| Re: Uni vs 2-up.. Who have the racing advantage, and why?
[Re: Rolf_Nilsen]
#252665 09/24/12 07:23 PM 09/24/12 07:23 PM | chackett
| chackett
Unregistered | Another situation is gusty conditions, I find it difficult to be solo, only two arms and dealing with conditions where you could use some downhaul on and off, possibly some mast rotator adjustment, traveller adjustment, and then the newer f16s with the long boards. I would have to think a good solo sailor against a good light-mod weight 2 up team is going to lose 8 out of 10 buoy races. | | | Re: Uni vs 2-up.. Who have the racing advantage, and why?
[Re: waynemarlow]
#252676 09/24/12 10:16 PM 09/24/12 10:16 PM |
Posts: 4,119 Northfield Mn | Here's my take on things, for what its worth. I typically sail a pretty good mix of uni and sloop. The last two years have been mostly two up, but I think next year will be a different story and I will be back to sailing singlehanded. This is also figurin' that crews are of about equal skill. Observations, no real data to back up a single thing. This is also written more from a singlehanded point of view I guess. I'd say I'm probably on the side of defending the singlehanders. Light air- (I'll define this as sitting on the boat, and not depowering anything) Upwind the two up boats have this pretty well lit up. Mostly because I think its easier to sail a sloop in lighter air. The uni has some height, sure, but the sloop boats have a small advantage going to weather. Especially if there is chop. The extra weight helps get through that. Downwind I'd say the uni has some advantage. Not much difference in height, but downwind sail area is about the same, and the uni can really accelerate and latch onto something moving down the course. light/moderate air- (On and off the wire singlehanded but mostly on, sloop boats will be sending crew out here and there) This is where the uni shines. You've got height going to weather, and about equal boat speed. Things are moving, but you haven't run out hands yet, and the loads aren't killing you. Downwind you are a rocket and you may or may not be wiring downwind. moderate air - (Singlehanded is on the wire consistently, two up boats are mostly two wire sailing going to weather, maybe trapping downwind) Uni is starting to get their hands full, and depowering a bit, whereas the sloops aren't doing much in that department. There's more sheeting to be done, and few and far between can run a main with one arm like a crew can with two. Downwind I'm on the wire as much as possible. You pretty much have to be to make up ground on the sloop boats well. Which is another reason why I like having an equal number of course legs, ie two upwind legs, two downwind legs. Heavy air- (singlehanded is depowered big time and probably maxed, sloops pretty much are too, sloops are definitely wiring downwind. This is where I get my butt handed to me. I've abandoned trapezing downwind because it creates more problems than boat speed for me. I can do it up to about 16kts of wind, but that's about it. There isn't enough weight to get the speed up and really get the apparent wind around, and it starts getting trippy and wanting to dive a lot. I'm not sure its so bad though, as you can drive deep really deep. Upwind though I do think the advantage switches back around to the uni. You don't have the righting moment, but you've got good boat speed, and good angles. You end up footing a bit, because you can't sheet the main properly anyway as it creates too much power. Also screwup's singlehanded get to be much more fatal. Bad jibes, bad douses, etc. and that can cripple things pretty quickly. Things are just moving mega fast, and are hard to keep up with. Really heavy air- (singlehanded I'm on the beach, to me that's 20+kts) F that noise. I'll mix another drink. I'm not overly fond of it two up either, but I'll do it, and I can have fun. Though weak points tend to get exploited, (either in gear, or skills) I finish about in the same place in either configuration. Some days are better than others for sure in either scenario. I really don't have much of a preference, except in big fleets. I like having a second set of eyes on the boat for traffic, and you are blind as a bat going downwind on the wire singlehanded. Mark roundings are tough. I've got a big wing span so setting the spin goes quickly, and a pretty good technique for not touching the tiller while either dousing or hoisting the spinnaker. I'm a bit rusty on the singlehanding, but there was a point where I could jibe every bit as well solo as I could with crew. I do think it takes a different kind of skill set to sail the two configurations. I hadn't been on the boat solo since May up until this past weekend. I had forgotten how to do it. I don't think one is really easier than the other, just different. I will say you have to be more refined with what you do, and think way ahead singlehanded, but that's more just from not being able to do three things at once. Like steer, sheet the main, and pull the tackline. Just my thoughts. For me the clincher was seeing Greg do so badly at Garda when he sailed solo. In a later discussion I had with the SCHRS all those involved seem to agree on the advantages of the dual handed boats in almost any part of a sailing race course. Let's take away you're mainsheet cleat and see how well you do. Greg is a good sailor, but I know he hasn't spent a ton of time sailing the Viper singlehanded either. It is a completely different animal in the two different configurations.
[Re: Rolf_Nilsen]
#252705 09/25/12 11:44 AM 09/25/12 11:44 AM |
Posts: 6,049 Sebring, Florida. | Racing Uni is definately harder, and presents more challenge upwind and down, but that's why I do it, for the challenge. AND...if you do poorly, you have no crew to blame!
As Karl mentioned, I have seen sloops go by me upwind, in very light air, mostly due to the 'turbo' effect the jib gives to the main. But I usually catch them downwind, as I have less weight.
It's usually at the downwind mark/spin douse, where I lose some distance to the Sloops, as they can do it while the skipper is still steering, or out on the wire, and he's trimming the main in, etc. while I've got to basically stop driving/trimming, snuff the spin, and then get back out on the wire and start trimming again.
Having an extra set of hands is a real advantage there, which only gets bigger as the wind increases. Coming in off the wire to snuff really hurts the Uni vs. the Sloops.
If I had the money, and good, reliable, regular crew, I'd have an A cat and a F Something (16 or 18).
