by Karl_Brogger. 12/29/24 05:14 PM
curved dagger boards #255451
12/04/12 07:43 AM
12/04/12 07:43 AM
Kiel, Germany
Baltic Offline OP
Baltic  Offline OP
Kiel, Germany
Interesting points on the agenda of the WC-meeting in Paris mid December are the permission to use GPS devices and a discussion concerning handicap for curved dagger boards.
Which are your positions concerning these matters?
Kai
F18: C2 / A-Cat: Minelli
Re: curved dagger boards [Re: Baltic] #255454
12/04/12 08:16 AM
12/04/12 08:16 AM
I think a list of approved GPS devices is a good idea, at the moment magnetic sailing compasses are more expensive than their GPS counterparts anyway (Tacktick etc).
Not aware that there are any F18s with curved foils.
With boats are expensive enough as they are and declining fleets I'm not sure if that is the way to go.
Re: curved dagger boards [Re: Tony_F18] #255456
12/04/12 08:40 AM
12/04/12 08:40 AM
tampa, fl
K
ksurfer2 Offline
ksurfer2  Offline
K
tampa, fl
With regards to GPS enabled devises.....things like the Speedpuck will not change the game. The guys at the front of the fleet will be the same guys whether or not they are using one. Same for the mid fleet and back of the fleet groups. Personally, I tried sailing with a tack tick for a while. While racing though, I hardly ever looked at it. After a tangle with the spin sheet, it went over board. Never bothered to replace it. Results certainly have not changed as a result.
Curved daggerboards are another story. The council could, potentially, make every F-18 currently sailing obsolete. If they want to bring about the end to the class, then go ahead and approved curved boards. Personally, I think it would be crazy to approve. If there are sailors out there that want to sail boats with curved foils, go by an A-cat, F-17, or Nacra F20. Leave the F-18's out of that game.
Re: curved dagger boards [Re: Baltic] #255468
12/04/12 11:45 AM
12/04/12 11:45 AM
Boston, Ma
Jeff.Dusek Offline
Jeff.Dusek  Offline
Boston, Ma
The USF18 Exec is currently looking over that agenda, there are definitely some interesting points.
As far as the curved daggerboards, it would be nice to see the actual proposal as I'm not entirely sure what they are actually suggesting!
USF18 Eastern Area Rep
Nacra Infusion USA 753
Re: curved dagger boards [Re: Baltic] #255473
12/04/12 01:40 PM
12/04/12 01:40 PM
Solomon's Island, MD
samc99us Offline
samc99us  Offline
GPS should be allowed, that rule is a bit silly. Won't change a darn thing, the pros will still be pros.
+1 on the curved daggerboards, need to see the proposal. Actually I'd like to see the boat!
Scorpion F18
Re: curved dagger boards [Re: samc99us] #255474
12/04/12 02:19 PM
12/04/12 02:19 PM
tampa, fl
K
ksurfer2 Offline
ksurfer2  Offline
K
tampa, fl
You can see the boat. Check this out. But please....DO NOT make it F-18 class legal!!!!
http://www.catsailingnews.com/2012/10/low-flying-phantom.html
Re: curved dagger boards [Re: Baltic] #255475
12/04/12 02:43 PM
12/04/12 02:43 PM
Seen that particular cat up close but apart from the hulls there is little F18 about it (3m wide, carbon mast, foils, etc).
Re: curved dagger boards [Re: Baltic] #255476
12/04/12 03:16 PM
12/04/12 03:16 PM
samc99us Offline
samc99us  Offline
That's the GC32 prototype. Agreed its not a F18.
Scorpion F18
Re: curved dagger boards [Re: Baltic] #255477
12/04/12 04:00 PM
12/04/12 04:00 PM
I think the proposed marketing plan is interesting and quite ambitious, trying to develop F18 into a sort of brand.
Not sure if there is an audience for F18 branded items though, but I could be wrong.
Re: curved dagger boards [Re: ksurfer2] #255485
12/05/12 09:03 AM
12/05/12 09:03 AM
Would this then doom the F-18 design to obsolescence?
Sort of like when the N20 rule kept an outdated sailplan?
