| Re: Will this adjustable trapeze system work?
[Re: Robi]
#46855 04/07/05 05:23 AM 04/07/05 05:23 AM |
Posts: 12,310 South Carolina | The boat is rigged perfectly, but there is NOTHING wrong with making personal changes. Oh lord no! There's not an F18 out there that is rigged identically!
Jake Kohl | | | Re: Will this adjustable trapeze system work?
[Re: Robi]
#46856 04/07/05 06:03 AM 04/07/05 06:03 AM | Anonymous
| Anonymous
Unregistered | Robi, what are you trying to accomplish? Are you saying that the "normal" trapeze system you got with the boat was not adjustable while on the wire and you are trying to figure out a simple way to make it adjustable without adding any parts?
Exactly you cannot adjust it while on the wire. Robi, it looks to me like the set-up in the Murrays catalog that was referred to is also adjustable in the way you are wanting, but also provides the upward tension that several people have described. My boat has the arrangement that you are describing, but after reviewing the posts here, I can see the advantages of having the bungy attached to the top of the ring rather than the bottom, and think I need to make some modifications. I don't have a lot of trapezing experience, but I don't find it real easy to get in and out of the trapeze with my current arrangement. Mark. | | | Re: Will this adjustable trapeze system work?
#46857 04/07/05 07:04 AM 04/07/05 07:04 AM |
Posts: 12,310 South Carolina | Mary had some good advice up top too. here are my rules for rigging changes: 1) Even if the changes you are planning are proven on other boats NEVER, EVER, make more than 2 rigging changes between sailing sessions. 2) if you are trying something that is unproven (if #3 doesn't apply), NEVER, EVER make more than 1 rigging change between sailing sessions. 3) look at other boats - if you like the way something looks, talk to the owner how to make sure they are happy with it before you steal the idea. 4) whenever possible, temporarily mount things to prove out the positions using line or other mounting points to avoid drilling extra holes....I hate extra holes or having to remake rigging that I messed up. 5) Bounce ideas off your crew whenever possible. It helps them feel like you care (even if you don't) 6) Crew the boat occasionally to see what hell you have unleashed on that person by the latest change. These rules have done me pretty well on the F18 and although we've been tweaking the boat for 6 months, we've got some pretty fancy yet simple and streamlined rigging, are almost rigged how we like it, and haven't had to undo anything we've added.
#46858 04/07/05 07:30 AM 04/07/05 07:30 AM |
Posts: 1,253 Columbia South Carolina, USA | I havent read the entire post so escuse me if someone has already said this. In wouters diagram it looks as if the port and starboard bungees are connected. I would advise against connecting any of the bungees to each other. If one breaks, then 2 are free to get all tangled up. Double your bungee(run bungee to other side of the hull and back) this will give you plenty of slack to go around the forestay if that happens in a pitchpole, but will also allow you to keep tension on the trap handle. David www.teamseacats.com
[Re: Robi]
#46860 04/07/05 07:48 AM 04/07/05 07:48 AM |
Posts: 3,293 Long Beach, California | Dude - can't wait to see that boat on the water again... I like the way Matt thinks.
I have to agree with what folks are saying about the bungee pulling up on the ring. The adjustable idea has its applications, and I'm sure you'll work out something that fits your need. I've sailed with both, but when setting up a 2005 Tiger (which comes stock with the adjustable system for the crew's trap) I took it off. With the handle rings, there are two places to hook in if I need to get my butt out of big waves, and I grab the skipper's trap if I'm on the wire downwind.
You're basic point, though, is the most valid one - set it up for what you prefer most. Tinkering is fun. Walking around the beach at Worlds gave me the opportunity to see how people from around the world rig stuff - Peter Dubbelaar (crewing for Steve Fields of Hobie Australia) was particularly helpful in pointing out some simple things that the Aussies do to clean up the tramp, eliminate sharp edges, etc... wish I'd had a camera handy.
Post a pic of whatever you work out.
