Dagger Board Height Control #259870
05/27/13 05:47 PM
05/27/13 05:47 PM
Punta Gorda, FL
jkkartz1 Offline OP
jkkartz1  Offline OP
Punta Gorda, FL
Has anyone adapted the AC45/AC72 dagger board vertical adjusting systems for smaller boats? It sure seems better than sending the crew to the bottom of the boat to adjust them.
Re: Dagger Board Height Control [Re: jkkartz1] #259871
05/27/13 06:55 PM
05/27/13 06:55 PM
Scarecrow
Scarecrow
Um the AC45s are adjusted at the board basically like ours.
The AC72 use hydraulics and goffee grinder pumps to adjust theirs. I can't see that catching on on a beach cat.
Lots of beach cats have the control line cross over so you can at least raise the board from the wrong side.
Re: Dagger Board Height Control [Re: jkkartz1] #259874
05/28/13 03:14 AM
05/28/13 03:14 AM
Search for "upf*cker".
Re: Dagger Board Height Control [Re: jkkartz1] #259878
05/28/13 07:14 AM
05/28/13 07:14 AM
we do something similar - a lot of a-cats and many F16/18 boats have a hole drilled mid-way through the daggerboard. A line or nylon strap goes through that hole and is knotted on the end. It is dimensioned such that the hole/line is still in the hull trunk when the board is fully down. You just have to pull the line/strap and the board will come up to about the halfway point.
Re: Dagger Board Height Control [Re: jkkartz1] #259884
05/28/13 10:32 AM
05/28/13 10:32 AM
Solomon's Island, MD
samc99us Offline
samc99us  Offline
Using this system over the weekend it has its limits, raising the weather board from the wire is an issue for example. Having a monkey crewing for you really helps. I talked to Tripp a bit about what they do, essentially there is a block on the side stays above the max board height. A line goes from the top of the board, up through the side stay block, back down to a turning block on the bottom of the stay, across the boat and repeated on the other side. A 2:1 system may be placed in the loop, all similar to the AC45 system.
Scorpion F18
0 registered members (), 274 guests, and 50 spiders.
