| Re: Fiberglass Gelcoat Repair on Hull Bottoms
[Re: Tornado]
#37900 09/20/04 03:11 PM 09/20/04 03:11 PM |
Posts: 12,310 South Carolina | From what I found, in general, you do not want to use a Polyester resin over cured epoxy because it will not bond well. However, epoxy will bond well to polyester and because of this it's safe to use epoxy to make repairs on most fiberglass substrates. This information is on the West System site - there's a lot of usefull stuff there.
Jake Kohl | | | Re: Fiberglass Gelcoat Repair on Hull Bottoms
#37901 09/20/04 04:34 PM 09/20/04 04:34 PM |
Posts: 1,200 Vancouver, BC | This makes sense...but why is polyester-based gelcoat used on my epoxy boat? This is how it comes from the factory. Is it put on prior to full epoxy cure? Mike. From what I found, in general, you do not want to use a Polyester resin over cured epoxy because it will not bond well. However, epoxy will bond well to polyester and because of this it's safe to use epoxy to make repairs on most fiberglass substrates. This information is on the West System site - there's a lot of usefull stuff there.
[Re: Tornado]
#37902 09/20/04 10:19 PM 09/20/04 10:19 PM |
Posts: 12,310 South Carolina | I found this at the West System site http://www.epoxyworks.com/22/polyester.html There is a wealth of information (granted...it's probably a bit biased) at http://www.epoxyworks.com/ See the last few articles listed on the left for some great explanations. Understanding the materials Polyester resin laminates achieve their highest strength when the bonds between layers of fiberglass are chemical or primary bonds as opposed to mechanical or secondary bonds. The manufacturing process for polyester boats has been developed so that a chemical bond exists between the gelcoat and the laminate. When a polyester boat is built, polyester gelcoat is first sprayed onto the mold surface. The first layer of the laminate is then applied to gelcoat, which has not completely cured. The two layers eventually cure together with a chemical bond between them.
Applying gelcoat to a cured laminate relies on a mechanical bond. Because of the difference in curing chemistry, it is not possible to achieve a chemical bond between epoxy and polyester gelcoat. We developed some tests, to determine whether or not the mechanical bonds achieved between gelcoat and properly prepared, cured epoxy were strong enough to achieve a durable repair... the test information shown on the site indicates only a slight reduction in bond strength between epoxy and and a polyester gel coat and they were really focused on boats that were left in the water (the rumour was that because the gel coat will absorb water and the epoxy will not, that the bond will suffer).
[Re: carlbohannon]
#37904 09/21/04 09:49 AM 09/21/04 09:49 AM |
Posts: 833 St. Louis, MO, | I see a lot of people use epoxy but I don't see why. I think polyester sticks best to polyester. Plus polyester is a ton cheaper. I think polyester is easy to work with also. If I were to be working with preexisting epoxy then I would stick with epoxy.
Mike Hill
Mike Hill N20 #1005
[Re: carlbohannon]
#37905 09/21/04 02:21 PM 09/21/04 02:21 PM |
Posts: 1,200 Vancouver, BC | Thanks Carl, didn't know this was how the boats came from the factory. My boat was originally a light pink color (this from the original owner and also from some scratches on the deck). The second owner had it re-painted to the off-white/grey, I believe with Imron, just prior to selling to me. anyway, I think my gelcoat repair on the epoxy filled puncture/scratch will hold up...it's certainly stuck well and I don't keep the boat in the water, which is sounding like the main reason this issue is of concern. Mike. Mike
Your Tornado is a Marstrom? Marstroms come from the factory painted with Spies Hecker auto paint. The cloest US equivilent is IMRON pure white base. A good auto paint shop can make up some 1 part touchup paint for you.
If you will do a search, you will find a thread on this from a couple of years ago.
I can't imagine anyone coating an expoxy boat with gelcoat. You would have to prime it to get it to stick
728
guests, and 115
Mod | | Forums26 Topics22,405 Posts267,058 Members8,150 | Most Online2,167 Dec 19th, 2022 | | |
