Page 7 of 12 1 2 5 6 7 8 9 11 12
Re: How in the world can we lose an entire jumbo jet today? [Re: Jake] #270330
03/17/14 04:09 PM
03/17/14 04:09 PM
Here's another viewpoint, this one from a real Airline Capt., not Richard Quest:
http://www.cnn.com/2014/03/16/opinion/palmer-malaysia-flight-370/index.html
Re: How in the world can we lose an entire jumbo jet today? [Re: Jake] #270343
03/18/14 06:18 AM
03/18/14 06:18 AM
Eastern NC, USA
tshan Offline
tshan  Offline
Eastern NC, USA
Another pilot's perspective (matches Timbo's scenario).....
https://plus.google.com/app/basic/stream/z13cv1gohsmbv5jmy221vrfyiz3vdhbop04
"chris goodfellow
4 days agoPublic
Post activities
MH370 A different point of view. Pulau Langkawi 13,000 runway.
A lot of speculation about MH370. Terrorism, hijack, meteors. I cannot believe the analysis on CNN - almost disturbing. I tend to look for a more simple explanation of this event.
Loaded 777 departs midnight from Kuala to Beijing. Hot night. Heavy aircraft. About an hour out across the gulf towards Vietnam the plane goes dark meaning the transponder goes off and secondary radar tracking goes off.
Two days later we hear of reports that Malaysian military radar (which is a primary radar meaning the plane is being tracked by reflection rather than by transponder interrogation response) has tracked the plane on a southwesterly course back across the Malay Peninsula into the straits of Malacca.
When I heard this I immediately brought up Google Earth and I searched for airports in proximity to the track towards southwest.
The left turn is the key here. This was a very experienced senior Captain with 18,000 hours. Maybe some of the younger pilots interviewed on CNN didn't pick up on this left turn. We old pilots were always drilled to always know the closest airport of safe harbor while in cruise. Airports behind us, airports abeam us and airports ahead of us. Always in our head. Always. Because if something happens you don't want to be thinking what are you going to do - you already know what you are going to do. Instinctively when I saw that left turn with a direct heading I knew he was heading for an airport. Actually he was taking a direct route to Palau Langkawi a 13,000 foot strip with an approach over water at night with no obstacles. He did not turn back to Kuala Lampur because he knew he had 8,000 foot ridges to cross. He knew the terrain was friendlier towards Langkawi and also a shorter distance.
Take a look on Google Earth at this airport. This pilot did all the right things. He was confronted by some major event onboard that made him make that immediate turn back to the closest safe airport.
For me the loss of transponders and communications makes perfect sense if a fire. There was most likely a fire or electrical fire. In the case of fire the first response if to pull all the main busses and restore circuits one by one until you have isolated the bad one.
If they pulled the busses the plane indeed would go silent. It was probably a serious event and they simply were occupied with controlling the plane and trying to fight the fire. Aviate, Navigate and lastly communicate. There are two types of fires. Electrical might not be as fast and furious and there might or might not be incapacitating smoke. However there is the possibility given the timeline that perhaps there was an overheat on one of the front landing gear tires and it blew on takeoff and started slowly burning. Yes this happens with underinflated tires. Remember heavy plane, hot night, sea level, long run takeoff. There was a well known accident in Nigeria of a DC8 that had a landing gear fire on takeoff. A tire fire once going would produce horrific incapacitating smoke. Yes, pilots have access to oxygen masks but this is a no no with fire. Most have access to a smoke hood with a filter but this will only last for a few minutes depending on the smoke level. (I used to carry one of my own in a flight bag and I still carry one in my briefcase today when I fly).
What I think happened is that they were overcome by smoke and the plane just continued on the heading probably on George (autopilot) until either fuel exhaustion or fire destroyed the control surfaces and it crashed. I said four days ago you will find it along that route - looking elsewhere was pointless.
This pilot, as I say, was a hero struggling with an impossible situation trying to get that plane to Langkawi. No doubt in my mind. That's the reason for the turn and direct route. A hijack would not have made that deliberate left turn with a direct heading for Langkawi. It would probably have weaved around a bit until the hijackers decided on where they were taking it.
Surprisingly none of the reporters , officials, other pilots interviewed have looked at this from the pilot's viewpoint. If something went wrong where would he go? Thanks to Google earth I spotted Langkawi in about 30 seconds, zoomed in and saw how long the runway was and I just instinctively knew this pilot knew this airport. He had probably flown there many times. I guess we will eventually find out when you help me spread this theory on the net and some reporters finally take a look on Google earth and put 2 and 2 together. Also a look at the age and number of cycles on those nose tires might give us a good clue too.
