by Karl_Brogger. 12/29/24 05:14 PM
Page 9 of 19 1 2 7 8 9 10 11 18 19
Re: F85SR Concept Boat [Re: waynemarlow] #268320
01/07/14 11:14 PM
01/07/14 11:14 PM
Try Flying Offline
Try Flying  Offline
Wayne you mention air leaks helping with your setup on larger projects....IMHO air leaks are bad. This means you will continue to draw out epoxy and also "infuse" your laminate with air = not good.
I'd suggest you make a large air receiver tank prior to your pump and also have an inline filter otherwise you will be drawing epoxy vapour into you piston pump.
Re: F85SR Concept Boat [Re: phill] #268349
01/08/14 01:00 PM
01/08/14 01:00 PM
waynemarlow Offline
waynemarlow  Offline
Yup had a large receiver and inline filter in the line, by air leaks I meant minimum that we could find, the pump was really working hard. The new project is in a mould with very flat surfaces to seal and I think we could almost get to the stage where there is no leaks( if that is really possible ) And I worry that we may almost lock the pump hence my question of introducing some form of electrics to control the pump.
Thanks for advice though and I will look up your recommendations
Re: F85SR Concept Boat [Re: waynemarlow] #268361
01/09/14 05:27 AM
01/09/14 05:27 AM
phill Offline OP
phill  Offline OP
I've finished laminating the inside of the stbd hull side.
I have worked out that if I can remove the strong back and set the frames directly on the concrete floor I will have just enough room
to get the port side back into the work area and set it on top of the stbd side ready for joining.
The concrete floor is very flat and very level but I will check the level of the frames prior to joining.
Once the port side is sitting on top, in that position I will be able to lift it high enough to create a 300mm gap
with the winch setup mentioned earlier.
Hopefully the capacity to lift the side up and down will help me align the second half of the Bulkheads that are yet to be fitted to the stbd side.
This should be a very interesting phase of the build.
BTW:- I'm still enjoying the work as much or even more than when I first started.
Re: F85SR Concept Boat [Re: phill] #268448
01/12/14 11:24 PM
01/12/14 11:24 PM
phill Offline OP
phill  Offline OP
After carefully removing the strong back and lowering the frames down onto the concrete floor
I got some friends around to help me move the port side of the main hull into the work area and
place it on top of the stbd side so I can prepare the two for joining.
Now I have them both in place my winching system should enable me to do all the rest myself.
A couple pics below. Note I only remove the peel ply when I have to. It doesn't look much but sure
keeps the surface beneath clean and free from contaminants.
The joining.jpg (1262 downloads)
The joining 2.jpg (1215 downloads)
Re: F85SR Concept Boat [Re: phill] #268776
01/25/14 05:12 AM
01/25/14 05:12 AM
phill Offline OP
phill  Offline OP
I got myself a water level to check all the frame levels to make sure everything was straight and without twist.
It turns out the concrete floor was not quite as true and flat as I expected over its full length. So I made up a simple means of adjustment.
Now each frame is set up so it is the correct level with the greatest variation being under 2mm.
PIc shows the winch lifting the port side up so I can easily work on B/Hs that I bogged into place when the two sides were together.
The only exception being the B/H that goes in under the **** floor.
I made up a couple of spacers when fitting the b/h half in the port side. Using them should ensure the two halves line up when joined.
levelling frames.jpg (1128 downloads)
Under cockpit bh.jpg (1121 downloads)
lifting up port half.jpg (1139 downloads)
Re: F85SR Concept Boat [Re: phill] #269437
02/17/14 04:15 AM
02/17/14 04:15 AM
phill Offline OP
phill  Offline OP
I decided to paint the bottom of the hull before installing the
second half of the **** floor.
When the last half of the floor went in I made sure it lined up perfectly.
The wooden cleats ensured this.
under the cockpit.jpg (1020 downloads)
cockpit floor.jpg (1059 downloads)
Re: F85SR Concept Boat [Re: phill] #269466
02/18/14 02:27 AM
02/18/14 02:27 AM
phill Offline OP
phill  Offline OP
Time to get rid of the mould frames.
I used 2 x2inch webbing straps.
The black one on the trailer winches in the middle of the hull took nearly all he load. The orange one up front allowed the hull to slide over it as it rolled.
Mark came round to give me a hand. He is in the pic below.
This is the guy that machined the folding mech on the back wall, mould frames and the rudder plug. It's good to know people who take real pride in what they do.
Once upright the air powered in line sander is a must.
It takes off any flairing towards the edges of the foam to make a really fair surface.
lifting the hull.jpg (1016 downloads)
lift and roll.jpg (1038 downloads)
in line sander.jpg (1047 downloads)
Re: F85SR Concept Boat [Re: phill] #269467
02/18/14 02:45 AM
02/18/14 02:45 AM
phill Offline OP
phill  Offline OP
With the main hull out of the frames and upright its time to get the stbd half ready to be laminated.
The plan is to do the cabin top, foredeck and side first. to this end I just filled these rebates.
