Trampoline Lacing Selection #2858
09/27/01 05:29 PM
09/27/01 05:29 PM
Anonymous OP
Anonymous OP
What is the best material for trampoline lacing? On my old boat I used 1/2" tubular nylon webbing which was good in that it laid flat. My new (used) boat came with 3/8 shock cord that seems good because of its self tightening properties. I plan to do some racing so the performance characteristics are more important to me than comfort or convenience. Thank you for your help.
<br>
<br>Alan M<br><br>
2827- (52 downloads)
Re: Trampoline Lacing Selection #2859
09/28/01 08:56 AM
09/28/01 08:56 AM
Anonymous OP
Anonymous OP
I have used both materials you describe over my years with the H16. I live at high altitude, and the sun on a bungee cord lacing, together with water exposure, shortens the life of a bungee system to one season for me, even when the tramp is covered between use. Also, super tension on the 3/8" bungee seemed to reduce its useful life for me. I suppose salt water would to the same thing, but I have no experience.
<br> I also wonder whether the shock cord system REALLY makes the boat tighter because when a full crew/skipper is on my tramp, it stretches the bungees. Unless you get them really tight, the tramp will sag a little in use, which would seem to cause dynamic changes to the system.
<br>I have returned to a 1/2" line system and had both of my tramps double grommetted. With extra care in tightening this line, it makes the best tramp tension for me. I also noticed subtle handling improvements which I attribute to the tightening of the whole hull--tramp alignment.
<br>I will be interested in other views from other H16 sailors. JDB
<br><br><br>
Re: Trampoline Lacing Selection #2860
09/28/01 04:07 PM
09/28/01 04:07 PM
Santa Fe, New Mexico
Greg Offline
Greg  Offline
I just replaced my lacing and used static climbing rope (9mm), but I am not sure I am happy with it because when it gets wet it stretches. Hobie sells tramp lacing, but I don't know anything about its characteristics. I bet it doesn/t stretch as much when wet.
<br>Greg,
<br>H14,H16<br><br>
Re: Trampoline Lacing Selection [Re: Greg] #2861
09/29/01 06:21 PM
09/29/01 06:21 PM
heavyair14 Offline
heavyair14  Offline
I use 1/4 dacron on my Hobie 14 tramps and it seems to hold up fine. The tramps are nice and tight. I'd recommend replacing tramp lacing line every 3-5 years or whenever it starts to wear, break down, or chafe.<br><br>
2871- (58 downloads)
Hobie 16 sail #102653
0 registered members (), 332 guests, and 120 spiders.