Fire in an aircraft demands one thing - you get the machine on the ground as soon as possible. There are two well remembered experiences in my memory. The AirCanada DC9 which landed I believe in Columbus Ohio in the eighties. That pilot delayed descent and bypassed several airports. He didn't instinctively know the closest airports. He got it on the ground eventually but lost 30 odd souls. In the 1998 crash of Swissair DC-10 off Nova Scotia was another example of heroic pilots. They were 15 minutes out of Halifax but the fire simply overcame them and they had to ditch in the ocean. Just ran out of time. That fire incidentally started when the aircraft was about an hour out of Kennedy. Guess what the transponders and communications were shut off as they pulled the busses.
Get on Google Earth and type in Pulau Langkawi and then look at it in relation to the radar track heading. 2+2=4 That for me is the simple explanation why it turned and headed in that direction.
Smart pilot. Just didn't have the time."
Re: How in the world can we lose an entire jumbo jet today? [Re: Jake] #270347
03/18/14 06:31 AM
03/18/14 06:31 AM
Eastern NC, USA
tshan Offline
tshan  Offline
Eastern NC, USA
The pilot posted the above before the Rolls Royce info was made public.. here is what he said after that info became public (see the url in post above for full conversation:
"chris goodfellow22 hours ago
Diego and all who have commented - thank you.
I wrote this post before the information regarding the engines continuing to run for approximately six hours and the fact it seems acars was shut down before the transponder.
The continued speculation of hijack and/or murder suicide and the latest this morning that there was a flight engineer on board that is being investigated does not do much to sway me in favour of foul play until I am presented with evidence of foul play.
My post received a lot of comments on Reddit as well if some of you wish to read those. www.reddit.com MH370.
Now let me deal with Diego's request for my present view in light of new evidence.
We know there was a last voice transmission that from a pilot's point of view (POV) was entirely normal. The good night is customary on a hand -off to a new ATC control. The good night also indicates STRONGLY to me all was OK on the flight deck. Remember there are many ways a pilot can communicate distress - the hijack code or even a transponder code different by one digit from assigned would alert ATC that something was wrong. Every good pilot knows keying an SOS over the mike is always an option even three short clicks would raise an alert.
So I conclude at that point of voice transmission all was perceived as well on the flight deck by the pilots.
But things could have been in the process of going wrong unknown to the pilots -
Evidently the ACARS went inoperative some time before. Disabling the ACARS is not easy as pointed out. This leads me to believe more in an electric or electric fire issue than a manual shutdown. I suggest the pilots were probably not aware it was not transmitting.
The next event is the turn to the SW in what appears direct Langkawi.
As I said in the first post the pilot probably had this in his head already.
Someone said why didn't he go to KBR on north coast of Malaysia which was closer. That's a 6,000 foot runway and to put that plane down on a 6,000 foot strip at night uncertain of your aircraft's entire systems is not an option. I would expect the pilot would consider ditching before a 6,000 runway if still above maximum landing weight which he likely was.
The safest runway in the region to make the approach was certainly Langkawi - no obstacles over water with a long flat approach. In my humble opinion this 18,000 hour pilot knew this instinctively.
Reports of altitude fluctuations. Well given that this was not transponder generated data but primary radar at maybe 200 miles the azimuth readings can be affected by a lot of atmospherics and I would not have high confidence in this being totally reliable. But let's accept for a minute he might have ascended to 45,000 in a last ditch effort to quell a fire by seeking the lowest level of oxygen. It is an acceptable scenario in my opinion. At 45,000 it would be tough to keep this aircraft stable as the flight envelope is very narrow and loss of control in a stall is entirely possible. The aircraft is at the top of its operational ceiling. The reported rapid rates of descent could have been generated by a stall and recovery at 25,000. The pilot may even have been diving the aircraft to extinguish flames. All entirely possible.
But going to 45,000 in a hijack scenario doesn't make any good sense to me.
The question of the time the plane flew on.
On departing Kuala he would have had fuel for Beijing and alternate probably Shanghai and 45 minutes. Say 8 hours. Maybe more. He burned 20-25% in first hour with takeoff, climb to cruise. So when the turn was made towards Langkawi he would have had six hours or more. This correlates nicely with the immarsat data pings being received until fuel exhaustion.
The apparent now known continued flight until TTFE time to fuel exhaustion only actually confirms to me the crew were incapacitated and the flight continued on deep into the south Indian ocean.
