Re: mesh or vinal tramp??? [Re: scboy] #257855
02/27/13 08:27 AM
02/27/13 08:27 AM
brucat Offline
brucat  Offline
Only problem with one-piece tramps is that there are far less places to grab when you're in the water under the boat. Learned that under a Hobie Wave (Classic/cartop model)...
Re: mesh or vinal tramp??? [Re: brucat] #257859
02/27/13 09:38 AM
02/27/13 09:38 AM
srm Offline
srm  Offline
The other problem with a 1-piece tramp on a Hobie 14/16 is that you can't get the tramp tight enough to take the slop out of the frame. You need center lacings if you want a tight boat.
sm
Re: mesh or vinal tramp??? [Re: srm] #257873
02/27/13 01:46 PM
02/27/13 01:46 PM
M
MN3
MN3
M
wasn't a problem with my TheMightyHobie18:
Bias Cut
Most trampolines with boltrope track on 3 sides are bias cut which means that the fibers of the mesh run at a 45 deg. angle to the sides. This eliminates the need to lace from 2 sides since the fibers pull at the adjacent sides from the lacing side and stretch the entire surface tight. This also increases the holding power of the grommets since all the fibers of the mesh can wrap around the reinforcement.
http://www.multihullnets.com/BeachCat/bcinfo.asp
sm
Re: mesh or vinal tramp??? [Re: scboy] #257928
02/28/13 02:31 PM
02/28/13 02:31 PM
maui
jollyrodgers Offline
maui
the topic is well covered now, but if i may add my opinion;
From my experience water doesn't pool on the tramp of the classic H16. It's convex in shape. The solid vinyl blocks the spray from underneath. People used to put strips of plastic in the lacing to block the spray that could get thru that gap.
As for tipping over backward on a H14; you as positioned too far aft during your back-up. The art of tacking a 14 is prolly long lost by now, but i can assure you that there have been many worlds and nats. held in rough ocean conditions where the top guys were getting around the course w/o tipping over.
Re: mesh or vinal tramp??? [Re: jollyrodgers] #257935
02/28/13 04:41 PM
02/28/13 04:41 PM
I thought the strip in the lacing was to prevent the mainsheet from falling through.
0 registered members (), 477 guests, and 26 spiders.
