Page 4 of 6 1 2 3 4 5 6
Re: 1101........ Scorpian's rebuild [Re: Pirate] #274734
08/15/14 05:11 AM
08/15/14 05:11 AM
Victoria Australia
Pirate Offline OP
Pirate  Offline OP
Victoria Australia
and that all important test fit grin
Both ends of the new inwale have had the shaping treatment as has both points under the beam blocks, the plan being that I'll slip one end in and then bend the inwale enough to slip in the other end..... obviously this will happen once the resin goes in, not going to over flex the new timber with instal and removals for no real reason
wink
Kingy
& now Mosquitos #1182 & #1740
Re: 1101........ Scorpian's rebuild [Re: Pirate] #274735
08/15/14 05:15 AM
08/15/14 05:15 AM
Victoria Australia
Pirate Offline OP
Pirate  Offline OP
Victoria Australia
the new inwales are glued in...
I slipped the foams into place and clamped it all up so the resin would harden with the new inwales set in the right curve
(this pic is mid installation )
Kingy
Re: 1101........ Scorpian's rebuild [Re: Pirate] #274736
08/15/14 05:19 AM
08/15/14 05:19 AM
Victoria Australia
Pirate Offline OP
Pirate  Offline OP
Victoria Australia
Phill has brought me a new toy....
a pneumatic stapler .... look out world grin
the accuracy isn't there yet but with practise wink
Kingy
Re: 1101........ Scorpian's rebuild [Re: Pirate] #274737
08/15/14 05:24 AM
08/15/14 05:24 AM
Victoria Australia
Pirate Offline OP
Pirate  Offline OP
Victoria Australia
a small smear of my sawdust/resin mix over the inwale connections fixes any cavities and adds that extra bit of strength to the joint, these will be mostly sanded back to near nothing in the end anyway but either way they needed that small amount of fill
Kingy
Re: 1101........ Scorpian's rebuild [Re: Pirate] #274738
08/15/14 05:27 AM
08/15/14 05:27 AM
Victoria Australia
Pirate Offline OP
Pirate  Offline OP
Victoria Australia
stringers being dry fitted..... note the nice curve of the new inwale even tho its now not supported by the foams
Kingy
Re: 1101........ Scorpian's rebuild [Re: Pirate] #274739
08/15/14 05:31 AM
08/15/14 05:31 AM
Victoria Australia
Pirate Offline OP
Pirate  Offline OP
Victoria Australia
Phill chipping away at even more daggy bits
wink
Kingy
Re: 1101........ Scorpian's rebuild [Re: Pirate] #274781
08/17/14 05:09 AM
08/17/14 05:09 AM
Victoria Australia
Pirate Offline OP
Pirate  Offline OP
Victoria Australia
Big weekend.... tired
The new inwales are shaped and ready for the decks
All the stringers are now cut and the rebates are also cut in
All the foams have had the final shaping and fit well
Slots in the foams for the stringers are done
Sawdust filler has been applied to any spots that needed filling
The last of the fat has been trimmed and another 2 vacuum bags of rubbish has been sucked out
The old repairs have a bit of 40gsm cloth added and glassed in place
The "Bolac hole" has been repaired from the inside (out side yet to be done)
Special mods have also been completed......
Now we rest for a couple of days while everything sets
grin
Kingy
Re: 1101........ Scorpian's rebuild [Re: Pirate] #274877
08/21/14 03:17 AM
08/21/14 03:17 AM
Victoria Australia
Pirate Offline OP
Pirate  Offline OP
Victoria Australia
got a bit of time now while resin sets..... update time wink
this is one of the many "fat reduction" steps we took, could have gone further but we wanted to retain some strength where it was needed...
Kingy
Re: 1101........ Scorpian's rebuild [Re: Pirate] #274878
08/21/14 03:19 AM
08/21/14 03:19 AM
Victoria Australia
Pirate Offline OP
Pirate  Offline OP
Victoria Australia
more sawdust & resin repairs...
