by soulsailor. 03/11/25 11:57 AM
C2 and Viper Owners #280472
09/09/15 12:51 PM
09/09/15 12:51 PM
Clermont, FL, USA
David Ingram Offline OP
Clermont, FL, USA
From Jill on Facebook:
https://www.facebook.com/robbie.daniel.18?fref=ts
F16 VIper and F18 C2 Shroud anchor upgrade. If you have a Viper and have not had your Shroud anchors upgraded and are coming to the Nationals in Sarasota, please contact Jill at 727-734-0799 or [email protected] We are going to try and replace these at the F16 Nationals in Sarasota in October. Replacement days will be Oct 16 & 17 for the C2.s and the 27th & 28th for the Vipers. You must be on the list to do it then.
F18 USA 242
http://www.solarwind.solar
Re: C2 and Viper Owners [Re: David Ingram] #280473
09/09/15 03:03 PM
09/09/15 03:03 PM
SE MI / NE IN
rehmbo Offline
rehmbo  Offline
SE MI / NE IN
What's the failure mode? I'm the 2nd owner, so not sure if my '10 C2 was ever done. Anchors are rock solid, but...
Jeff R
H18, C2 USA1193
cramsailing.com
crescentsail.com
Re: C2 and Viper Owners [Re: David Ingram] #280474
09/09/15 04:43 PM
09/09/15 04:43 PM
Scarecrow
Scarecrow
They snap off inside the hull. Check with Jill or Goodall Design when they stopped shipping boats that had the issue. You'll be able to tell if yours have been fixed post delivery because there will be a 1 inch scar in the gelcoat around the chain plate.
PM me your email address and I'll send you Jim Boyer's guide on how to effect the repair.
Re: C2 and Viper Owners [Re: David Ingram] #280475
09/09/15 06:09 PM
09/09/15 06:09 PM
SE MI / NE IN
rehmbo Offline
rehmbo  Offline
SE MI / NE IN
I had heard of some kind of campaign to replace these, but have to admit I hadn't taken it very seriously. Not liking the idea of a sudden failure. Not sure when or if I'll have my boat in Florida this winter. Will send a pm.
Jeff R
H18, C2 USA1193
cramsailing.com
crescentsail.com
Re: C2 and Viper Owners [Re: David Ingram] #280476
09/09/15 06:28 PM
09/09/15 06:28 PM
Scarecrow
Scarecrow
Edited highlights or the repair:
Re: C2 and Viper Owners [Re: David Ingram] #280477
09/09/15 06:31 PM
09/09/15 06:31 PM
Scarecrow
Scarecrow
then...
Re: C2 and Viper Owners [Re: David Ingram] #280478
09/09/15 06:32 PM
09/09/15 06:32 PM
Scarecrow
Scarecrow
Finally..
Re: C2 and Viper Owners [Re: ] #280479
09/09/15 07:41 PM
09/09/15 07:41 PM
catman Offline
catman  Offline
Is that tang just a bent piece of stainless with a nut holding it on the threaded bit? Would have liked to see the new tang before it was installed.
Re: C2 and Viper Owners [Re: David Ingram] #280481
09/09/15 08:03 PM
09/09/15 08:03 PM
Scarecrow
Scarecrow
No the tang is a machined lug with a drilled and tapped thread that screws down onto the thread shown in the third last image. I believe from Rehmbo that this detail might have changed as he describes his as more like an eye bolt.
Re: C2 and Viper Owners [Re: David Ingram] #280482
09/10/15 04:14 AM
09/10/15 04:14 AM
Hobart, Tasmania, Oz.
Dazz Offline
Dazz  Offline
Scarecrow, that is the old capricorn tangs, the C2 / Viper uses and eye bolt. this has nothing to do with that repair nor are there any forecast failures.
C2 AUS 222 by Goodall design
"Darph Bobo"
Re: C2 and Viper Owners [Re: David Ingram] #280483
09/10/15 04:49 AM
09/10/15 04:49 AM
Scarecrow
Scarecrow
So what is the upgrade Jill and Robbie are offering to do?
Re: C2 and Viper Owners [Re: David Ingram] #280484
09/10/15 05:08 AM
09/10/15 05:08 AM
Dazz Offline
Dazz  Offline
changing metric eye bolts for imperial ones.. or so i have heard...
"Darph Bobo"
Re: C2 and Viper Owners [Re: Dazz] #280486
09/10/15 07:02 AM
09/10/15 07:02 AM
Clermont, FL, USA
Clermont, FL, USA
That is not correct. The eye bolts have been known to fail and are being swapped out for larger ones. The new ones may be imperial but that has nothing to do with the issue.
Jeff, I doubt your boat was been swapped out, email Jill and ask her to send you the hardware and the instructions I'm sure it's not that difficult.
F18 USA 242
Re: C2 and Viper Owners [Re: David Ingram] #280487
09/10/15 07:33 AM
09/10/15 07:33 AM
Jeff, I doubt your boat was swapped out, email Jill and ask here to send you the hardware and the instructions I'm sure it's not that difficult.
That is pretty incredible dealer support...I have to say.
Re: C2 and Viper Owners [Re: Jake] #280488
09/10/15 08:10 AM
09/10/15 08:10 AM
SE MI / NE IN
rehmbo Offline
rehmbo  Offline
SE MI / NE IN
In my case its not their fault. I'm about 1200 miles from them and haven't had my boat in FL in a couple years (something I need to rectify this year!)
Jeff R
H18, C2 USA1193
cramsailing.com
crescentsail.com
Re: C2 and Viper Owners [Re: Jake] #280489
09/10/15 09:09 AM
09/10/15 09:09 AM
Clermont, FL, USA
Clermont, FL, USA
100% agree! To be honest it's the only reason I'm on a C2 instead of an Infusion.
F18 USA 242
Re: C2 and Viper Owners [Re: David Ingram] #280490
09/10/15 10:20 AM
09/10/15 10:20 AM
I noticed a rust stain on the first few pictures showing the damage.
Wonder if that stain's appearance indicated some sort of crevice corrosion prior to the ultimate failure?
Re: C2 and Viper Owners [Re: rehmbo] #280491
09/10/15 10:23 AM
09/10/15 10:23 AM
Clermont, FL, USA
Clermont, FL, USA
Yep! Steeplechase, Tradewinds and Charlotte Harbour is a great winter series. Plus there is that week long event in October :-)
F18 USA 242
Re: C2 and Viper Owners [Re: David Ingram] #280492
09/10/15 10:25 AM
09/10/15 10:25 AM
Solomon's Island, MD
samc99us Offline
samc99us  Offline
Infusion support has been fixed-Nacra NA is under new management. Our Mk. 2 is very well built and very quick.
Scorpion F18
Re: C2 and Viper Owners [Re: Jake] #280493
09/10/15 12:05 PM
09/10/15 12:05 PM
Eastern NC, USA
tshan Offline
tshan  Offline
Eastern NC, USA
My first though, as well. Good work.
0 registered members (), 1,653 guests, and 20 spiders.
Posts267,060
