Problem with my Stealth. Need help #261328
07/14/13 11:02 AM
07/14/13 11:02 AM
Bertrand Mazuir Offline OP
Hi All,
I have a problem with a thread on a hull of my Stealth (used to put together the hull and the beam).
It has been damaged certainly because of a too hard tightening.
So now I need to repair it and I see 2 solutions :
Drill to put a M12 screw (currently M10). But I'm not sure if it is feasable as I don't know how is the block of the thread.
Repair with a HELICOIL system :
http://docs-europe.electrocomponents.com/webdocs/1015/0900766b810150a0.pdf
Did somebody have this kind of experience on a Stealth. What would you recommend ?
Many thanks for your help
Bertrand
Stealth 539
Re: Problem with my Stealth. Need help [Re: Bertrand Mazuir] #261488
07/18/13 09:51 AM
07/18/13 09:51 AM
Greenville SC
bacho Offline
bacho  Offline
Greenville SC
Is the insert in the hull aluminum or stainless?
I would be tempted to try a 12mm bolt first, I haven't been real impressed with helicoils. The other option would be to try to put a nut on the bolt if you have access.
Re: Problem with my Stealth. Need help [Re: Bertrand Mazuir] #261516
07/20/13 05:55 AM
07/20/13 05:55 AM
waynemarlow Offline
waynemarlow  Offline
You will be fine with either a larger bolt or helicoil, the early Stealths had an Ali block imbedded in the back of the layup and the later ones had a Delron ( or something similar ). Most people forget to put some sort of grease on bolts and eventually corrosion between dis-similar metals locks the threads.
John Pierce the maker of the Stealths is still about, have you tried contacting him ?
Re: Problem with my Stealth. Need help [Re: Bertrand Mazuir] #261703
07/24/13 10:14 PM
07/24/13 10:14 PM
WA, ID, MT
davefarmer Offline
davefarmer  Offline
WA, ID, MT
My 2002 had alum plates, poorly glassed in. I had to go in thru the transom to fix when retapping didn't work. I have a fairly extensive series of pic of the process if desired.
Dave
Re: Problem with my Stealth. Need help [Re: davefarmer] #261913
07/31/13 02:43 PM
07/31/13 02:43 PM
I Helicoiled one of mine; fairly simple process
Re: Problem with my Stealth. Need help [Re: Bertrand Mazuir] #268068
12/29/13 11:10 AM
12/29/13 11:10 AM
john_nohj Offline
john_nohj  Offline
Davefarmer id really like to see those pics. Previous owner had used brass screws to fix in the gudgeons and I sheared off all 6 heads trying to take them out. Trying to figure out best solution now.
Also does anyone have John Pierces email/contact details? Tried emailing the stealthmarine email address for replacement parts and have had no reply. Maybe just because its Christmas?
Thanks,
John_nohj
Re: Problem with my Stealth. Need help [Re: Bertrand Mazuir] #269639
02/23/14 12:04 PM
02/23/14 12:04 PM
WA, ID, MT
davefarmer Offline
davefarmer  Offline
WA, ID, MT
I found this:
[email protected]
worked a couple years ago
Re: Problem with my Stealth. Need help [Re: davefarmer] #269994
03/07/14 06:10 PM
03/07/14 06:10 PM
Dublin, Ireland
Dermot Offline
Dermot  Offline
Dublin, Ireland
Dermot
Catapult 265
Re: Problem with my Stealth. Need help [Re: Bertrand Mazuir] #270168
03/13/14 07:22 AM
03/13/14 07:22 AM
N
NacramanUK Offline
NacramanUK  Offline
N
All stealth moulds (hull, foils and mast) now with Pete Jary (Zest Racing) who is in Southampton with production starting very soon. Please pm me for more details ([email protected] )....
0 registered members (), 311 guests, and 20 spiders.
