| Re: knives and helmets ?
[Re: carl2]
#274811 08/18/14 10:01 AM 08/18/14 10:01 AM | MN3
| MN3
Unregistered | mea culpa for my tightwad post..hope I can still post here don't worry, most people are tightwads here one time or another anyone use handgrabs or rope ladder tied to front beam to assist? yes big issue. discussed in detail here, try searching but from my exp, rope ladders don't work as well as you would think (or need lots of practice) becuase they simply push under the beam and are not much help, plus need special storage righting line with knots are a little help but not all that helpful I have found location location location is key (where on the boat you try to get back on from) front beam - almost impossible on my boat, saps all my remaining strenght rear beam - impossible solution for me on my boat ... aft of the shrouds, I "jump" up a little and grab my trap handle. use this to anchor and lift a foot/feet up near the rear beam (least freeboard area) and then lift my waist / torso up using my feet and hands (still on trap handle) in a pinch, if you can get to it your jib sheet can assist too | | | Re: knives and helmets ?
[Re: ]
#274813 08/18/14 10:37 AM 08/18/14 10:37 AM |
Posts: 3,906 Clermont, FL, USA | solution for me on my boat ... aft of the shrouds, I "jump" up a little and grab my trap handle. use this to anchor and lift a foot/feet up near the rear beam (least freeboard area) and then lift my waist / torso up using my feet and hands (still on trap handle)
This is what I do too and I'm 52 and sail an F18 and I can get on the boat easily and in short order. The key thing to remember is to move your a$$. If you have a self tacking jib and don't have a quick release system the jib will pull the boat off the wind relatively quickly and the boat will take off like a rocket.
[Re: David Ingram]
#274817 08/18/14 11:34 AM 08/18/14 11:34 AM |
Posts: 3,116 Annapolis, MD | Dave.... you make a key point
How do you get there? swim under hull.... go forward and around the bow? go aft under the tramp... around the rudders and forward to the shroud... trap handle?
Do you have a quick release on your jib's clew? (and let it flog when you right the boat....) then reattach the sheets and off you go...
What does your quick release look like?
Final point.... Who needs to move their butt... you or your quicker and more nimble crew who can ride the boat up... climb over the beam and get to the rudders to park the boat ASAP?
crac.sailregattas.com
[Re: Pirate]
#274819 08/18/14 12:27 PM 08/18/14 12:27 PM |
Posts: 554 Boston, Ma | I've been wearing a helmet this season due to a concussion I got skiing in March. It was a minor concussion that lingered for 2.5 months- very annoying.
On the F18 I've been wearing a kiteboarding helmet Tripp let me borrow. On the Moth I've worn a Bern helmet that MIT provides at the sailing pavilion. I haven't really noticed having either of them on.
Unfortunately I tore a ligament in my hand during the statue race, so the helmet hasn't been needed for a while!
USF18 Eastern Area Rep Nacra Infusion USA 753
[Re: Mark Schneider]
#274820 08/18/14 12:48 PM 08/18/14 12:48 PM |
Posts: 3,906 Clermont, FL, USA | Dave.... you make a key point
Final point.... Who needs to move their butt... you or your quicker and more nimble crew who can ride the boat up... climb over the beam and get to the rudders to park the boat ASAP? I don't have a jib quick release on my boat and there isn't one on my skippers boat. I've seen quick release systems that use a snap shackle or simple S hook at the clew. When I'm sailing on my skippers boat I can pretty much right the boat on my own and she just rolls up on deck as the boat comes up. I always have a plan B just in case something doesn't go as planned, which is for me to high tail it to the stern holding onto the righting line until I've got a firm grip on the foot strap. From there I pull myself forward until I can reach the skippers trap and I use it to help pull myself on the boat. Plan B is always in motion because the sooner I can get on the boat the sooner we are back to racing and I hate when she says... waiting on you grandpa. The quicker you're on the boat the less likely it's going to get away from you. It is something we practiced and I think it was time well spent.
[Re: dave mosley]
#274828 08/18/14 03:30 PM 08/18/14 03:30 PM |
Posts: 12,310 South Carolina | dont you know someone who does vinyl wraps? Yeah, but that is a different guy.
Jake Kohl | | | Re: knives and helmets ?
#274830 08/18/14 03:36 PM 08/18/14 03:36 PM |
Posts: 5,590 Naples, FL | Perhaps using the blow-torch technique to get the wrap to fit on the helmet while being worn is not considered a "best practice"?
[Re: brucat]
#274838 08/18/14 09:04 PM 08/18/14 09:04 PM |
Posts: 4,119 Northfield Mn | Ding hit the nail right on the head: Practice!!!
Capsizing and swiiming near your boat are probably the last things anyone wants to do with their sailing time, but there is probably nothing more valuable.
Mike Luckily I'm the mf-ing master of capsizing.
[Re: Karl_Brogger]
#274847 08/19/14 09:05 AM 08/19/14 09:05 AM |
Posts: 3,969 | Ding hit the nail right on the head: Practice!!!
Mike Luckily I'm the mf-ing master of capsizing. Only because I've taken a partial hiatus from racing. I've capsized a Wave... Mike | | | Re: knives and helmets ?
[Re: brucat]
#274848 08/19/14 10:16 AM 08/19/14 10:16 AM |
Mike Luckily I'm the mf-ing master of capsizing. Only because I've taken a partial hiatus from racing. I've capsized a Wave... Mike That's talent you can't teach right there.
1 registered members (soulofasailor),
1,861
guests, and 23
