Page 2 of 3 1 2 3
Re: Camera mount ideas [Re: Chris9] #254946
11/19/12 01:33 PM
11/19/12 01:33 PM
Ixnay on the behind the tramp thing. I mounted one on a post to the rudder pintles and it worked great until JC whacked it with the ugly stick during a gybe at Mug Race. Then all I saw was brown water for 30 minutes.
If you are going to do a forward looking shot, you probably need to mount the camera to an extension rod about 3 feet behind the rear beam. If it's beefy enough it won't bounce too badly. Now, if you can get it to move to the windward side, you're all set. Perhaps some linkage to the traveler?
And it has to be high enough off the deck so you don't just see the backside of the driver... But maybe those wide-lens models have solved that?
Anyone tried the windward shroud about head high (standing on deck) looking forward? Sure it would bounce around on the opposite tack and be covered by the spin, but at least you'd have a "good side" to work with?
Re: Camera mount ideas [Re: Isotope235] #254954
11/19/12 02:30 PM
11/19/12 02:30 PM
Portland, Maine
ThunderMuffin Offline
Portland, Maine
1 on end of Spin Pole, 1 on the tiller arm.
I like the tiller arm one.
Re: Camera mount ideas [Re: ThunderMuffin] #254957
11/19/12 03:05 PM
11/19/12 03:05 PM
who schooled you on USA 1 with the blue spinnaker?
Re: Camera mount ideas [Re: waterbug_wpb] #254959
11/19/12 03:10 PM
11/19/12 03:10 PM
tampa, fl
K
ksurfer2 Offline
ksurfer2  Offline
K
tampa, fl
That was Brett and JC on the Marstrom 20.
Re: Camera mount ideas [Re: Team_Cat_Fever] #254960
11/19/12 03:12 PM
11/19/12 03:12 PM
Roanoke Island ,N.C.
Team_Cat_Fever Offline OP
Thanks Tad,
That helped.
I like the tiller angle but the movement and water was what I expected. The Drift has a pretty wide angle I think I'll probably try the boom and see how it works.
What did you use for editing? I'd be interested to hear from non mac folks about this.
Isak Dinesen
E. B. White
Re: Camera mount ideas [Re: Team_Cat_Fever] #254962
11/19/12 03:25 PM
11/19/12 03:25 PM
Thanks Tad,
That helped.
Windows Live Moviemaker. It's free and pretty darn good / easy to use. You can upload to Youtube straight from the software too.
Re: Camera mount ideas [Re: Team_Cat_Fever] #254964
11/19/12 03:43 PM
11/19/12 03:43 PM
I used PowerDirector for some videos in the past, simple to use and had plenty of features for amateur videos:
http://www.cyberlink.com/products/powerdirector/introduction_en_EU.html
Mounting positions are personal, I like filming from the spin pole and using a headstrap.
Re: Camera mount ideas [Re: Tony_F18] #254965
11/19/12 03:49 PM
11/19/12 03:49 PM
most head mounted cams are hard to watch - you don't realize how much you look around when sailing.
I wonder if a shoulder mounted cam might provide an interesting angle? It would get you coming and going on port vs. starboard.
Re: Camera mount ideas [Re: Jake] #254972
11/19/12 04:04 PM
11/19/12 04:04 PM
Originally Posted by Jake
Thanks Tad,
That helped.
I think I already have that in a bundle that came with the computer. Sounds good. I like easy.
Isak Dinesen
E. B. White
Re: Camera mount ideas [Re: Team_Cat_Fever] #254974
11/19/12 04:11 PM
11/19/12 04:11 PM
Gopro has a chest mount, that might work:
There was an F18 teamrace event at my club that used heavyduty suction cups with some tubes to keep the camera centered behind the boat, it makes for a nice vantage point:
Re: Camera mount ideas [Re: Tony_F18] #254979
11/19/12 04:27 PM
11/19/12 04:27 PM
very nice. Caught a glimpse of the 3-point mount in a few of those shots.
I'd say that's a winner - get good forward view on both tacks.
Maybe someone could post the dimentions and materials?
Re: Camera mount ideas [Re: waterbug_wpb] #254982
11/19/12 05:34 PM
11/19/12 05:34 PM
I like the angle alot ,just not all the trusswork to get it. That's perfect for what they were doing with all the boats having them though.
Isak Dinesen
E. B. White
Re: Camera mount ideas [Re: Team_Cat_Fever] #254984
11/19/12 05:36 PM
11/19/12 05:36 PM
I would think some lightweight aluminum would make it robust without adding a lot of weight.
And if everyone had them attached, it would improve footage as well as even out the field (if the weight were seen as a disadvantage?)
Re: Camera mount ideas [Re: Team_Cat_Fever] #254990
11/19/12 06:49 PM
11/19/12 06:49 PM
That's exactly what I was thinking.
I hear Tawd can make things outta wood too. Get yourself a couple of 2x10's, and whip it up....
Re: Camera mount ideas [Re: Karl_Brogger] #255003
11/19/12 11:36 PM
11/19/12 11:36 PM
Booger, let me know when you're ready for your lessons.
Isak Dinesen
E. B. White
Re: Camera mount ideas [Re: Team_Cat_Fever] #255016
11/20/12 08:47 AM
11/20/12 08:47 AM
When it comes to trimming, anytime. I'm a horrid trimmer. I can do crown like a mofo, but when it comes to 2-1/4" thin butt casing and f'd up walls I start losing my mind. I've yet to do stairs as well. I'm a cabinet maker. wink
Re: Camera mount ideas [Re: Team_Cat_Fever] #255018
11/20/12 09:00 AM
11/20/12 09:00 AM
Portland, Maine
Portland, Maine
Thanks Tad,
That helped.
I was worried about the movement too. The trick I used was to put the camera on the END of the tiller arm on the crossbar right inside the plastic pieces, not further back. This meant that the camera moved side to side and didn't "pan" back and forth which would have been seriously annoying.
I used Adobe Premier Pro and After Effects. Its part of the Creative Suite.
Re: Camera mount ideas [Re: Team_Cat_Fever] #255019
11/20/12 09:13 AM
11/20/12 09:13 AM
You could do it with one aluminum rod and a couple of stays to the rudder pintles (maybe).
Re: Camera mount ideas [Re: Team_Cat_Fever] #255022
11/20/12 09:23 AM
11/20/12 09:23 AM
M
MN3
MN3
M
i have used the double-sided sticky tape mounts for the gopro in several places (decks & mast). The tape has held up through a few extreme incidents (getting snagged with the spin sheet, kicked with a foot, etc) But if the camera wasn't tethered... it would have sunk.
Re: Camera mount ideas [Re: Karl_Brogger] #255028
11/20/12 10:49 AM
11/20/12 10:49 AM
That was a joke, boy, a funny haha.
Isak Dinesen
E. B. White
Page 2 of 3 1 2 3
1 registered members (soulofasailor), 1,976 guests, and 26 spiders.