There really is no point in speculating further until more evidence surfaces but in the meantime it serves no purpose to malign the pilots who well may have been in an heroic struggle to save this aircraft from a fire or other serious mechanical issue and were overcome.
I hope the investigation team looks at the maintenance records of the front gear tires - cycles, last pressure check and maintenance inspection. Captain or F/O as part of pre-flight looks at tires. Is there any video at the airport to support pre-flight walkaround? Any damage on pushback? A day after I wrote the original post a plane in the U.S. blew a tire in takeoff and the t/o was fortunately aborted with a burning tire.
Hopefully - and I believe now it is a slim hope - the wreckage will be found and the FDR and VDR will be recovered and provide us with insight. Until facts prove otherwise, I would give the Captain the benefit of respect and professional courtesy."
Re: How in the world can we lose an entire jumbo jet today? [Re: Jake] #270348
03/18/14 06:34 AM
03/18/14 06:34 AM
pgp Offline
pgp  Offline
That makes sense.
Pete Pollard
Blade 702
Re: How in the world can we lose an entire jumbo jet today? [Re: Jake] #270349
03/18/14 07:37 AM
03/18/14 07:37 AM
Here's some 'old school' stuff for you cubicle pilot wannabee's to look at.
http://www.youtube.com/watch?v=7R0CViDUBFs
This is the **** of an (American Airlines) MD80, which is simply a stretched DC9, and still sporting 1950's technology from a DC3! This is at the opposite end of the technology spectrum from a 777, but it's fun to look at.
I flew both the DC9 and MD88 at Delta for just long enough to know I hated it. It makes you work wayyy too hard just to fly it, and you can never trust it to do what you want it to. It's got a mind of it's own.
We have a saying in the airline biz:
Boeing build airplanes, McDonnell Douglas builds Character!
Compare that **** to this one, a 777LR: http://www.youtube.com/watch?v=_llyS20J0Ac
And yes, I know Boeing bought Micky-D's, but that still don't make it right!
Re: How in the world can we lose an entire jumbo jet today? [Re: Jake] #270350
03/18/14 07:48 AM
03/18/14 07:48 AM
Portland, Maine
ThunderMuffin Offline
Portland, Maine
The Maddog.
Re: How in the world can we lose an entire jumbo jet today? [Re: Jake] #270351
03/18/14 07:50 AM
03/18/14 07:50 AM
Yeah, and now you know why we call it that! I spent my first three days in the MD88 simulator screaming obscenities at it!
Re: How in the world can we lose an entire jumbo jet today? [Re: Jake] #270352
03/18/14 08:02 AM
03/18/14 08:02 AM
Portland, Maine
Portland, Maine
I think my uncle had to fly them too. He said it was the only plane that scared him more than the harriers he flew in the Corps.
Re: How in the world can we lose an entire jumbo jet today? [Re: Jake] #270353
03/18/14 08:15 AM
03/18/14 08:15 AM
Portland, Maine
Portland, Maine
Timbo: does the fact that the left turn was programmed and executed by a computer make any difference to your assessment?
http://www.nytimes.com/2014/03/18/world/asia/malaysia-airlines-flight.html?hp&_r=1
Re: How in the world can we lose an entire jumbo jet today? [Re: ThunderMuffin] #270354
03/18/14 08:32 AM
03/18/14 08:32 AM
Jake Offline OP
Jake  Offline OP
My experience is limited to sitting in the copilot seat of a twin engine Baron for some hopping around the east coast (occasionally a P-Baron)...programming an unplanned turn in that case is pretty quick and simple and takes less time than executing the turn manually. Our pilot would usually set the course change into the autopilot for any type of course change (to avoid weather, traffic, or to adhere to ground instruction). I would expect them to program that turn especially if they had their hands full with other things.
Re: How in the world can we lose an entire jumbo jet today? [Re: Jake] #270355
03/18/14 08:37 AM
03/18/14 08:37 AM
Jake Offline OP
Jake  Offline OP
The simplest answer is usually the correct one. This is a good example of how the media can affect the story - particularly in a vacuum of facts.
