To answer that is simple.
Because Cats sail faster than mono's
Go to the page :
http://www.geocities.com/kustzeilen/sailvectors.htmland look at the first vector drawing that you encounter.
Than realize that a sailrig has a minimum angle of attack requirement. At smaller angles the saildrive reduces quickly AND / OR the sail will start to luff. Ergo a minimum angle of attack is required.
Now look at the two vector balances in the upper right corner of the vector drawing.
Assume that the most upper and most right one represents the catamaran and that the one just to the left and below that is the monohull.
It is clear that for both boats to sail on the same course (black dotted line) at their typcial speeds (cat > mono) that the angle of attack that the rig of the cat experiences is (significantly) smaller than that of the monohull. (Angle between the blue arrown and the black one laying along the travelled course)
Assume that both boats use the same rigs, a rig that has a minimal angle of attack of say 25 degrees, than is will be apparent that the mono must point higher at its slower speed than the catamaran to have its rig operate at the same minimal angle. If is points equally to the cat and the cat is at the minimal angle than the mono is sailing suboptimaly by sailing at an angle of attack that is larger than the optimal value.
So in simple terms with increasing boatspeeds a boat using the same rig at a constant wind must point lower to keep the apparent wind at the same optimal angle (Angle of attack).
Now is the winds increases than the boat can again point up a little when not changing its boatspeed. This is also a reason why mono's that have reached their max hull speed tend to point higher still.
Hope this make sense to you. If not than never ask question like these again, for they can only be answered when you learn to understand the Aerodynamics of sailing.
