| Re: Hagar Feb 9?
[Re: ThunderMuffin]
#257265 02/11/13 07:34 AM 02/11/13 07:34 AM |
Posts: 12,310 South Carolina | Yeah I think the second little pop was either my weight finishing the job or just another seam letting go on the sail. I did luck out in that I didn't hit the boom straight. You almost got a high rise out of the boom! That was a great video angle.
Jake Kohl | | | Re: Hagar Feb 9?
[Re: ThunderMuffin]
#257268 02/11/13 07:50 AM 02/11/13 07:50 AM |
Posts: 6,049 Sebring, Florida. | Sucks to get dropped off the wire like that!
So...who didn't replace the worn out trap line?
Or did something else let go?
Blade F16 #777
| | | Re: Hagar Feb 9?
[Re: ThunderMuffin]
#257275 02/11/13 08:35 AM 02/11/13 08:35 AM |
Posts: 4,119 Northfield Mn | That SUCKS!
I do find it extremely funny that a split second before the crew splashes, it looks like he's checking his watch, (or at least just looking at his wrist), then poof, he's gone.
Great angle Tad, sorry for your main. Its a sad realization that you just went winging through an expensive piece of cloth.
| | | Re: Hagar Feb 9?
[Re: Karl_Brogger]
#257276 02/11/13 08:36 AM 02/11/13 08:36 AM |
Joined: Jan 2008 Posts: 3,655 Portland, Maine ThunderMuffin OP
Posts: 3,655 Portland, Maine | That SUCKS!
Great angle Tad, sorry for your main. Its a sad realization that you just went winging through an expensive piece of cloth. Eh. It can be replaced :P | | | Re: Hagar Feb 9?
[Re: Karl_Brogger]
#257280 02/11/13 09:27 AM 02/11/13 09:27 AM |
Posts: 12,310 South Carolina | That SUCKS!
Great angle Tad, sorry for your main. Its a sad realization that you just went winging through an expensive piece of cloth. I had a quote running through my head, "emergency departure initiating in 3...2....1...."
[Re: ThunderMuffin]
#257285 02/11/13 09:51 AM 02/11/13 09:51 AM |
Posts: 6,049 Sebring, Florida. | Timbo: The stopper knot that held the pigtail to the bungee pulled through the stopper ball. In retrospect, that stopper ball was way too big for the diameter line I was using.
I was worried that my eye splice let go but no.. in the video I was able to slow mo it in Premier Pro and see that the bungee pulled right through the block on his way into the drink.
Lesson learned. That sucks! I had a similar thing happen, had a knot let go on a trap handle, but mine happened just as I got out onto the wire in a good breeze, right on the starting line, at GO time, in a 23 boat fleet! I went straight into the drink, the boat went over, luckily I was down by the pin, so it didn't hit anyone. I got the boat up quickly enough, but with no trap handle on one side, and being Uni, I had to go to the beach to replace it! I hate it when that happens!
Blade F16 #777
| | | Re: Hagar Feb 9?
[Re: ThunderMuffin]
#257286 02/11/13 10:07 AM 02/11/13 10:07 AM |
Posts: 5,525 | We can put a man on the moon, but so far as I know there is no full proof trapeze rig.
Pete Pollard Blade 702
| | | Re: Hagar Feb 9?
[Re: ThunderMuffin]
#257288 02/11/13 10:13 AM 02/11/13 10:13 AM |
Posts: 3,224 Roanoke Island ,N.C. | Human error is ALWAYS the fault of traps breaking. Set it up right and replace worn parts and it won't happen. It's just not always a priority like standing rigging.
| | | Re: Hagar Feb 9?
[Re: ThunderMuffin]
#257290 02/11/13 10:29 AM 02/11/13 10:29 AM |
Posts: 3,224 Roanoke Island ,N.C. | I'd just re-rigged the whole trap system with the adjustable rig.
The knot/ball were just not the right size. Critical mistake - wont be made again.
I've done the same. It's pretty amazing how fast the shock cord stretches out. Both times I've had trap failures (both my fault) the rings were still in the harness because of the keeper.
| | | Re: Hagar Feb 9?
[Re: Team_Cat_Fever]
#257292 02/11/13 10:48 AM 02/11/13 10:48 AM |
Posts: 4,119 Northfield Mn | We can put a man on the moon, but so far as I know there is no full proof trapeze rig. No doubt. Then there's this: Human error is ALWAYS the fault of traps breaking. Set it up right and replace worn parts and it won't happen. It's just not always a priority like standing rigging. I've only had a couple fail, once singlehanded and the only thing I had a decent grip on was a Marstrom tiller extension. Broke the tiller, but I didn't loose the boat. That was a shite day, I also ripped a patch out of a spinnaker that day too. Back to the beach twice, and at one of our worst venues to get in and out of by yourself. Which led to a small hole in the bottom of one of my hulls from a rock. Cascading shitstorms happen to all of us at some point. They've all been my fault though.
| | | Re: Hagar Feb 9?
[Re: ThunderMuffin]
#257293 02/11/13 11:27 AM 02/11/13 11:27 AM |
Posts: 12,310 South Carolina | I'm probably going to jinx myself with this statement - but I've never had a trap system failure. I did once fail to get the ring engaged past the keeper on my harness and fall in because of that (come to think of it, I think Tad was on my boat at the time). Since then, I've cut all the keepers off my Harnesses. You have to stay after them with maintenance and be careful with the rigging. If you think "that might be a problem", fix it.
[Re: ThunderMuffin]
#257296 02/11/13 11:51 AM 02/11/13 11:51 AM |
Posts: 5,525 | Standing rigging can last a life time. Trapeze rigging requires almost constant attention. Why is that?
| | | Re: Hagar Feb 9?
[Re: pgp]
#257297 02/11/13 11:57 AM 02/11/13 11:57 AM |
Posts: 1,152 tampa, fl | Standing rigging can last a life time. Trapeze rigging requires almost constant attention. Why is that? There is a big difference between "can" and "will". That is why the smart money is on replacing your standing rigging on a regular basis!
If your havin girl problems i feel bad for you son I got 99 problems but my beautiful wife ain't one | | | Re: Hagar Feb 9?
[Re: waterbug_wpb]
#257299 02/11/13 12:05 PM 02/11/13 12:05 PM |
Posts: 1,152 tampa, fl | Are spinnaker bridles considered "standing rigging"? Unfortunately not on my boat.
151
guests, and 78
Mod | | Forums26 Topics22,405 Posts267,059 Members8,150 | Most Online2,167 Dec 19th, 2022 | | |
