| Re: New UK designed and built foiling catamaran
[Re: Karl_Brogger]
#274325 07/31/14 04:12 AM 07/31/14 04:12 AM |
Posts: 98 | singlehand? (I don't have any friends) I had heard that Karl  ......but yes it has been designed to be sailed single handed if desired | | | Re: New UK designed and built foiling catamaran
[Re: Tony_F18]
#274328 07/31/14 05:20 AM 07/31/14 05:20 AM |
Posts: 98 | It does look more difficult to launch from the beach compared to the 'L' foils. The foils fully retract to the hull surface for launching and landing.... | | | Re: New UK designed and built foiling catamaran
[Re: Tony_F18]
#274334 07/31/14 08:45 AM 07/31/14 08:45 AM |
Posts: 5,590 Naples, FL | It does look more difficult to launch from the beach compared to the 'L' foils. Like those foils could become "ankle biters" if you're not careful? (this from a guy who still gets "bit" on the shin by the dang trailer hitch... you'd think I'd have learned by now)
[Re: NacramanUK]
#274337 07/31/14 12:18 PM 07/31/14 12:18 PM |
Posts: 2,584 +31NL | It does look more difficult to launch from the beach compared to the 'L' foils. The foils fully retract to the hull surface for launching and landing.... How do you insert the boards when you are on the beach? Won't the T foil break when you pull the boat on its side (assuming they enter from the bottom). | | | Re: New UK designed and built foiling catamaran
[Re: Tony_F18]
#274340 07/31/14 01:12 PM 07/31/14 01:12 PM |
Posts: 98 | It does look more difficult to launch from the beach compared to the 'L' foils. The foils fully retract to the hull surface for launching and landing.... How do you insert the boards when you are on the beach? Won't the T foil break when you pull the boat on its side (assuming they enter from the bottom). It weighs 75kgs.......you get someone to lift the bows or stern on the beach and insert from below.......designer is going to do a video this weekend of the whole process.....
[Re: NacramanUK]
#274343 07/31/14 01:59 PM 07/31/14 01:59 PM |
Posts: 1,246 Orlando, FL | It does look more difficult to launch from the beach compared to the 'L' foils. The foils fully retract to the hull surface for launching and landing.... How do you insert the boards when you are on the beach? Won't the T foil break when you pull the boat on its side (assuming they enter from the bottom). It weighs 75kgs.......you get someone to lift the bows or stern on the beach and insert from below.......designer is going to do a video this weekend of the whole process..... Well Karl, that eliminates sailing UNI.
USA 777
[Re: Tony_F18]
#274346 07/31/14 02:23 PM 07/31/14 02:23 PM |
Posts: 98 | Ah,that makes sense. Missed the part about it weighing 75kg. Hope you bring it to Texel next year. It will be there.... | | | Re: New UK designed and built foiling catamaran
[Re: tback]
#274347 07/31/14 02:38 PM 07/31/14 02:38 PM |
Posts: 4,119 Northfield Mn | Well Karl, that eliminates sailing UNI. I'm thinking stick em in before it even comes off the trailer. And certainly before you rig it. Boards would probably be the first thing to go in.
[Re: NacramanUK]
#274364 08/01/14 01:25 PM 08/01/14 01:25 PM |
Posts: 190 | | | | Re: New UK designed and built foiling catamaran
[Re: NacramanUK]
#274376 08/02/14 10:20 AM 08/02/14 10:20 AM |
Joined: Jan 2008 Posts: 3,655 Portland, Maine ThunderMuffin
Posts: 3,655 Portland, Maine | It does look more difficult to launch from the beach compared to the 'L' foils. The foils fully retract to the hull surface for launching and landing.... How do you insert the boards when you are on the beach? Won't the T foil break when you pull the boat on its side (assuming they enter from the bottom). It weighs 75kgs.......you get someone to lift the bows or stern on the beach and insert from below.......designer is going to do a video this weekend of the whole process..... Make sure the rigging at the top of the stick is squared away before you put the boards in. No flipping that bitch over on her side on the beach. | | | Re: New UK designed and built foiling catamaran
[Re: ThunderMuffin]
#274379 08/03/14 08:38 AM 08/03/14 08:38 AM |
Posts: 12,310 South Carolina | With the light weight, it's probably possible to tip it over on the bows.
Jake Kohl | | | Re: New UK designed and built foiling catamaran
[Re: NacramanUK]
#274699 08/14/14 06:54 AM 08/14/14 06:54 AM |
Posts: 2,844 42.904444 N; 88.008586 W | This is so excellent. I'm predicting that many boats will be made and sailed with foiling design in the next few years. Sorry Nacra- but your half so designs so far don't touch this- yet. Nacra? Still not predicting earthquakes, or anything about the temperature though.
F-18 Infusion #626- SOLD it!
1,174
guests, and 41