But I guess there are still many huge fleets of outdated designs (laser, Opti, Star, 420, etc)
Re: curved dagger boards [Re: waterbug_wpb] #255491
12/05/12 10:25 AM
12/05/12 10:25 AM
tampa, fl
K
ksurfer2 Offline
ksurfer2  Offline
K
tampa, fl
[quote=ksurfer2]
F-18 was never meant to be cutting edge. It was meant to provide a level playing field between manufacturers with controlled development that would keep it "affordable" to the sailors. So far, that plan has worked brilliantly.
F-18's could be built full carbon, carbon spars and beams, curved foils, etc. but that would defeat the purpose of the class. If that's the kind of boat you want to sail, go buy a Marstrom 20. That is not what F-18's are meant to be.
Re: curved dagger boards [Re: waterbug_wpb] #255492
12/05/12 10:41 AM
12/05/12 10:41 AM
Clermont, FL, USA
David Ingram Offline
Clermont, FL, USA
Jay, the N20 didn't die because of the "outdated" sail plan! If that were true we should have seen the N20 resurrected from the ashes when the p-cola group created a new class allowing sail plan development. You also need to ask yourself why the F20C class hasn't blown up.
Many consider the F18 obsolete right now and so freaking what! I didn't join the F18 class because of its light weight and carbon fiber!
Like Karl said there are several curved dagger board options out there, leave the F18 alone. I for one feel very comfortable that straight daggerboards will NOT be the classes downfall. When racing class do we really give a sh!t if we don't have the latest go fast gizmo? There is a lot to be said for stability. When someone lays down 20K+ for brand new boat only to find out that they need to upgrade their boards at the tune of another $2400 can get you thinking, is this class worth the expense?
We also need to ask ourselves who is bringing the proposal forward, who do they work for and are they really considering the impact to the weekend warrior, which by the way is the core of the class. What is good for the pro's can often be at the expense of the amateur.
F18 USA 242
http://www.solarwind.solar
Re: curved dagger boards [Re: Baltic] #255493
12/05/12 10:46 AM
12/05/12 10:46 AM
Boston, Ma
Jeff.Dusek Offline
Jeff.Dusek  Offline
Boston, Ma
I put together a poll for the Eastern Area F18 group that addresses the proposals on the agenda. Mike and I are trying to get it circulated amongst the other areas as well. If you are a US F18 sailor, please fill it out and pass it along to your fleet.
https://docs.google.com/spreadsheet/viewform?formkey=dEdPZ2UzdFVncTVBWmFocXpwYVJRNUE6MQ#gid=0
Re: curved dagger boards [Re: Jeff.Dusek] #255494
12/05/12 10:56 AM
12/05/12 10:56 AM
Clermont, FL, USA
Clermont, FL, USA
Jeff,
The first question under F18 Branding needs a "none of the above" option.
Dave
F18 USA 242
Re: curved dagger boards [Re: Baltic] #255496
12/05/12 10:59 AM
12/05/12 10:59 AM
Boston, Ma
Jeff.Dusek Offline
Jeff.Dusek  Offline
Boston, Ma
Dave, good point! I will edit.
-done
Re: curved dagger boards [Re: Jeff.Dusek] #255498
12/05/12 12:02 PM
12/05/12 12:02 PM
Clermont, FL, USA
Clermont, FL, USA
Done, and thank you for putting that together. It's a very efficient to get a read on the fleet.
F18 USA 242
Re: curved dagger boards [Re: Baltic] #255499
12/05/12 12:39 PM
12/05/12 12:39 PM
Is there a way to see the results of the poll?
Re: curved dagger boards [Re: Baltic] #255501
12/05/12 01:15 PM
12/05/12 01:15 PM
Boston, Ma
Jeff.Dusek Offline
Jeff.Dusek  Offline
Boston, Ma
Results are available for the USF18 exec. I will summarize the results after the international meeting.
Re: curved dagger boards [Re: Jeff.Dusek] #255504
12/05/12 02:44 PM
12/05/12 02:44 PM
interesting question posted about making the F18 website commercial.
What kind of revenue projection would something like that have, and where would the money go? What qualifies an advertiser? Russian Brides come to mind...
Re: curved dagger boards [Re: Baltic] #255507
12/05/12 08:45 PM
12/05/12 08:45 PM
If it involves a donkey and a midget, I'm in.
0 registered members (), 265 guests, and 85 spiders.
Posts267,059