I'm keeping the sharp corners between the cabin top, sides and hull.
My reasoning is if I can make it look fair along these sharp corner by sanding the flat panels leading up to them once I round off the corners it will look spot on.
Just a theory I have- see below. Should look even better once I round the corners.
Here is a shot over the ****. I have made the longest cabin allowed for and the **** it still huge.
Note I still have to finish trimming the cabin roof and side back to the companionway bulkhead.
I forgot to mention that I have peel ply in several diff colours. I don't take it off until I have to .
This makes it look a bit shabby until removed but it has saved me twice big time.
Once inside taping in bulkheads I tipped over a pot of resin not noticing until it was emptied all through the hull.
I mopped up what I could and the rest will come out with the peel ply.
The other was when painting the hull under the **** I tipped over the paint onto a section of the hull that I needed to glass tape.
I just pulled up the peel ply to give a clean surface for bonding.
Both saving a lot of time sanding.
stbd side pre lam.jpg (1030 downloads)
stbd side pre lam 2.jpg (1001 downloads)
Re: F85SR Concept Boat [Re: phill] #270258
03/15/14 04:00 AM
03/15/14 04:00 AM
phill Offline OP
phill  Offline OP
The stbd hull side has been laminated in two parts.
The end of **** forward and then back.
In both cases I weighed everything that went in and out and in both cases
the resin content worked out at 46.5% of the total laminate weight. Below are a couple of pics.
Stbd side forward section under vacuum.
In this pic I'm removing the absorption fabric and excess resin. The peel ply is left in place for now.
Stbd Laminate.jpg (864 downloads)
Re: F85SR Concept Boat [Re: phill] #270341
03/18/14 05:41 AM
03/18/14 05:41 AM
phill Offline OP
phill  Offline OP
A couple days back I laminated some uni and plain weave along the keel for added protection for beaching and trailering.
My original intention was to do this without a vacuum until I realised there was 3.5kg of glass involved.
With that much I decided it was probably worth vacuuming.
Once again I did the maths after the work and again got a 46.5% resin content in the laminate.
Pic below.
keel lamination.jpg (849 downloads)
Re: F85SR Concept Boat [Re: phill] #270802
03/27/14 09:13 PM
03/27/14 09:13 PM
E
ed. Offline
ed.  Offline
E
Hi Phil,
How do you get the asorbption fabric to lift off of the peel ply, do you have another layerof perforated release film, or is it due to the fabric itself?
The fluffy I'm using is pretty well stuck to the peel ply, and it all comes off as one.
Re: F85SR Concept Boat [Re: ed.] #270806
03/28/14 01:26 AM
03/28/14 01:26 AM
phill Offline OP
phill  Offline OP
Ed,
There is a layer of perforated film between.
The holes must have been poked through by a machine, very small and very close together, but one side is just a little more rough than the other side.
It can be very hard to tell which is the smooth and rough side because can't always feel it with your fingers tips.
When it is like this I rub it against my lips to work it out.
Right near the end of the project I found out that if it is laid on the peel ply with the smoother side down it will stick to the wet resin really well and the rougher side will be enough to hold the absorption fabric in place on vertical surfaces.
Also this way around the perforated film comes off the peel ply after cure very easily with the absorption fabric. The other way around and it won't stick and hold he absorption fabric so I had to come up with other ways of getting everything to stay in place. Also it stays with the peel ply
when the absorption fabric is removed.
Had me going for a while trying to work out why some sessions were just so much easier than others when it came to placing the consumable layers and removing them after. When I bought the laminating materials I had to buy a full roll of this perforated film and that was 1000 metres. Luckily it was quite cheap.
Re: F85SR Concept Boat [Re: phill] #270859
03/29/14 12:20 AM
03/29/14 12:20 AM
K
KATRAT Offline
KATRAT  Offline
K
For those that are interested here are some videos of my F85SR sailing.
http://www.youtube.com/playlist?list=PLrBsmeznqOvzKiAz4qFy3j5F7qXo9VbTF
This boat is for sale if you are interested. Can be shipped anywhere.
Glynn Thomas
Subic Bay, Philippines
glynnthomas72(at)yahoo(dot)com
Re: F85SR Concept Boat [Re: KATRAT] #270889
03/31/14 04:41 AM
03/31/14 04:41 AM
phill Offline OP
phill  Offline OP
Glynn,
The boats that I have seen made by Multihulls Direct have an outstanding, and I mean outstanding, quality of finish.
At that price it should be snapped up in a heartbeat.
All the best ,
Re: F85SR Concept Boat [Re: phill] #271224
04/08/14 02:27 AM
04/08/14 02:27 AM
phill Offline OP
phill  Offline OP
I cut the anchor well, then two coats of resin into the section that would be out of sight once the floor went in. When I was building the hull halves I built into them a couple of supports on the sides for the anchor well floor. I just used some glass tape and foam left over from the beam flanges.
The pics below pretty much show how it is.
