by Karl_Brogger. 12/29/24 05:14 PM
Page 135 of 202 1 2 133 134 135 136 137 201 202
Re: AC72 Oracle Team USA Spaceship has landed [Re: bacho] #264834
09/24/13 09:35 AM
09/24/13 09:35 AM
Solomon's Island, MD
samc99us Offline
samc99us  Offline
Size doesn't matter so much with foils once you're above a certain point.
Cavitation happens on the part of the foil that is most highly loaded and doesn't spread under steady-state conditions. You could ventilate the foil as a result of cavitation if the boats ride height changed dramatically.
Scorpion F18
Re: AC72 Oracle Team USA Spaceship has landed [Re: bacho] #264836
09/24/13 09:59 AM
09/24/13 09:59 AM
V
Ventucky Red Offline
V
Originally Posted by bacho
Airplane wings are designed to stall in particular areas first. I guess these foils are rather small for that.
If the horizontal surface cavitated, would the problem be limited to that area? Would it be possible for that to immediately ventilate the rest of the foil?
I don't know if it is a design thing or it is just the way it happens, but many aircraft wings will stall at the wing root first hence the areolons being outboard to still have authority to control the aircraft.
Re: AC72 Oracle Team USA Spaceship has landed [Re: brucat] #264837
09/24/13 10:07 AM
09/24/13 10:07 AM
Originally Posted by brucat
If the foil cavitates, won't the boat just slow down?
sorry,.. was just re-stating what was already said above...
Re: AC72 Oracle Team USA Spaceship has landed [Re: bacho] #264838
09/24/13 10:19 AM
09/24/13 10:19 AM
As Sam mentioned, the cavitation will start small on a small section of the foil where it is creating the most lift (vacuum). If speed continues to grow, the cavitation will spread. In this case, the cavitation will limit the lift of the foil and start to slow the boat down as it tries to maintain foiling (or the hull touches the water). It probably wouldn't be very dramatic.
Re: AC72 Oracle Team USA Spaceship has landed [Re: Ventucky Red] #264839
09/24/13 10:20 AM
09/24/13 10:20 AM
I was going to ask why the cavitation started where it did near the outer edge of the foil rather than the base where it attaches to the vertical surface.
would the rake angle of the leading edge have anything to do with that?
Would an inverse rake angle help or hurt? Let's assume nothing in the water would get hung up on it smile
Re: AC72 Oracle Team USA Spaceship has landed [Re: P.M.] #264842
09/24/13 10:50 AM
09/24/13 10:50 AM
Greenville SC
bacho Offline
bacho  Offline
Greenville SC
I envision the boats flipping end over end, breaking into 100 pieces and at least one fireball. Much more exciting that way.
Re: AC72 Oracle Team USA Spaceship has landed [Re: waterbug_wpb] #264844
09/24/13 11:01 AM
09/24/13 11:01 AM
A forward rake angle helps you with ventilation but not cavitation.
Re: AC72 Oracle Team USA Spaceship has landed [Re: P.M.] #264849
09/24/13 12:03 PM
09/24/13 12:03 PM
Portland, Maine
ThunderMuffin Offline
Portland, Maine
Random thought but has anyone compared the relative conditioning of the two teams? We all know we have sex-breath McGee on ETNZ who clearly sounds like he's on mile 25 of a marathon by the last leg - but I have to say that the Oracle guys don't look nearly as spent when the race is over - at least in the later stages of the event.
You think that it might play a part in the seemingly sluggish maneuvering by ETNZ?
(The race has inspired me to go back to the gym FWIW)
Re: AC72 Oracle Team USA Spaceship has landed [Re: P.M.] #264850
09/24/13 12:20 PM
09/24/13 12:20 PM
On the Water
P.M. Offline OP
Happy Birthday P.M.  Offline OP
On the Water
Race 17
1.6 knot flood current, 24.6 knot wind limit
race 18
1.1 knot flood, 24.1 knot wind limit
Big winds forecast today
Philip
USA #1006
Re: AC72 Oracle Team USA Spaceship has landed [Re: P.M.] #264851
09/24/13 12:20 PM
09/24/13 12:20 PM
On the Water
P.M. Offline OP
On the Water
Philip
USA #1006
Re: AC72 Oracle Team USA Spaceship has landed [Re: P.M.] #264853
09/24/13 12:29 PM
09/24/13 12:29 PM
brucat Offline
brucat  Offline
He doesn't want to take any more chances that he won't be able to fulfil his dream/promise to return to monohulls? I'd be more impressed if he took the wheel.
Re: AC72 Oracle Team USA Spaceship has landed [Re: P.M.] #264854
09/24/13 12:34 PM
09/24/13 12:34 PM
brucat Offline
brucat  Offline
Hey while we're waiting... let's start a top 10 list of things from this regatta that you can apply to every day life (since $100,000,000/boat technology will not readily trickle down to our level of the sport).
Here's one (inspired by the gym comment above):
If you're sitting in your office chair, and you lean to one side, and the sounds that come from the chair remind you of the groaning rigs of the AC72s, you might want to find your way back to the gym...
Re: AC72 Oracle Team USA Spaceship has landed [Re: P.M.] #264855
09/24/13 12:46 PM
09/24/13 12:46 PM
Originally Posted by P.M.
Race 17
race 18
I'm seeing a forecast of 16 kts out of the east at 2pm local.
Re: AC72 Oracle Team USA Spaceship has landed [Re: brucat] #264856
09/24/13 12:49 PM
09/24/13 12:49 PM
catman Offline
catman  Offline
You don't need the gym. A little silicone spray will fix that.
Re: AC72 Oracle Team USA Spaceship has landed [Re: Jake] #264857
09/24/13 01:10 PM
09/24/13 01:10 PM
On the Water
P.M. Offline OP
On the Water
Race 17
race 18
Out of the East? Are you ok Jake?
Philip
USA #1006
Re: AC72 Oracle Team USA Spaceship has landed [Re: P.M.] #264858
09/24/13 01:10 PM
09/24/13 01:10 PM
On the Water
P.M. Offline OP
On the Water
Wind 260 at 20.7 kts, 22.5 kts peak
Philip
USA #1006
Re: AC72 Oracle Team USA Spaceship has landed [Re: P.M.] #264859
09/24/13 01:12 PM
09/24/13 01:12 PM
brucat Offline
brucat  Offline
That's awfully close to the limit...
Re: AC72 Oracle Team USA Spaceship has landed [Re: P.M.] #264860
09/24/13 01:13 PM
09/24/13 01:13 PM
Portland, Maine
Portland, Maine
Philip where are you pulling weather data from?
Re: AC72 Oracle Team USA Spaceship has landed [Re: ThunderMuffin] #264861
09/24/13 01:15 PM
09/24/13 01:15 PM
finally! Thanks for that investigative journalism
Re: AC72 Oracle Team USA Spaceship has landed [Re: ThunderMuffin] #264862
09/24/13 01:19 PM
09/24/13 01:19 PM
On the Water
P.M. Offline OP
On the Water
It's the live chatter feed
http://live.virtualeye.tv/Chatter/chatter_100.html
TIM = Telemetry Interface Metadata
It's the source from the race committee. Wind comes from the Automated Wind monitor and reporter.
Philip
USA #1006
0 registered members (), 81 guests, and 77 spiders.
Posts267,059
