| Re: Nacra 5.8; adding a boom, losing a boomlet
[Re: ileestma]
#261471 07/17/13 06:03 PM 07/17/13 06:03 PM |
Posts: 1,383 Kingston SE South Australia | Finally, since we're on the topic, and while i have your attention, what about adding a "blade" jib in the mix too. Namely, one that is self-tacking, and non overlapping. Will this cause "balance" problems? I've heard i can actually obtain roughly the same sq. ft. of area by extending the leech, which would be in keeping with the high-aspect theme of these potential rig changes. thoughts?
My thoughts on the jib are that all the bighead sails have a relatively small jib that just shapes the wind into the slot so you really just need to match your sail shape with your jib shape, the Taipan 5.7's went to self tackers by dropping the tack to the top of the spin pole using a stainless steel rod to give them a longer jib with roughly the same area, I'm not sure about lifting your hounds or putting your jib higher than the hounds. The F18 mast is only 20cm shorter than the 5.8 so you could try some F18 sails as a starting point and see how they feel and see if the mast holds the leach up. Couple of other things to consider, the 5.8 mast is designed to loosten your diamonds as the wind gets higher allowing the mast to depower the rig by bending into the slot in gusts. On a reach the 5.8 is the most fantastic boat I've been on, I've got video of me on a reach jumping over and through waves in over 20 knots on the 5.8 and it's totally controlled, I've never pitchpoled it on a reach but on downwind course's I've gone in big time. I run a F18 spin on my 5.8
[Re: yurdle]
#261473 07/17/13 08:11 PM 07/17/13 08:11 PM |
Posts: 337 Arizona | I would estimate that I had seen the 5.8 mast bend off +5-6 feet under kite and double trapped. Holy.. -____ Yea, an abrupt turn above the hounds. Maybe pushing 30*. Jeff, you have to see some stuff up there that looks pretty scary once in a while when you run spin, right? I had a spin and sq top on a 5.7 also. I think it was a lighter mast section than the 5.8 & 6.0. Saw that thing bend off pretty bad also. Close to the 5.8, but I usually ran less weight on the trapeze and couldn't push as hard as Manny with his 5.8.
Auscat MKV 444 A class NACRA I-20- 440/CATHATKA | | | Re: Nacra 5.8; adding a boom, losing a boomlet
[Re: ileestma]
#261475 07/18/13 12:05 AM 07/18/13 12:05 AM |
Posts: 1,383 Kingston SE South Australia | I mainly saw the wild mast with my old style fat spin that fluffed around as soon as I got going properly. The F18 spin behaves nicely and doesn't do such dramatic pulling to the side. My Taipan 5.7 was set up beautifully when I got it and I just pulled the spin up and went double trapped at 185kg crew weight, I haven't got to that stage yet with the 5.8
[Re: JeffS]
#261486 07/18/13 08:29 AM 07/18/13 08:29 AM |
Posts: 36 | [quote=ileestma] The F18 mast is only 20cm shorter than the 5.8 so you could try some F18 sails as a starting point and see how they feel and see if the mast holds the leach up.......... I run a F18 spin on my 5.8 20 CM?!? Well, shoot. Sounds like my best route is buy a used F18 main and chute. That way i could save $$$$ by buying used as opposed to new/custom. the only question is will it look like hell, e.g. boom is way too high. I can't get the thing lengthened either because it's tri-radial construction right? As for the chute, i have to add a pole and halyard anyways, i'll just place them wherever i have to in order to make the chute work. bada bing bada boom! The jib, i'm afraid WILL need to be custom however... Am i on the right track here? this way i'm not spending the same money as a used F18, but still getting a major modernization of the rig..... or will this route yield a frankensteined POS? | | | Re: Nacra 5.8; adding a boom, losing a boomlet
[Re: ileestma]
#261500 07/19/13 12:08 AM 07/19/13 12:08 AM |
Posts: 1,383 Kingston SE South Australia | It won't be a POS but will be a frankenboat, if you sail your boat as is around 20kts you will feel the controllable power in it, I don't know how the boat will react to having a third more drive up high with a square top but I can guess. A Tornado main is only slightly longer so perhaps have a go with the rig of one of those
178
guests, and 37
Mod | | Forums26 Topics22,405 Posts267,059 Members8,150 | Most Online2,167 Dec 19th, 2022 | | |