Kingy
Re: 1101........ Scorpian's rebuild [Re: Pirate] #274879
08/21/14 03:22 AM
08/21/14 03:22 AM
Victoria Australia
Pirate Offline OP
Pirate  Offline OP
Victoria Australia
several old ply repairs have been removed and new internal replacement resin & cloth (40gsm) has been laid over the old damage
Kingy
Re: 1101........ Scorpian's rebuild [Re: Pirate] #274880
08/21/14 03:25 AM
08/21/14 03:25 AM
Victoria Australia
Pirate Offline OP
Pirate  Offline OP
Victoria Australia
the "Bolac hole" has been repaired from the inside using the ply patch we threw at it @ Bolac as a 'mould' as such....
the hole uncovered....
this will be sanded back later on and filled to a smoooooth finish when the hulls get the make-over
Kingy
Re: 1101........ Scorpian's rebuild [Re: Pirate] #274881
08/21/14 03:30 AM
08/21/14 03:30 AM
Victoria Australia
Pirate Offline OP
Pirate  Offline OP
Victoria Australia
and the foams get glued in at last, the 2 foams under the main deck nearest the front beam have at this stage been left out so further work can be done without the foams being damaged and to allow an easy access to the area, hopefully they can go in shortly....
Kingy
Re: 1101........ Scorpian's rebuild [Re: Pirate] #274882
08/21/14 03:31 AM
08/21/14 03:31 AM
Victoria Australia
Pirate Offline OP
Pirate  Offline OP
Victoria Australia
foredeck foams have all be fitted and glued in
smile
Kingy
Re: 1101........ Scorpian's rebuild [Re: Pirate] #274883
08/21/14 03:35 AM
08/21/14 03:35 AM
Victoria Australia
Pirate Offline OP
Pirate  Offline OP
Victoria Australia
As of last night.....
(Club's AGM was held so no works was done...)
resin is still a bit too soft to do too much tonight but there's a few things I need to get on with
wink
Kingy
Re: 1101........ Scorpian's rebuild [Re: Pirate] #274930
08/23/14 05:40 PM
08/23/14 05:40 PM
Victoria Australia
Pirate Offline OP
Pirate  Offline OP
Victoria Australia
Phill checking the alignment of the foams new stringer supports....
The new stringers will be fitted after the resin sets and as I've used in the past the stringers are WRC
(Western Red Cedar)
Kingy
Re: 1101........ Scorpian's rebuild [Re: Pirate] #274931
08/23/14 05:42 PM
08/23/14 05:42 PM
Victoria Australia
Pirate Offline OP
Pirate  Offline OP
Victoria Australia
Rear deck stringers have been fitted to both hulls
wink
Kingy
Re: 1101........ Scorpian's rebuild [Re: Pirate] #274932
08/23/14 05:53 PM
08/23/14 05:53 PM
Victoria Australia
Pirate Offline OP
Pirate  Offline OP
Victoria Australia
The front stay mounts had seen some action over the years and the repairs were somewhat suspect, the ply patches were removed and the old repairs inspected so we could understand what had transpired to cause such repairs.
Once happy with what we'd seen we elected to glass a simple overlay to the ply and refit the hardware to the gelled resin. Once fully cured the nuts got an extra bit of tightening.
obviously the deck line & stringer slots will be cut in later
wink
Kingy
Re: 1101........ Scorpian's rebuild [Re: Pirate] #274933
08/23/14 06:08 PM
08/23/14 06:08 PM
Victoria Australia
Pirate Offline OP
Pirate  Offline OP
Victoria Australia
the new foam stringer supports also attach to both the gunwales.
and the chainplate also got re-worked....
The old deck was 10mm ply and we're going to 4mm ply so the plate was going to sit way above the deck, the old holes were filled with the sawdust-resin, then a small piece of 40gsm cloth was applied so it just covered the original ply doubler.
Phil made some new alloy internal plates and these were also resined into place along with the foams stringer support
The new holes for the chainplates were ~10mm lower than the old holes and as you can see the plate's shackle hole is well clear of the gunwale and should have a ~2mm clearance once the deck is fitted.
The other advantage we built in was the resined in internal plate, this will remain in place once the nuts and bolts have been removed and will make life easy to reinstall the plates after all the painting etc has been completed.
Kingy
Re: 1101........ Scorpian's rebuild [Re: Pirate] #274974
08/26/14 02:21 AM
08/26/14 02:21 AM
Victoria Australia
Pirate Offline OP
Pirate  Offline OP
Victoria Australia
front stringers set in....
Kingy
Re: 1101........ Scorpian's rebuild [Re: Pirate] #274975
08/26/14 02:24 AM
08/26/14 02:24 AM
Victoria Australia
Pirate Offline OP
Pirate  Offline OP
Victoria Australia
someone asked me how I get the tension on the boards that are holding the newly glued in stringers up to a tight fit....
other than pulling as hard as I can on the old hay-band.....
little offcuts of what I have laying around and handy (stringer offcuts in this case) are slipped in to add that final pinch of pressure
Kingy
0 registered members (), 297 guests, and 70 spiders.
Posts267,059
