, Steve Abbey, Michelle Marman, Mike Powers, Peter Murray, Dick Bliss and Matt Wirth
Parties were awesome as usual.
Rick White
Re: Latest spinnaker report [Re: carlbohannon] #251480
08/17/12 04:56 PM
08/17/12 04:56 PM
Albenarle NC
jackbr549 Offline
jackbr549  Offline
Albenarle NC
Thanks!
Re: Latest spinnaker report [Re: Mugrace72] #251502
08/19/12 08:02 PM
08/19/12 08:02 PM
“an island in the Pacifi...
hobie1616 Offline
hobie1616  Offline
Any updates on Rick vs. Jack? I'm close to pulling the trigger on a Wave and need info.
TIA
US Sail Level 2 Instructor
US Sail Level 3 Coach
Re: Latest spinnaker report [Re: hobie1616] #251504
08/20/12 06:15 AM
08/20/12 06:15 AM
RickWhite Offline
RickWhite  Offline
Neither ofus working on it. However, my original Hooter System worked far better than either Jack's or my Super Hooter. Took 2nd overall in Conch Cup with around 55 boats and passed most of the H16 fleet.
Won the Around the Bay Race (60 boats) by 15 minutes on corrected time.
With the Super Hooter a few years ago I was passing a H20 when it exploded.., or imploded -- bow sprit was not beefy enough for all that load.
Rick White
0 registered members (), 309 guests, and 86 spiders.
Posts267,059
