| Re: Blade F16
[Re: waterbug_wpb]
#257087 02/06/13 03:23 PM 02/06/13 03:23 PM | Scarecrow
| Scarecrow
Unregistered | A couple of comments on the above.
1. F18 boards are really heavy due to their length, the rules and the boat's huge righting moment compared to an F16.
2. I have to dissagree with Rolf, for projects like this wood is not good it is great. Built properly a carbon skinned timber cored foil will be about the same weight as the foam carbon alternative and if you're not paying for the labour they're much cheaper (this was demonstrated to me by a very good i14 builder).
3. I agree with Macca with regards to a bit of extra thickness. 2mm (19->21mm) will add over 20% more strength | | | Re: Blade F16
[Re: ]
#257089 02/06/13 03:51 PM 02/06/13 03:51 PM |
Posts: 4,451 West coast of Norway | My grip is with plywood. Plywood have nothing to do inside high performance foils. Details on "proper" build of a wood core carbon covered foil is most interesting! What wood (species, fast grown/slow grown, weight pr cm3 etc). Cutting and staggering of timer staves to avoid warp. Laminate schedule. I like wood! As in "I love wood!"  The material is cheap and strong, easy to work with, excellent durability, relatively lightweight, very environmentally friendly and so on. With the Gougeon book available as a PDF for download I hope more people try their hand with wood.
| | | Re: Blade F16
[Re: waterbug_wpb]
#257092 02/06/13 04:56 PM 02/06/13 04:56 PM |
Posts: 5,525 | So, if not plywood then what? As regards plywood, I was thinking Brunzyeel for the finished product but anything from the local box store for a model.
Pete Pollard Blade 702
| | | Re: Blade F16
[Re: Rolf_Nilsen]
#257093 02/06/13 04:59 PM 02/06/13 04:59 PM | Scarecrow
| Scarecrow
Unregistered | Rolf,
the way I we've built "timber foils" before is.
1. Select straight grained timber with good strength to weight ratio (ie cedar) of say 1" (25mm thickness).
2. Cut into narrow strips, reverse alternate layers glue and clamp back together.
3. Place whole thing in thicknesser and dress until "flat"
4. Laminate solid glass strip up to same thickness (de-bulk and bag)
5. glue glass to front and back edges.
6. Machine to shape (you want solid glass lead and trailing edges)
7. Create rebate for uni strips at maximum thickness point. Note unis can be tapered out between 50mm below hull exit and lower end of board.
8. Fair over unis.
9. Apply laminate.
10. Fair and paint. | | | Re: Blade F16
[Re: waterbug_wpb]
#257097 02/06/13 05:06 PM 02/06/13 05:06 PM |
Posts: 5,525 | Cedar? Here in the U.S. I'm guessing the most suitable species would be western red cedar. Anyone hazard a quess?
| | | Re: Blade F16
[Re: waterbug_wpb]
#257112 02/07/13 12:08 AM 02/07/13 12:08 AM | Scarecrow
| Scarecrow
Unregistered | Not western red, it has too much oil in it so will delaminate too fast. Go for Spruce, Hughes didn't pick it because he liked the colour. | | | Re: Blade F16
[Re: ]
#257121 02/07/13 08:27 AM 02/07/13 08:27 AM |
Posts: 4,119 Northfield Mn | Not western red, it has too much oil in it so will delaminate too fast. Go for Spruce, Hughes didn't pick it because he liked the colour. Why not a hardwood? It'd be twice the weight, but there isn't much mass to begin with.
| | | Re: Blade F16
[Re: mini]
#257130 02/07/13 09:48 AM 02/07/13 09:48 AM |
Joined: Dec 2001 Posts: 5,590 Naples, FL waterbug_wpb OP
Posts: 5,590 Naples, FL | Never mind the danger of the sharp trailing edge meat slicer way up in the air just waiting to catch the crew sliding forward if you happen to stuff it. FRUIT NINJA!
| | | Re: Blade F16
[Re: Karl_Brogger]
#257131 02/07/13 09:49 AM 02/07/13 09:49 AM |
Posts: 5,590 Naples, FL | petrified wood? Talk about sailing a "classic". How about one thousands of years old?
| | | Re: Blade F16
[Re: Karl_Brogger]
#257149 02/07/13 12:56 PM 02/07/13 12:56 PM |
Posts: 774 Greenville SC | Not western red, it has too much oil in it so will delaminate too fast. Go for Spruce, Hughes didn't pick it because he liked the colour. Why not a hardwood? It'd be twice the weight, but there isn't much mass to begin with. Sitka spruce is pretty much the standard in aviation for its characteristics in weight, strength and flexibility. Marine applications such as this should be much the same. | | | Re: Blade F16
[Re: Rolf_Nilsen]
#257162 02/07/13 03:20 PM 02/07/13 03:20 PM |
Posts: 932 Solomon's Island, MD | Hi Scarecrow,
Questions: 7. Uni strips with carbon? How much would you guesstimate is enough for a 1995x21x180mm board?
