Page 3 of 3 1 2 3
Re: Hagar Feb 9? [Re: ThunderMuffin] #257320
02/11/13 04:41 PM
02/11/13 04:41 PM
I'd like to re-iterate that it wasn't for lack of maintenance on the boat that caused this, rather a stopper ball that should have been a bit smaller.
So a lack of PROPER maintenance? grin
Re: Hagar Feb 9? [Re: Jake] #257321
02/11/13 04:44 PM
02/11/13 04:44 PM
Greenville SC
bacho Offline
bacho  Offline
Greenville SC
Which is worse?
It happened to me on my first trip into the ocean on my first Hobie 18. My crew dropped off the side, it was an experience that taught me a lesson about life jackets as it became clear to me just how easy it was to lose sight of someone and how long it can sometimes take to double back and pick them up.
Re: Hagar Feb 9? [Re: bacho] #257358
02/12/13 12:53 PM
02/12/13 12:53 PM
Knokke-Heist - Belgium
Gilo Offline
Gilo  Offline
If you think one trap fail sucks....
http://youtu.be/wYFDf0HhOHM
Falcon F16 - BEL666
Boats: TheBoatShop.be
Re: Hagar Feb 9? [Re: ThunderMuffin] #257371
02/12/13 03:55 PM
02/12/13 03:55 PM
SE MI / NE IN
rehmbo Offline
rehmbo  Offline
SE MI / NE IN
Here was my little misadventure last month at Tradewinds. I think I have the dubious honor of being the only sailor to take an unintended swim that weekend. Fortunately, no damage and the water was warm.
http://www.youtube.com/watch?v=RExuf_WlbRs
My trap hook had some kind of spring clip retainer. When I went out, the hook/clip must have been just resting on the edge of the ring. As soon as I put weight on it, splash. Needless to say the clip was removed.
My crew's first instinct with the main sheet wasn't quite spot on either... Later, trying to uncleat the center-sheeted main from in the water was a real PITA.
Jeff R
H18, C2 USA1193
cramsailing.com
crescentsail.com
Re: Hagar Feb 9? [Re: ThunderMuffin] #257377
02/12/13 05:15 PM
02/12/13 05:15 PM
I've never thought about that. Taking the cleat off is the answer there I'd think.
Re: Hagar Feb 9? [Re: Karl_Brogger] #257380
02/12/13 06:07 PM
02/12/13 06:07 PM
First thing I do with a new harness. As long as your bunji system is functioning properly, it keeps upward tension on the dogbone and the keeper isn't necessary. It's more of a liability in my opinion.
Re: Hagar Feb 9? [Re: ThunderMuffin] #257381
02/12/13 07:02 PM
02/12/13 07:02 PM
Yeah, but capsizes are inevitable.
(edit)- I was talking about the mainsheet.
Re: Hagar Feb 9? [Re: Karl_Brogger] #257383
02/12/13 07:10 PM
02/12/13 07:10 PM
Oh....I cleat the mainsheet all the time. I'm wimpy. I adjust it a lot but I do give myself breaks with the cleat. However, I'm johnny on the freakin spot with the uncleating flick at all times.
Re: Hagar Feb 9? [Re: rehmbo] #257384
02/12/13 07:13 PM
02/12/13 07:13 PM
I don't think your crew was going to be able to get to the main sheet before he was sliding down the trampoline anyway - he didn't have many options.
Can't you just reach around the rear beam while standing on the hull that's in the water to uncleat the main?
Re: Hagar Feb 9? [Re: ThunderMuffin] #257385
02/12/13 07:48 PM
02/12/13 07:48 PM
Center sheeting is pretty centered
Re: Hagar Feb 9? [Re: Karl_Brogger] #257387
02/12/13 08:38 PM
02/12/13 08:38 PM
Aaaaa...I see. Crew had hold of the mainsheet before all this began...gotcha.
Re: Hagar Feb 9? [Re: ThunderMuffin] #257388
02/12/13 09:09 PM
02/12/13 09:09 PM
SE MI / NE IN
rehmbo Offline
rehmbo  Offline
SE MI / NE IN
Yeah - I had just transferred the main sheet to Collin (my son) and he hadn't uncleated it yet. First thing he did was drop it when I went trolling for sharks. Kind of a knee-jerk thing he won't do again (I hope).
After I got back to the boat, I could easily release the traveler, but couldn't get enough leverage to release the main while I was bobbing in the water. I ended up climbing up and basically stood on the main sheet reeves between the blocks (is that the right description?) to get close enough to release the main. Didn't want to put any weight on the boom for fear of bending it.
First time with center sheeting. I kinda liked it except in this situation.
Jeff R
H18, C2 USA1193
cramsailing.com
crescentsail.com
Re: Hagar Feb 9? [Re: Gilo] #257408
02/13/13 10:24 AM
02/13/13 10:24 AM
Eastern NC, USA
tshan Offline
tshan  Offline
Eastern NC, USA
Gilo - what happened here? Trapeze shackle at the top give way?
Re: Hagar Feb 9? [Re: tshan] #257505
02/14/13 11:50 AM
02/14/13 11:50 AM
Props to Collin for a nearly perfect crew maneuver - didn't get wet until he stepped off. AND didn't go through the main unlike Tad's little vid at Hagar's smile
And you're little pirouette wasn't bad either. Stick not broken, didn't hurt yourself, and the boat didn't sail too far without you...
Yeah, ditch the keeper on your harness hook. Seems no good comes of that thing. Either hangs you up when trying to get out, or doesn't get you hooked in correctly.
Re: Hagar Feb 9? [Re: ThunderMuffin] #257517
02/14/13 03:06 PM
02/14/13 03:06 PM
SE MI / NE IN
rehmbo Offline
rehmbo  Offline
SE MI / NE IN
Thanks Jay - only concern with his dismount was losing connection with the boat. Had it been much windier, we both woulda been swimming for a while. He was also PO'd for losing his sunglasses. He could see them slowly sinking, but it was either the boat or the glasses - fortunately he made the right choice smile
Jeff R
H18, C2 USA1193
cramsailing.com
crescentsail.com
Page 3 of 3 1 2 3
0 registered members (), 794 guests, and 26 spiders.
