IIRC, the noodles weight more than the foam thats in there right now. The reason they suggested noodles is because they are easy to fit through deck portholes. If your foam has lost its plastic covering, it will start to erode away over time, therefore losing your positive buoyancy. So noodles would be better than nothing.
Can't help you with the rudders, only got one set myself