The A cat would be for when my crew was unavailble or to go to a good local A cat regatta, and the F boat for the two up 20kt spinnaker runs!
I think in the 'average' wind, what ever that is, (say 8-10kts?) they are pretty equal around the cans, so it comes down to who is sailing their boat at 'optimum' speed with every puff and lull, who see's the shifts coming and who takes advantage quicker. It is easier in all conditions, for the two up crew to shift gears re. adjusting the downhaul, rotator, etc. with two more hands avaiable. So the gustier it gets, the more the sloops should do better by being able to shift gears quicker.
Blade F16 #777
[Re: Rolf_Nilsen]
#252721 09/25/12 09:48 PM 09/25/12 09:48 PM |
Posts: 217 Palm Harbor, FL | So far there have only been 9 voters in the poll. Surely more sailors must have an opinion?
I don't feel qualified to have a vote. I usually sail 1-up and the few times I've had someone else onboard, I still didn't bend on the jib, and I haven't been in any real races, just some beer can runs. I only have one harness. When my wife/crew does go out with me, she wears the harness and her sole job is to make sure we don't capsize. I leave the jib on shore, and I still take care of everything as if I was sailing 1-up. Of course, just because I'm not qualified to vote doesn't mean I'm lacking in an opinion. I'm only 150 lbs and it seems to me that I have to de-power the rig long before 2-up crews do. Also, my main is cut for a jib, so it's very hard to get proper flow across both the top and bottom of the sail, usually either the top is luffing or the bottom is stalling. I've heard about Greg doing badly at Garda, and I can't help but wonder... Was the jib hardware still on the boat? (That jib traveller is pretty heavy.) Was the main cut for a jib? Also, I have sailed an A-Cat a few times and to me, an F-16 has a very different feel. How much 1-up practice did he have *on an F-16*?
Daniel T. Taipan F16 - USA 213 | | | Re: Uni vs 2-up.. Who have the racing advantage, and why?
[Re: Rolf_Nilsen]
#252725 09/26/12 07:38 AM 09/26/12 07:38 AM |
Posts: 4,119 Northfield Mn | He didn't break the cleat, there wasn't one. How do you hold a main and a spin sheet?
[Re: Rolf_Nilsen]
#252726 09/26/12 07:46 AM 09/26/12 07:46 AM |
Posts: 5,525 | I've decided to add a spin cleat.
Pete Pollard Blade 702
[Re: Rolf_Nilsen]
#252727 09/26/12 07:49 AM 09/26/12 07:49 AM |
Posts: 4,119 Northfield Mn | I've got cleats for the spin sheet. I only use them when cruising.
[Re: Rolf_Nilsen]
#252728 09/26/12 07:52 AM 09/26/12 07:52 AM |
Posts: 5,525 | Mounted where? Side stays?
[Re: Karl_Brogger]
#252729 09/26/12 07:55 AM 09/26/12 07:55 AM |
Posts: 6,049 Sebring, Florida. | He didn't break the cleat, there wasn't one. How do you hold a main and a spin sheet? I've been thinking about Greg's problem with no mainsheet cleat since I first heard about it. I think I might have tried to trim in the main to the 'right place' and tie a slip knot in it, then leave it alone and trim the spinnaker. I almost never touch my mainsheet downwind when Uni, just not enough hands.
Blade F16 #777
[Re: Rolf_Nilsen]
#252730 09/26/12 08:01 AM 09/26/12 08:01 AM |
Posts: 5,525 | +1
My deficiency has always been to weather. Downwind is relatively a much simpler matter. But I think adding spin cleats will make the jibes a little smoother by sheeting some on the slack sheet before the tack begins.
[Re: Karl_Brogger]
#252735 09/26/12 10:14 AM 09/26/12 10:14 AM |
Posts: 893 | He didn't break the cleat, there wasn't one. How do you hold a main and a spin sheet? Just last week I had the main cleat jam open ( just needed a bit of lubrication ) simply put a loop in a half hitch as I came around the top mark. It took all of about 10 seconds extra. At the bottom mark I simply let out the travellor, snuffed the spinny away, pulled the main and the loop came out,up with the travellor and back to norm where I don't cleat the main on the upward leg. Worked well and little time lost. Anyway its not about Greg and in some ways I am sorry I used that as an example, but what people honestly think about the racing advantages of uni v sloop. If there are appreciable advantages then how do we rectify that or do we just admit defeat and let the solo boats form their own group and sail under their own rules. | | | Re: Uni vs 2-up.. Who have the racing advantage, and why?
[Re: Rolf_Nilsen]
#252737 09/26/12 10:32 AM 09/26/12 10:32 AM |
Joined: May 2003 Posts: 4,451 West coast of Norway Rolf_Nilsen OP
Posts: 4,451 West coast of Norway | I dont think we should include non-functional equipment issues like cleats jammed open or not installed in this discussion. 10 secs to tie a slip knot is 10 sec too much anyway  (competition will be halfway down to the bottom mark when the knot is tied and the spi is flying) The poll dont have enough participants to be representative but the trend there is clearly that two-up have most of the advantages over uni. Except for what input Gilo posted most seem to accept this as a fact and only have "train harder, sail smarter" as strategy to come out on top. What other options do we have? Personally I dont see that many options within the class rules. * Segregate unis from two ups? * Allow different equipment on unis and loose the effortless switch from uni to two-up (which was a very strong selling point for the class in the beginning)? * Give unis a time advantage when racing and loose "first over the line wins" ease of racing? * Allow a different mainsail on unis? Any creative input? Suggestions for improvements on todays percieved situation without impacting the class? | | |
1 registered members (Team_Cat_Fever),
361
guests, and 94
