| Re: 1182 ......'Twice Shy'
[Re: Pirate]
#273547 06/29/14 04:38 AM 06/29/14 04:38 AM |
Joined: Apr 2013 Posts: 858 Victoria Australia Pirate OP
Posts: 858 Victoria Australia | the old 10mm deck against an offcut of the new 4mm deck material. ![[Linked Image]](http://i961.photobucket.com/albums/ae97/BADZX/1182/306_zpsb7eec2d0.jpg) ![[Linked Image]](http://i961.photobucket.com/albums/ae97/BADZX/1182/307_zps3eba31fd.jpg) As you can clearly see the 2 added foams, the ply plates I glued to the foams, the 3 runs of stringers I added and the new ply deck .... weighs far less than that lump of 10mm ply that was there ! be interesting to get her back on the scales once this is finished 200/16196 Yar, & this ere post be done without a sin'le drop o' rum passin' me lips
Kingy started with Impara Cadet #3 / Mosquito #245 & now Mosquitos #1182 & #1740 | | | Re: 1182 ......'Twice Shy'
[Re: Pirate]
#273548 06/29/14 04:46 AM 06/29/14 04:46 AM |
Posts: 858 Victoria Australia | It will be a couple of days before I even look at her again, the resin is a slow cure resin and the weather here is pharkencold to say the least so it will probably be a bit longer to fully cure even tho the heaters are on. Once its cured fully we have the wonderfull job of ripping the staples out ..... mutter mutter mutter ... and then we can cut the hatch hole and the case slot. I took exact measurements for the case slot and the centre of the hatch so it in theory be fairly simple to make the holes in the right spots...... yeah !!!  Yar, & this ere post be done without a sin'le drop o' rum passin' me lips
[Re: Pirate]
#273719 07/05/14 09:36 AM 07/05/14 09:36 AM |
Posts: 858 Victoria Australia | Resin has cured fully  staples are ripped and then pulled out  edges are cut off and then planed back  sanding block finishes off the edges  hatch hole and case slots cut and sanded into shape not bad for a Saturday arvo job  ![[Linked Image]](http://i961.photobucket.com/albums/ae97/BADZX/1182/309_zps47a5c57c.jpg) ![[Linked Image]](http://i961.photobucket.com/albums/ae97/BADZX/1182/310_zps34accd52.jpg) Yar, & this ere post be done without a sin'le drop o' rum passin' me lips
[Re: Pirate]
#273844 07/11/14 05:45 AM 07/11/14 05:45 AM |
Posts: 858 Victoria Australia | masking done, and primer on  the mains will have the green border like the rear and fore decks have and the centre will be varnished. should look neat and tidy when its finished. NB: see the sanding block on the fore deck ...... After the rush job to replace the fore-decks and have her ready for the Easter Regatta at Lake Bolac, I never did a great job on the varnishing, it was just enough to seal it up and I knew I had to "fix" it later.... now is as good a time as any  I'm cutting it down with 180grit paper until I get it reasonable, then I'll drop down to 320grit paper, at this stage I wont have to re-do the green border but more than likely I'll get a rub through so its one the cards to get a new green border while I'm doing the mains.... ![[Linked Image]](http://i961.photobucket.com/albums/ae97/BADZX/1182/318_zps52e6182f.jpg) ![[Linked Image]](http://i961.photobucket.com/albums/ae97/BADZX/1182/319_zps7b8acf02.jpg) off to the shed.... SFA on the idiot box yet again.....  Yar, & this ere post be done without a sin'le drop o' rum passin' me lips
[Re: Pirate]
#273888 07/14/14 04:45 AM 07/14/14 04:45 AM |
Posts: 858 Victoria Australia | Masking tape and paper removed from the decks  the paper and tape stays on the hull sides untill the clear is applied, then we are done ![[Linked Image]](http://i961.photobucket.com/albums/ae97/BADZX/1182/322_zps59abb575.jpg) nice clean edge, sadly the fore-decks as clean an edge but they wont take long to get right..... clear coat in a couple of days when the green settles enough to give it a lite sand... ![[Linked Image]](http://i961.photobucket.com/albums/ae97/BADZX/1182/324_zps887254b2.jpg) Yar, & this ere post be done without a sin'le drop o' rum passin' me lips
[Re: Pirate]
#274121 07/24/14 05:30 AM 07/24/14 05:30 AM |
Posts: 858 Victoria Australia | clear on  the mains are a strange color in comparision to the front and rear decks, yet as you move around the boat the light has an amazing effect on the finish, it jumps from a dark brown to a very lite-honey color and then back dark again as you pass by... ![[Linked Image]](http://i961.photobucket.com/albums/ae97/BADZX/1182/326_zpse4214730.jpg) in this photo you can see just how dark the timber appears compared to the other decks ![[Linked Image]](http://i961.photobucket.com/albums/ae97/BADZX/1182/331_zps365371c6.jpg) Yar, & this ere post be done without a sin'le drop o' rum passin' me lips
