Rating: 5
Page 3 of 3 1 2 3
Re: Righting an F17 [Re: Jake] #54031
01/18/06 08:24 PM
01/18/06 08:24 PM
Thailand
Buccaneer Offline
Buccaneer  Offline
Thailand
Sounds like a real fight for survival. How is it possible to build a single hander that you can’t right without some convoluted after market BS and two hours work?
Re: Righting an F17 [Re: Buccaneer] #54032
01/19/06 07:10 AM
01/19/06 07:10 AM
Holland
FastFlippie Offline
FastFlippie  Offline
Holland
Hello,
some comments regarding things I read.
There might be a disadvantage by loosening the downhaul.By that you might create a "baggy" shape of the mainsail.Thus alowing more weight pushing the mast down.
I sail a nacra5.5 mostly singlehanded, when I capsize I detach the main-sheet, so the sail sinks inline with the wanted righting motion.Then I put the daggerboard halfway in,making it stronger to stand on.After that I fasten myself to the righting line,pull out a (in the meantime become cold) beer and wait.Usually there is not enough time to finish my beer.
Reading all the articles there must be a solid solution to the righting problem when all combined.
Good luck and can someone please make the winter disappear?
P.
Re: Hoisting a PFD? [Re: Jake] #54033
01/21/06 01:08 PM
01/21/06 01:08 PM
uk
TEAMVMG Offline
TEAMVMG  Offline
uk
"Actually, I would probably get the hell out of the way while the rescue boat tries to right the catamaran - either by getting ON the rescue boat or jumping into the water and getting at least a boat length away along side."
OOer guys - never let go of the boat, thats priority number 1 in a capsize
Re: Righting an F17 [Re: FastFlippie] #54034
01/21/06 04:15 PM
01/21/06 04:15 PM
Victoria, Australia
C2 Mike Offline
C2 Mike  Offline
Victoria, Australia
Hello,
P.
Hi,
I've spent my fair share of time upside down on a few cats over the years. IMHO getting them upright is 95% technique with only a bit of brute force on most occasions. These days we run the downhaul under the tramp and that doubles as my righting rope. We have *never* removed the main from the sail to get the boat upright again. I understand what you are trying to achieve however it is simply not an issue.
BTW - middle of a glorious summer down here - expecting 110 deg F today
Michael
Re: Righting an F17 [Re: C2 Mike] #54035
01/21/06 08:31 PM
01/21/06 08:31 PM
2017 F18 Americas Site
Dan_Delave Offline
Dan_Delave  Offline
Michael
Yes it is winter here and the water is a bit on the cold side but we were able to get out for about 2 hours in about 12 to 14 knots today.
Page 3 of 3 1 2 3
0 registered members (), 376 guests, and 144 spiders.