8. Fairing. How much work is this and how precise is the result? How critical is the trueness to the designed profile?
9. Is this laminate only to make the foil durable so a 120 to 220gsm glass cloth is enough?
In your opinion:
How critical is accuracy to the designed profile. Is a tolerance of 1mm, 0,1mm or even 0,01mm the target?
What about geometry of the foil. Any tapers complicate work. Same with rounding off the tip etc. Yet this is often not discussed even if it is "standard" to aim for an elliptical pressure distribution and to avoid drag from tips.
Thanks for your insights, much appreciated! We are operating at reasonable Reynolds numbers, close to 1 million when sailing at 10 kts. Doing some first order calculations, assuming the flow is laminar (i.e smooth), looking 0.25in (6.4mm) aft of the LE, the boundary layer is 0.098in (2.5mm). Effectively this means any scratches or bumps within that distance would have no effect on the performance of the foil as the water around the foil can't even see them. However, there are A LOT of assumptions made in that first order analysis and you always want to build the best foil you possible can. My #1 tip if selecting a foil for a home build is to go with something whereby the performance doesn't degrade drastically due to imperfections. For example, a laminar flow section like the NACA 63-209 discussed here ( http://www.foils.org/hysecdes.pdf) is much more sensitive to surface imperfections and things like kelp than a more traditional foil. The NACA0010 that was designed to operate in a more turbulent flow environment where the boundary layer is even thicker and hence you can get away with even more, besides it is easier to build accurately.
Scorpion F18
| | | Re: Blade F16
[Re: ]
#257172 02/07/13 03:50 PM 02/07/13 03:50 PM |
Posts: 932 Solomon's Island, MD | Rolf,
8. Fair over unis.
9. Apply laminate.
10. Fair and paint. I am not an expert at wood construction by any means. I guess you have to laminate strips together to avoid warping along a grain line?
Scorpion F18
| | | Re: Blade F16
[Re: waterbug_wpb]
#257178 02/07/13 04:47 PM 02/07/13 04:47 PM |
Posts: 4,119 Northfield Mn | The smaller the strips, the less warping you'd have. So long as you flipped the pieces, assuming they came from the same stock.
| | | Re: Blade F16
[Re: Rolf_Nilsen]
#257186 02/07/13 06:16 PM 02/07/13 06:16 PM | Scarecrow
| Scarecrow
Unregistered | Hi Scarecrow,
In your opinion:
Thanks for your insights, much appreciated! Rolf, too many variables, to little time to give you a back of the envelope estimate. Design path goes something like this: 1. Determine maximum righting moment. 2. Determine worst case lift distribution from rig. 3. Using above info calculate max side force on foil 4. Calculate lift distribution on foil. 5. Calculate moments and forces on foil. 6. Determine young's modulus and allowable stresses on selected timber. 7. Determine young's modulus and allowable stresses on proposed laminate. 8. decide on allowable flex on fully loaded foil. 9. determine section modulus of proposed foil. 10. adjust number of carbon layers until deflection goal is achieved. 11. confirm maximum stress due to bending in various components. 12. adjust laminate to suit. 13. check shear strength of core (particularly in way of hull exit). 14. Repeat all of the above because I've almost certainly lost a decimal place somewhere. The exterior laminate makes it more durable but also must take into account hoop stength and twisting, yes you can use glass but it will be heavier. Profile (meaning the shape of the board when view from the side) is in theory very important, however there is a trade off between efficiency with the foil down and up. If you taper the lower end you can reduce drag, however, it is at the expense of drag when you pull the foils up as you end up with slop in the case or a small amount of foil left down. Section shape is important but don't dwell on it too much the shapes people use (with the exception of Richard Roake, Martin Fischer and their peers), be they NACA or any other profile are merely part of systematic analysis programs where one variable has been changed at a time, they are not "ideal solutions", so pick one which has the characteristics you want and do your best to match it but your priority should be a fair (consistand curvature without waves) shape. | | | Re: Blade F16
[Re: waterbug_wpb]
#257272 02/11/13 09:10 AM 02/11/13 09:10 AM |
Posts: 4,451 West coast of Norway | Hi Klaus, as smooth as possible is an "unclear" target  In your opinion, how smooth should a homebuilder aim for? The combination of surface roughness and a true section is a challenge if working by eye and hand accuracy. Is there a crossover point between the importance of sectional trueness and surface smoothness? A CNC millcan work down to 0.001mm accuracy and some light sanding will give smoothness (or the machine can produce that as well if it is good enough). | | | Re: Blade F16
[Re: waterbug_wpb]
#257287 02/11/13 11:11 AM 02/11/13 11:11 AM |
Posts: 5,525 | I think this bears repeating.
"Other than stated here in this forum, skin smoothness or quality is very important, 1 mm roughness would have an catastrophic impact, and 0.1 would be still significant. A foil should be as smooth as possible and smoothness is more important than the section."
So what degree of smoothness can a home builder hope to achieve using hand tools?
1,174
guests, and 41