[Re: Pirate]
#274122 07/24/14 05:37 AM 07/24/14 05:37 AM |
Posts: 858 Victoria Australia | that weird color change from another angle & using the light (notice how dark the other hull's deck is in the background) ![[Linked Image]](http://i961.photobucket.com/albums/ae97/BADZX/1182/328_zpsfb1c42a7.jpg) really hard to describe how the shift in your position and the light reflecting changes the decks appearance so much.... At first I was really pi$$ed at the darkness of the wood and was almost at the point where I had the primer out and was ready to color the mains green as they were..... but having walked past it 20 odd times a day I've found I actually love the effect, it constantly catches your eye. Others that have seen it have all asked how I got it to do that.....  Yar, & this ere post be done without a sin'le drop o' rum passin' me lips
[Re: Pirate]
#274124 07/24/14 05:56 AM 07/24/14 05:56 AM |
Posts: 858 Victoria Australia | At the Easter regatta @ Lake Bolac the rear traveller track came slightly loose in the +25knot "breeze", I never bothered to worry about it too much at the time figuring I'd deal with it later when I had the time. So having a bit up my sleeve I removed the track and found one stress fracture right at the point where the moving track met the immovable track..... took it to my straight table and just as I started clamping it down I noticed I now had 2 traveller tracks  out with the tig and bingo its a go-er again (beautiful alloy in this bar, some of the nicest alloy to tig-weld ever  ) ( NB: note the color change in the main deck again.....  ) ![[Linked Image]](http://i961.photobucket.com/albums/ae97/BADZX/1182/335_zps26c41002.jpg) The big surprise was the level of corrosion between the track and the rear beam, both have been anodised and there's remnants of a an unknown compound that looks like it was added as a sealer The corrosion has eaten its way under the anodising on the beam but hasn't touched the track at all, the other odd thing is the fixing screws (stainless) haven't been effected and neither has the area around the screw-hole, it seems largely between the fixing screw points where the corrosion has occurred. pics to come on that Yar, & this ere post be done without a sin'le drop o' rum passin' me lips
[Re: Pirate]
#274201 07/26/14 07:10 AM 07/26/14 07:10 AM |
Posts: 858 Victoria Australia | weird huh !!!  Tramp is back on now and is very tight all ready and I haven't even tensioned it up as yet. I had to soak the tramp in a 60lit drum of hot water to get it to soften up enough to fit it to the boat, even then it took me just under 2hours to get it all into place, I'll leave the cord tensioning until mid summer, it will be one of those 40degree hot days to string it in any tighter Yar, & this ere post be done without a sin'le drop o' rum passin' me lips
[Re: Pirate]
#274226 07/28/14 05:15 AM 07/28/14 05:15 AM |
Posts: 858 Victoria Australia | the learning curve continued......  I had the "TreadGrip" on the boat before the main deck replacement and re-painting of the fore decks, but I actually had it on the deck and the hull as well.....40mm on each so to speak. The stuff was good on the hull but not such a brilliant idea on the decks, I also didn't take it past the rear beam and only a couple of foot past the front beam. This time I have only applied it to the hulls side and I've gone from the transom to around the mid point of the fore deck. ![[Linked Image]](http://i961.photobucket.com/albums/ae97/BADZX/1182/341_zps7d0bc48b.jpg) Yar, & this ere post be done without a sin'le drop o' rum passin' me lips
[Re: Pirate]
#274229 07/28/14 05:31 AM 07/28/14 05:31 AM |
Posts: 858 Victoria Australia | I also narrowed down the strip of "TreadGrip"from 40mm down to 35mm.... huge weight savings right there ![[Linked Image]](http://i961.photobucket.com/albums/ae97/BADZX/1182/347_zps3122c2ac.jpg) I'll be replacing the beam bolts next (when the order arrives or if I have to steal them from Karp) & hopefully there will be some 1 1/4" monel rivets in the bag too for the traveller bar to rear beam fixing. Not in the above pic.... the front hatches are now in and the "TreadGrip" is dry and masking tape removed..... Re-paint the front beam is coming up soon enough  Yar, & this ere post be done without a sin'le drop o' rum passin' me lips
1 registered members (soulofasailor),
1,861
guests, and 23
