Page 3 of 6 1 2 3 4 5 6
Re: Cat Refinishing--What's your take? [Re: JACKFLASH] #260770
06/28/13 02:10 PM
06/28/13 02:10 PM
Solomon's Island, MD
samc99us Offline
samc99us  Offline
Sloan you've basically solid me already. Is this the product you are recommending? http://www.jamestowndistributors.com/userportal/show_product.do?pid=2330
For repairs do you still suggest spraying vs. rolling?
Scorpion F18
Re: Cat Refinishing--What's your take? [Re: JACKFLASH] #260784
06/29/13 07:26 AM
06/29/13 07:26 AM
Rickh Offline
Rickh  Offline
I have done several keel boat bottoms with performance epoxy, and several years ago did my A Cat hulls. It buffs out like glass with wool pad and water-after wet sanding around 1500. Sand as soon as possible after application-its a really hard finish after a few days. Definitely spray, and repairs are almost invisible.
Re: Cat Refinishing--What's your take? [Re: JACKFLASH] #260792
06/29/13 11:41 AM
06/29/13 11:41 AM
Roanoke Island ,N.C.
Team_Cat_Fever Offline
Ian and Rick,
Is the stuff in Sam's link the right stuff?
Isak Dinesen
E. B. White
Re: Cat Refinishing--What's your take? [Re: Team_Cat_Fever] #260802
06/30/13 01:32 PM
06/30/13 01:32 PM
JACKFLASH Offline OP
I have also used the Interlux performance epoxy on underside of a J24. It is great stuff. Good luck getting GT300 sticker or the like to stick once your sailing. The VC Epoxy has a teflon aditive in it.
Collin Casey
Re: Cat Refinishing--What's your take? [Re: JACKFLASH] #260826
07/01/13 03:01 PM
07/01/13 03:01 PM
Anacortes
Sloansailing Offline
Anacortes
Yes that is the stuff. Like Rick I've done lots of boat bottoms with the stuff, as well as the rudders and boards on my Tiger. Always been very happy with the result. Definitely spray it on, its not worth it to roll it. Apply lots of thin coats within the re-coat timeframe. Then as Rick says wet sand it AS SOON as you can. It gets hard as a rock after full cure and if you wait too long it will take FOREVER to sand it down to a smooth finish. Try using an air powered jitterbug sander for the first couple of wet sanding runs with 220-400 grit, that will save you a lot of time hand sanding when you move to 600 and up.
For repairs just prep it and spray as you would gelcoat, then wet sand and polish.
Sam99 get in touch with Bobby Muller at Muller Marine in Annapolis if you want someone to do it for you. You won't be disappointed. Tell him I sent you smile
Anacortes Rigging.com
Rigging and Yacht Services
Re: Cat Refinishing--What's your take? [Re: Sloansailing] #260827
07/01/13 03:24 PM
07/01/13 03:24 PM
Portland, Maine
ThunderMuffin Offline
Portland, Maine
Bah
Only available in white frown
Re: Cat Refinishing--What's your take? [Re: ThunderMuffin] #260828
07/01/13 03:48 PM
07/01/13 03:48 PM
Williamston, sc
h18catsailor Offline
Williamston, sc
Bah
Well....you could finally "decide" grin
David Strickland
Hobie 18
HEAVY air crew on a J22
Re: Cat Refinishing--What's your take? [Re: h18catsailor] #260829
07/01/13 04:00 PM
07/01/13 04:00 PM
Portland, Maine
Portland, Maine
Bah
Well I had... gun metal grey.
Re: Cat Refinishing--What's your take? [Re: Sloansailing] #260832
07/01/13 04:44 PM
07/01/13 04:44 PM
samc99us Offline
samc99us  Offline
I'll talk to Bobby and see what he can do for me, he's a 5 minute walk from my place. My bottom is in pretty good shape after all the hours of sanding, gelcoating, sanding, gelcoating then polishing I did back in April. Might want my boards re-faired before nationals but I can sand and happen to know where a paint booth is hidden smile
Scorpion F18
Re: Cat Refinishing--What's your take? [Re: ThunderMuffin] #260835
07/01/13 09:10 PM
07/01/13 09:10 PM
Anacortes
Anacortes
Bah
Pigment
Re: Cat Refinishing--What's your take? [Re: Sloansailing] #260836
07/02/13 07:02 AM
07/02/13 07:02 AM
Bah
Pigment
unpredictable results.
Re: Cat Refinishing--What's your take? [Re: Jake] #260838
07/02/13 09:54 AM
07/02/13 09:54 AM
boat wrap, perhaps?
Re: Cat Refinishing--What's your take? [Re: waterbug_wpb] #260839
07/02/13 10:02 AM
07/02/13 10:02 AM
boat wrap, perhaps?
I've been trying to find a few folks interested in this so I can justify buying the material to produce several hull wraps....the stuff isn't that cheap and you have to buy in bulk. It's not something I really care to get into from a business perspective, but I hate to buy $1,200 in materials to just do my boat.
Re: Cat Refinishing--What's your take? [Re: JACKFLASH] #260840
07/02/13 10:13 AM
07/02/13 10:13 AM
Greenville SC
bacho Offline
bacho  Offline
Greenville SC
Jake, what's the shelf life of the stuff?
Re: Cat Refinishing--What's your take? [Re: JACKFLASH] #260841
07/02/13 10:20 AM
07/02/13 10:20 AM
samc99us Offline
samc99us  Offline
Jake hit me up I'm interested.
Scorpion F18
Re: Cat Refinishing--What's your take? [Re: Jake] #260842
07/02/13 10:37 AM
07/02/13 10:37 AM
Anacortes
Anacortes
Bah
Pigment
What kind of pigments did you try? I've never done it, always just applied it white. I would think an epoxy pigment (like the West System black pigment) if mixed thoroughly would work.
Re: Cat Refinishing--What's your take? [Re: JACKFLASH] #260843
07/02/13 11:05 AM
07/02/13 11:05 AM
samc99us Offline
samc99us  Offline
I'm with Jake on the pigment. Tried it once (West Systems Green), granted on a lighter weight part where using lots of pigment wasn't an option, and ended up with splotches of pigment strewn throughout the part, it looked ugly. Black may do OK since it's black.
Scorpion F18
Re: Cat Refinishing--What's your take? [Re: JACKFLASH] #260846
07/02/13 11:32 AM
07/02/13 11:32 AM
Sounds like you didn't mix it thoroughly. Not a pigment problem. I can't vouch for epoxy based pigments ,but they work fine in gel-coat as long as you play by the rules.
Isak Dinesen
E. B. White
Re: Cat Refinishing--What's your take? [Re: bacho] #260849
07/02/13 12:10 PM
07/02/13 12:10 PM
They say 2 years on the shelf. The print life (before significant signs of fading) is nine years. The recommended interval of application is about 5 years (before it becomes a real pain to remove). There is an intermediate level of material with a 5 year print life...but typically these are harder to remove (I really don't know in this case)
Re: Cat Refinishing--What's your take? [Re: Jake] #260854
07/02/13 01:13 PM
07/02/13 01:13 PM
Portland, Maine
Portland, Maine
What is the durability? Meaning, how would it take beach landings?
0 registered members (), 246 guests, and 36 spiders.
Posts267,059
