| Re: Trapeze
[Re: newbiesailor]
#51553 06/22/05 06:09 PM 06/22/05 06:09 PM |
Joined: Mar 2005 Posts: 2,074 Northfield,NH USA bullswan
Posts: 2,074 Northfield,NH USA | You come back in when you want to/ need to to tack or whatever. The process is simply the reverse of going out. The hulls are both in the water presumably when you come in. Hope that helps.... Greg
The nice part about being a pessimist is that you are constantly being either proven right or pleasantly surprised. - George Will "It's not that liberals aren't smart, it's just that so much of what they know isn't so" -Ronald Reagan | | | Re: Trapeze
[Re: newbiesailor]
#51555 06/23/05 07:51 AM 06/23/05 07:51 AM |
Posts: 1,884 Detroit, MI | The whole point of trapezing is to counter-balance the heeling of the boat. It allows you to carry more power (=speed) when sailing in higher winds. When you are flying a hull, you want to stay out on the trapeze to help balance the boat. Coming in off the wire would make the hull fly even higher (all else being equal, like not letting the sail out). As a skipper, most of us will power up the boat until the windward hull is "light" - not flying, but definitely thinking about it. You go out on the wire, sheet in to fully power up the boat and support your weight out there and off you go! | | | Re: Trapeze
[Re: hrtsailor]
#51557 06/24/05 02:28 AM 06/24/05 02:28 AM |
Joined: Mar 2005 Posts: 66 Durban, KwaZulu-Natal, South A... Clint_SA
Posts: 66 Durban, KwaZulu-Natal, South A... | Getting back in just takes practise-like getting out. I try get the boat under control before going it. So going in when the hull is flying is not a good idea (you will probably capsize). If you find the hull is constantly up, either release some main sheet, or head a little more up wind. This will flatten the boat. Also watch for gusts approaching before going in. Rather stay out until the gust has passed. Then almost swing in, bending your knees to conrtol it until your feet have to go in. Don't want take your weight off the cable until in. It might help putting the rear leg on the hull, just behind the pylon. With regards to crew, I prefer going in before my crew- not sure if this is correct. Maybe someone else can comment on this. Once in, rememebr that you don't have the extra weight out to balance the boat, so the hull will fly easier, so either head up a little if you need the time before taking or let the travellor out a whee bit:) Hope it helps. If anyone spots errors in this please correct me
Dubulamanzi
424
guests, and 36
