Re: Tapered spin halyard [Re: Dazz] #274005
07/18/14 05:25 AM
07/18/14 05:25 AM
Greenville SC
bacho Offline
bacho  Offline
Greenville SC
Originally Posted by Dazz
So how many people here have the tack line attached to the bungie for the turning block (s) at the rear of the tramp? idea is to allow that/those blocks to move forward up the tramp when the kite is set.
works very well in light weather!
My boat has that, works great.
Re: Tapered spin halyard [Re: Dazz] #274011
07/18/14 08:48 AM
07/18/14 08:48 AM
Anacortes
Sloansailing Offline
Anacortes
It took a little tinkering with the lengths but we got this set up on our boat under the tramp and its been great. Works especially well if you have the retrieval line running through a ring at the clew to pull the sheets into the snuffer when you douse. No extra slack in the sheets, no extra slack in the halyard.
Anacortes Rigging.com
Rigging and Yacht Services
Re: Tapered spin halyard [Re: rehmbo] #274024
07/18/14 08:28 PM
07/18/14 08:28 PM
My halyard is under the tramp.
My tackline runs under the tramp to a back to back block, then is tied off at the front beam.
That back to back block has a bungee running through it. The bungee goes through a couple of little harken blocks tired off to each corner at the rear beam. Both ends of that bungee have a block on it that the halyard runs through. I want to get rid of these blocks and switch to rings to keep asshholes from ruining my day.
The block tied off to the starboard side of the rear beam is larger because the bungee runs through it twice.
It sounds super complicated, but once you see it in person is really simple and it has a 2:1 to a 2:1 on the take up, so you've got miles of slack with kite up, but still pulls it up tight when snuffed. I haven't noticed any difference in effort to snuff the spinnaker either.
Re: Tapered spin halyard [Re: rehmbo] #274025
07/18/14 10:04 PM
07/18/14 10:04 PM
Hobart, Tasmania, Oz.
Dazz Offline
Dazz  Offline
Hey Karl, have you seen the ronstan shock blocks? Absolutely ideal for spinnaker halyard take up! The rope runs a little smoother through them.
C2 AUS 222 by Goodall design
"Darph Bobo"
Re: Tapered spin halyard [Re: rehmbo] #274033
07/19/14 02:44 PM
07/19/14 02:44 PM
I have. Hadn't thought about using them there though.
Re: Tapered spin halyard [Re: rehmbo] #274570
08/10/14 06:56 PM
08/10/14 06:56 PM
Dazz Offline
Dazz  Offline
This is a vid from Rich Vilvens Capricorn, that is a pretty tricky under the tramp halyard! looks like it works pretty well too.
"Darph Bobo"
Re: Tapered spin halyard [Re: rehmbo] #277740
02/27/15 10:08 AM
02/27/15 10:08 AM
SE MI / NE IN
rehmbo Offline OP
rehmbo  Offline OP
SE MI / NE IN
As a quick follow-up on this. I decided to give it a go and stick with the original double-tapered design based on 5mm Robline Dinghy control. I have an undertramp takeup that works well and didn't want to risk the chance messing up the delicate balance.
Turns out my concerns on doing this myself were completely unfounded. This YouTube video was hugely helpful.
https://www.youtube.com/watch?v=7bWZpUQZO8E#t=190
Hardest part was digging the effing core out of the plait. Had to borrow my wife's reading glasses just to see what the heck I was doing. I think it took all of a couple hours beginning to end. Next time would be half that.
Now its on to making a new set of dyneema trap lines...
Jeff R
H18, C2 USA1193
cramsailing.com
crescentsail.com
Re: Tapered spin halyard [Re: rehmbo] #277741
02/27/15 05:41 PM
02/27/15 05:41 PM
I'm stupid. I pull the entire core out, and stuff in a different color, just because I'm a douche, and like having things that aren't off the shelf. But yeah, it takes some patience to pull the dyneema through that tight weave.
The more you do it, the better you get. I could make a halyard in 15 minutes at one point. I haven't had to do it in at least a year and a half, but my spare is gone, on the boat, and it's looking tired, so time to make a couple more for myself. I'm sure it'll go swimmingly....
Start buying line by the spool.
Re: Tapered spin halyard [Re: Karl_Brogger] #277742
02/28/15 02:28 PM
02/28/15 02:28 PM
dr5e14w Offline
dr5e14w  Offline
I could make them in about 8 minutes each of I was making 5 or more at a time. Not any more though
Re: Tapered spin halyard [Re: rehmbo] #277749
03/01/15 04:18 PM
03/01/15 04:18 PM
Memphis, TN
Andy Humphries Offline
Memphis, TN
It is easier to use a 5mm single braid like Robline Racing sheet or Mafioli Swiftcord spliced into 3mm dyneema, which is also single braid. Much easier and faster. I hate trying to splice those tightly woven covers.
Re: Tapered spin halyard [Re: rehmbo] #277751
03/01/15 05:58 PM
03/01/15 05:58 PM
SE MI / NE IN
rehmbo Offline OP
rehmbo  Offline OP
SE MI / NE IN
I remember you mentioned it being tough to work with. Now I'm a believer. Not sure I'll try that tight braid again. Picking the plates out of the cover to taper it was maddening.
Jeff R
H18, C2 USA1193
cramsailing.com
crescentsail.com
Re: Tapered spin halyard [Re: rehmbo] #280663
09/29/15 10:33 PM
09/29/15 10:33 PM
San Francisco, CA
L
Longboardebo Offline
L
San Francisco, CA
Hmm, I didn't hear anyone mention splicing in a soft shackle to the head of the halyard? I've done that on my last two halyards and its worked great! Very clean. I do the soft shackle first and then strip the core out of the cover to make sure I get the length correct and then cut off the extra cover to provide the tail for the kite.
Here is the youtube link for the integrated softshackle:
https://www.youtube.com/watch?v=rRKOkYqWpug
2013 NACRA F18 Infusion Mk II
0 registered members (), 434 guests, and 35 spiders.
