Peter,
I drilled them out before I used the dye. The dye would gum them up for sure. For your situation, some wide masking tape placed over the gromets and carefully cut around the perimeter with a utility razor (blade set to protrude a few millimeters only) would work pretty well. Then you could use the dye and save your gromets.
Dave