Re: How in the world can we lose an entire jumbo jet today? [Re: Jake] #270356
03/18/14 08:40 AM
03/18/14 08:40 AM
M
MN3
MN3
M
+1 for aliens
This was me flying into Tampa at 1am lastnight in a sick storm
I shoulda taken an aisle seat
Re: How in the world can we lose an entire jumbo jet today? [Re: ] #270360
03/18/14 09:25 AM
03/18/14 09:25 AM
Jake Offline OP
Jake  Offline OP
Thailand turned over some newish radar data (not before now because "nobody asked for it") that corroborates the data that the flight turned back toward Malaysia. According to this report, it seems that the flight turned back toward Kuala Lumpur (where it originated) and then later turned west toward Butterworth. A quick look at Google and Earth and I see that Penang International Airport is just to the other side of Butterworth, Malaysia and has a runway about 2 miles long that could probably facilitate that plane. I think it's starting to really look like something major went wrong equipment onboard and those guys were trying to get it back on the ground. Something happened on the way that saw it pointed further west out over the Indian Ocean and unmanned.
http://www.thehindu.com/news/mh370-...ne-lost/article5799254.ece?homepage=true
Re: How in the world can we lose an entire jumbo jet today? [Re: ThunderMuffin] #270373
03/18/14 05:49 PM
03/18/14 05:49 PM
I don't buy it first of all, but secondly, the 777 Flight Management System (FMS) has the ability to load two routes, a Route 1 wich is our normal route, and a Route 2, which we load with our divert points and divert airports.
If they were having a mx issue, and they'd decided to divert, all they would have to do is push two buttons on the FMS to move from Route 1 to Route 2: "Activate" and "Execute" and the airplane would now fly the route 2, to their divert airport.
I'm in ATL at the moment, on my way to Dubai tonight. I'll keep my eyes open for the Malaysian 777, who might be trying to shadow us....
Riiiihhhgggt!
Re: How in the world can we lose an entire jumbo jet today? [Re: Jake] #270384
03/19/14 07:05 AM
03/19/14 07:05 AM
brucat Offline
brucat  Offline
I don't trust a single thing we're being fed. Not from the government(s), and certainly not from the media, who come up with a more and more outlandish theory every 4-6 hours. Not because I'm a paranoid conspiracy theory nut, but because there are just too many changes of the story from the officials, and too much editorial ad-libbing from the "reporters" (anyone who thinks this plane can be hidden, fueled, and flown around the world to shadow in for a sneak attack in the USA needs to step away from their bunker and get some sunlight)...
It's sad that we're back in this situation after 9/11, where they report stories first and check facts later (if at all). One would have thought that they would have learned that lesson after the Bush/Gore election night fiasco...
Re: How in the world can we lose an entire jumbo jet today? [Re: brucat] #270385
03/19/14 07:25 AM
03/19/14 07:25 AM
Jake Offline OP
Jake  Offline OP
It's all about the money. First to report gets the viewers and they can sell ads. Viewership, in general, is pretty insensitive to whether or not something is "factual".
Re: How in the world can we lose an entire jumbo jet today? [Re: Jake] #270386
03/19/14 08:02 AM
03/19/14 08:02 AM
brucat Offline
brucat  Offline
I know all of that, and the internet fuels a lot of it; but especially when people's lives are in the mix, it's just disgusting.
Anyone see the footage of the helicopter that crashed in Seattle yesterday? Did your news outlet also show the raw footage of the thing fully engulfed before the fire department arrived? Now, imagine that your dad was one of the two guys in there, either just killed from the crash, of being burned alive as he died, unable to get out. I'm all for freedom of the press, but handling these stories this way does not make us look good as a species.
EDIT: Yes, I know that these are two different issues (the plane issue is one of needlessly freaking out the public and potentially giving terrorists new ideas), the helicopter is total lack of common decency), but the common theme is sensationalism that serves only the media.
Re: How in the world can we lose an entire jumbo jet today? [Re: brucat] #270387
03/19/14 08:28 AM
03/19/14 08:28 AM
Orlando, FL
tback Offline
tback  Offline
Orlando, FL
No, CNN was covering the missing plane 24x7.
Didn't hear about the border skirmish between Israel and Jordan, or the "flash mob" at the Ukraine Naval Station, or Phil Jackson being named to the NY Knicks; and certainly didn't hear about Benghazi or the IRS misgivings eek
USA 777
Re: How in the world can we lose an entire jumbo jet today? [Re: Jake] #270404
03/19/14 06:20 PM
03/19/14 06:20 PM
Probably never was a plane. Probably just another diversionary tactic.
I wonder if that scenario has popped up?
Re: How in the world can we lose an entire jumbo jet today? [Re: Timbo] #270405
03/19/14 06:34 PM
03/19/14 06:34 PM
Jake Offline OP
Jake  Offline OP
0 registered members (), 546 guests, and 92 spiders.
Posts267,058