[Re: John Williams]
#46861 04/07/05 10:30 AM 04/07/05 10:30 AM |
Posts: 606 League City, TX | Walking around the beach at Worlds gave me the opportunity to see how people from around the world rig stuff - Peter Dubbelaar (crewing for Steve Fields of Hobie Australia) was particularly helpful in pointing out some simple things that the Aussies do to clean up the tramp, eliminate sharp edges, etc... wish I'd had a camera handy. John, I took a load of pictures of their rigging on Tuesday when the sailing was cancelled. I'll post a few tonight. Chris. | | | Re: Will this adjustable trapeze system work?
[Re: flumpmaster]
#46862 04/07/05 10:44 AM 04/07/05 10:44 AM |
Posts: 3,293 Long Beach, California | Excellent! Where should we look? I particularly noted wide variations in cunningham (main and jib) set ups and self-tackers. Liked the internal stuff that came out of the beams... Good thinking - glad someone had their wits about them... I only remember Don Q....
#46863 04/07/05 10:58 AM 04/07/05 10:58 AM |
Posts: 263 SC | 5) Bounce ideas off your crew whenever possible. It helps them feel like you care (even if you don't) You think I don't read this Jake?!?! LOL
Always borrow money from a pessimist. He won't expect it back.
[Re: dave mosley]
#46865 04/07/05 12:06 PM 04/07/05 12:06 PM |
Posts: 12,310 South Carolina | You think I don't read this Jake?!?! LOL Oh Crap!
[Re: Robi]
#46867 04/07/05 05:49 PM 04/07/05 05:49 PM |
Posts: 1,911 South Florida & the Keys | you guys don't EVEN want to see the trap rig on my ARC. I can get launched (liked I usuallt do) up to 50 yards and still not snap the bungi. I use the no cut, non adjustable style with a classic dogbone. You can use either enclosed area which gives you about 4" dif.
Eric Arbogast ARC 2101 Miami Yacht Club | | | Re: Will this adjustable trapeze system work?
[Re: arbo06]
#46868 04/08/05 08:18 AM 04/08/05 08:18 AM |
Posts: 778 Houston | you guys don't EVEN want to see the trap rig on my ARC. I can get launched (liked I usuallt do) up to 50 yards and still not snap the bungi. I use the no cut, non adjustable style with a classic dogbone. You can use either enclosed area which gives you about 4" dif. Plus it weighs less and has fewer things to break and drop you into the water. I have been thinking about a similiar system for the ball and socket system | | | Re: Will this adjustable trapeze system work?
[Re: carlbohannon]
#46869 04/08/05 08:25 AM 04/08/05 08:25 AM |
Posts: 5,558 Key Largo, FL & Put-in-Bay, OH... | Carl, For the ball-and-socket system, though, you only have the option of one level, right? As opposed to two options using a dogbone. (I've never used the ball-and-socket, so I don't know.) | | | Re: Will this adjustable trapeze system work?
[Re: Robi]
#46874 04/08/05 09:33 PM 04/08/05 09:33 PM |
Posts: 390 | Robi, You have become a clone of the dutch doofus. Misquoting me just to try to justify your statements. I DID NOT SAY "will not work"". I said "does NOT work properly." and "CANNOT work properly". The key word is "PROPERLY". Is english not your native language?
Why did you say "someone using it just fine" when two hours before you made that statement the person in question clearly stated, on the f16 forum, that the bungi HAD PULLED THE DOGBONE OFF SEVERAL TIMES exactly as I had warned? He even mentioned looking up a post about a system which puts tension on the hook. Obviously, he wants to change his.
I am not "confused with the drawing." As a Civil Engineer, I have created and interpreted drawings for 25 years. You may have drawn it wrong, but I did not read it wrong. Except for the bungi cord, your "design" is very old and very common.
Let's check the count. 1 vote for your exact system (wooznik) 11 votes against it (including Worrell 1000, Tybee 500, Tornado, and other experienced sailors)
But you people seem to want to listen to a person who has very little racing experience.
Are you still so confident? | | |
1 registered members (Xarisaz),
629
guests, and 80
Mod | | Forums26 Topics22,405 Posts267,058 Members8,150 | Most Online2,167 Dec 19th, 2022 | | |