I made sure I put in really good fillets in the corners to make sure mud does not sit in them and is easily flushed out.
The foam where the drain holes have been drilled was first removed and replaced with a glue mix (resin and microfibre).
The holes then drilled through the glue mix and outer laminate. You can just see them in the corners in this pic.
Anchor well 1.jpg (990 downloads)
anchor well 2.jpg (990 downloads)
anchor well floor 1.jpg (927 downloads)
Re: F85SR Concept Boat [Re: phill] #271525
04/17/14 05:08 AM
04/17/14 05:08 AM
phill Offline OP
phill  Offline OP
My grand plan is to work from the bow back doing the little projects required to finish the main hull. to this end I really need to work out what I'm doing about the spinnaker pole and the socket it fits into.
The spec for the pole is a min dia of 90mm. This is a bit of a problem given the way that I wanted to make the pole. It is even more of a problem for the socket the pole has to fit into. To solve the socket problem I thought I'd have a go at making a collapsible mandrel and make the socket around it.
The only tube that was around 90mm was storm water at 88.9mm.
I decided I could use this to make a collapsible mandrel for the socket and also the mould for the actual pole itself (talk about pole mould later)
The mandrel was made by turning up some 20mm thick ply wood to fit neatly inside the stormwater pipe. 4 discs of ply were made. A section 600mm long of pipe was split lengthways with my multitool. This was so I could pass one side of the split inside the other to help the mandrel collapse. The ply discs were to stop this from happening until they get removed at the end.
Another section of pipe was split so it could be fitted over the first split section. This created a gap of around 13mm between each side of the split. A section of pipe was cut to fill the gap but there was still a gap the same as the width of the cutting blade in my multi tool. This small gap was filled by lighting a candel and letting the melting wax do the job. The excess was cut away with a box cutter. Se pic.
Some threaded rod was used an an axle through the ply discs
to help rotate the mandrel. A nut was welded on the rod and a plate to screw to one of the ply discs to help while the carbon was wound on , (ratchet spanner) and later to spin to help consolidate the layup (with cordless drill).
Some pics follow that may help.
Spi pole 1 Mandrel.jpg (836 downloads)
Spi pole 4 socket.jpg (838 downloads)
Spi pole 5 socket.jpg (836 downloads)
Re: F85SR Concept Boat [Re: phill] #271526
04/17/14 05:17 AM
04/17/14 05:17 AM
phill Offline OP
phill  Offline OP
A couple pics of the socket after it has been removed from the mandrel.
You can see the beginnings of the mould for the spinnaker pole in the background. I'll explain what I'm up to with that when I'm a little further along the track.
Spi pole 6 socket.jpg (856 downloads)
Spi pole 8 socket.jpg (822 downloads)
Re: F85SR Concept Boat [Re: phill] #272430
05/19/14 04:32 AM
05/19/14 04:32 AM
Curious minds are interested in learning what is currently going on in your workshop Phil grin
Re: F85SR Concept Boat [Re: phill] #272567
05/21/14 05:35 AM
05/21/14 05:35 AM
phill Offline OP
phill  Offline OP
Rolf,
I've been busy just haven't done much updating.
The spinnaker pole socket now has the carbon fore stay fitting in place.
I won't fit it to the main hull until the pole is made as this will help me line it up along the centerline and get the right angle to the WL.
The landing has been made for the foredeck hatch to give a flat surface to mount it in the curved foredeck. I didn't like the hatch I bought so have ordered a lower profile hatch from NZ. I hope to use the original hatch as an escape hatch. So the foredeck now has a hole in it that I can pass stuff through when working inside.
The mould for the spinnaker pole and boom is finished and I have sourced a roll of Lay Flat Tubing (polypropylene) and a device to seal the ends so I can make the cylindrical bag to inflate to compact the layup in the mould. I'm just waiting on the delivery of some carbon that I want to include in the layup.
I have just had a delivery of some parts that I need to make the carbon anchors for the screacher and spinnaker on the pole when it is made.
Mark has machined the foam blanks for my rudder and I have one complete layer of uni and twill on each foam half to make them really stiff . All done vacuumed to plate glass to ensure they are true.
All had a 200gm layer of glass laminated on C/L before machining to hold the foam when it get really thin and give a really good trailing edge. They have been glued together and the HD insert glued in place.
I have made a glass flange in the main hull to support the forward bunk. First went in some formwork to make a mould all covered in packing tape so it would release the glass.
Today I cut out the foam for the forward berth and it has been laminated and currently under vacuum.
I do have some pics and will post them when projects are getting close to being finished.
Still much to do and having fun along the way.
Re: F85SR Concept Boat [Re: phill] #272583
05/21/14 08:34 AM
05/21/14 08:34 AM
You are really putting the hours into this project!
Was the Lay Flat Tubing expensive, and do you have any leads on where to get those? I tried the same thing with both vinyl plastic and old firehoses put both had their issues smile
Thanks a lot for the update!
0 registered members (), 199 guests, and 78 spiders.
Posts267,059
