Spinnakers #260579
06/21/13 11:39 PM
06/21/13 11:39 PM
Portarlington, Victoria
Haz_Mann Offline OP
Haz_Mann  Offline OP
Hi all,
This might seem like a ridiculous question, but just for interest sake, is there a minimum size limit on spinakers, understanding they must be assymetrical etc. Just interested to know.
Thanks
Harry
Harry Mann
Mosquito 1720
"2 B ADVISED"
Re: Spinnakers [Re: Haz_Mann] #260590
06/22/13 09:27 PM
06/22/13 09:27 PM
Matt_Stone Offline
Matt_Stone  Offline
Go into the website, under documents, and click on building rules, its on the last page
Matt
Need and spin gear you can talk to me
Re: Spinnakers [Re: Haz_Mann] #260594
06/23/13 08:01 AM
06/23/13 08:01 AM
Haz_Mann Offline OP
Haz_Mann  Offline OP
Thanks matt
Might be in touch
Thanks
Harry
Harry Mann
Mosquito 1720
"2 B ADVISED"
Re: Spinnakers [Re: Haz_Mann] #260751
06/28/13 07:11 AM
06/28/13 07:11 AM
Port Hedland
Beckit 1824 Offline
Beckit 1824  Offline
Port Hedland
If you are out there Gary, at Sauna Sail you were explaining on your spinnaker you included some bungy in the set up, so that when you put it away it also took the slack out of the spin sheets to unclutter the deck. I have just ordered a spinnaker and was curious as to whether you could explain it again please.
Luke
Re: Spinnakers [Re: Beckit 1824] #260782
06/29/13 06:51 AM
06/29/13 06:51 AM
thricebitten
thricebitten
Hi Luke,
I was hoping we had a photo of it on the spinnaker rigging page but no such luck (if you have a photo Tim please post it).
I will try to explain but as allways a picture is worth a thousand words. So you tie about .5m of shockcord to the clew of spin and on the other end tie a plastic ring (or anything similar that will not attack the spinnaker) you then pass the return cord through this before putting it through the return cord patches.
When hoisted the return cord should be long enough to not stretch the shockcord, but not have any slack.
The idea is that it pulls the clew towards the return patches which go in the chute first, this means the sheets get pulled deeper in to the chute, taking up the slack on the tramp (if you have centre boom sheeting) or most of the slack for others. Just stops ropes and blocks from hanging in the water more than they have to. As I allways say, it's important to have everything sorted when one up, as nobody to go and tidy up while you are on trap, like a crew boat.
Re: Spinnakers [Re: Haz_Mann] #260786
06/29/13 07:59 AM
06/29/13 07:59 AM
Port Hedland
Beckit 1824 Offline
Beckit 1824  Offline
Port Hedland
Excellent, thanks Gary. All understood. Just some light shock cord?
I get tangled up at the best of time. Helped another guy buy Peter Foulsoms old mozzie today so another boat on the water. Spinnaker on order. Got a fiberglass pole from Peter also and just have to wait 10 weeks for Matt to finally make a chute, and then make another in the right colour.
Then I just have learn how to use it.
Re: Spinnakers [Re: Haz_Mann] #260798
06/29/13 06:30 PM
06/29/13 06:30 PM
Haz_Mann Offline OP
Haz_Mann  Offline OP
Gary or Luke, do you know anyone that might happen to have an old kite hanging around? Not putting one on just yet but want to start collecting bits and pieces so I have everything when I'm ready. I've already spoken to matt about chute mouth etc.
Harry
Harry Mann
Mosquito 1720
"2 B ADVISED"
Re: Spinnakers [Re: Haz_Mann] #260800
06/29/13 08:56 PM
06/29/13 08:56 PM
Port Hedland
Beckit 1824 Offline
Beckit 1824  Offline
Port Hedland
Not off mind. They are still pretty new and expensive so no 'second generation' ones yet. Gary might know someone.
Re: Spinnakers [Re: Haz_Mann] #260808
07/01/13 01:56 AM
07/01/13 01:56 AM
Matt_Stone Offline
Matt_Stone  Offline
i have searched around, and no 2nd hand ones as yet!
Re: Spinnakers [Re: Haz_Mann] #260809
07/01/13 02:01 AM
07/01/13 02:01 AM
Haz_Mann Offline OP
Haz_Mann  Offline OP
Rang around a bit today and new ones are around $900.. I haven't found anything yet either
Harry Mann
Mosquito 1720
"2 B ADVISED"
Re: Spinnakers [Re: Haz_Mann] #260810
07/01/13 03:32 AM
07/01/13 03:32 AM
Port Hedland
Beckit 1824 Offline
Beckit 1824  Offline
Port Hedland
Due to their lightness and the material, I reckon you would want a pretty good second hand one too, or it wouldn't work right. Might be worth building the rest of it and biting the bullet when you are ready to use it.
Luke
Re: Spinnakers [Re: Beckit 1824] #260936
07/04/13 03:38 AM
07/04/13 03:38 AM
thricebitten
thricebitten
Hi Luke,
tell Matt not to cut the holes for the bridle so big. At the Sauna Sail I ended up with the spinnaker getting stuck in the cut out at the side when raising the spinnaker at one stage.
Re: Spinnakers [Re: Haz_Mann] #260943
07/04/13 09:37 AM
07/04/13 09:37 AM
Port Hedland
Beckit 1824 Offline
Beckit 1824  Offline
Port Hedland
Hey Matt, don't cut the holes for the bridle so big. I don't want my spinnaker getting stuck in the cut out at any stage. Bloody queenslanders aye
Re: Spinnakers [Re: Haz_Mann] #260957
07/04/13 10:08 PM
07/04/13 10:08 PM
Matt_Stone Offline
Matt_Stone  Offline
Roger, thanks for the feed back
0 registered members (), 649 guests, and 178 spiders.
