Page 3 of 4 1 2 3 4
Re: adding a spin to N6.0 [Re: PTP] #58907
10/14/05 10:01 PM
10/14/05 10:01 PM
Annapolis, MD
Mark Schneider Offline
Annapolis, MD
Wind surfer masts taper. You want the tip of your pole to stay put relative to the hoist position so that your spin luff remains constant. The tapered tip will probably not be stiff enough.
For a 6.0 pole you have to carry the pole fairly low with the front foil in place. So to keep the pole in column and not have it invert you need a dolphin striker. Secondly, If the pole isn't stiff enough it will take on a really interesting S shape at the tip.
I have seen too solutions. Scace purchased two carbon windsurfer poles and butted them together for his Tornado pole... the end diameter was then large enough to be stiff.
(Tornado's carry the pole fairly high without a front foil.)
Murphey on his P19 with a Nacra foil added the dolphin striker to keep from towing his bows in when he preloaded the pole. Then when he discovered that the tip was too soft he just kept laying up carbon cloth around the pole end to stiffen it up.
Take Care
Mark
crac.sailregattas.com
Re: adding a spin to N6.0 [Re: PTP] #58908
10/15/05 01:48 PM
10/15/05 01:48 PM
Ventura, CA
jes58 Offline
jes58  Offline
Ventura, CA
yes I would be interested in your pix, what you needed for parts and were you got them etc... I have considered getting the pole and the mainbeam mount from the factory (al la I20), and going aftermaket on every thing else.
thanks
Re: adding a spin to N6.0 [Re: jes58] #58909
10/15/05 04:08 PM
10/15/05 04:08 PM
PTP Offline OP
PTP  Offline OP
I think the pole will be stiff enough with a dolphin striker and attachments to the forestay bridle attachments and to the tips of the bows.
Re: adding a spin to N6.0 [Re: PTP] #58910
10/17/05 07:26 AM
10/17/05 07:26 AM
Crofton, MD
Chris9 Offline
Chris9  Offline
Crofton, MD
I was going to post 30 or 40 pics but each are apparently to big. Suggestions?
Chris Allen
Nacra 20 Gertie
www.wrcra.org
Re: adding a spin to N6.0 [Re: Chris9] #58911
10/17/05 07:30 AM
10/17/05 07:30 AM
Crofton, MD
Chris9 Offline
Chris9  Offline
Crofton, MD
Maybe some of them will fit
Chris Allen
Nacra 20 Gertie
www.wrcra.org
Re: adding a spin to N6.0 [Re: Mark Schneider] #58912
10/17/05 07:35 AM
10/17/05 07:35 AM
Crofton, MD
Chris9 Offline
Chris9  Offline
Crofton, MD
Nice to see that the grass was in focus in that last one:)
Chris Allen
Nacra 20 Gertie
www.wrcra.org
Re: adding a spin to N6.0 [Re: Chris9] #58913
10/17/05 07:36 AM
10/17/05 07:36 AM
Crofton, MD
Chris9 Offline
Chris9  Offline
Crofton, MD
Chris Allen
Nacra 20 Gertie
www.wrcra.org
Re: adding a spin to N6.0 [Re: Chris9] #58914
10/17/05 07:39 AM
10/17/05 07:39 AM
Crofton, MD
Chris9 Offline
Chris9  Offline
Crofton, MD
Chris Allen
Nacra 20 Gertie
www.wrcra.org
Re: adding a spin to N6.0 [Re: Chris9] #58915
10/17/05 07:42 AM
10/17/05 07:42 AM
Crofton, MD
Chris9 Offline
Chris9  Offline
Crofton, MD
Chris Allen
Nacra 20 Gertie
www.wrcra.org
Re: adding a spin to N6.0 [Re: Chris9] #58916
10/17/05 07:45 AM
10/17/05 07:45 AM
Crofton, MD
Chris9 Offline
Chris9  Offline
Crofton, MD
Chris Allen
Nacra 20 Gertie
www.wrcra.org
Re: adding a spin to N6.0 [Re: Chris9] #58917
10/17/05 07:47 AM
10/17/05 07:47 AM
Crofton, MD
Chris9 Offline
Chris9  Offline
Crofton, MD
Since I did such a nice job recognizing the minimum distance my little camera will focus at: 28' from base of mast
Chris Allen
Nacra 20 Gertie
www.wrcra.org
Re: adding a spin to N6.0 [Re: Chris9] #58918
10/17/05 07:51 AM
10/17/05 07:51 AM
Crofton, MD
Chris9 Offline
Chris9  Offline
Crofton, MD
Chris Allen
Nacra 20 Gertie
www.wrcra.org
Re: adding a spin to N6.0 [Re: Chris9] #58919
10/17/05 07:57 AM
10/17/05 07:57 AM
Crofton, MD
Chris9 Offline
Chris9  Offline
Crofton, MD
Hmmm, I thought N6.0 mast were 31.5 feet 31'-7". Nice shoes for aCat sailor! Whoops a-class cat sailor. Sterling, thanks for helping and providing the tape measure.
Chris Allen
Nacra 20 Gertie
www.wrcra.org
Re: adding a spin to N6.0 [Re: Chris9] #58920
10/17/05 07:59 AM
10/17/05 07:59 AM
Crofton, MD
Chris9 Offline
Chris9  Offline
Crofton, MD
Doulber from clew of spin
Chris Allen
Nacra 20 Gertie
www.wrcra.org
Re: adding a spin to N6.0 [Re: Chris9] #58921
10/17/05 07:59 AM
10/17/05 07:59 AM
Crofton, MD
Chris9 Offline
Chris9  Offline
Crofton, MD
doubler
Chris Allen
Nacra 20 Gertie
www.wrcra.org
Re: adding a spin to N6.0 [Re: Chris9] #58922
10/17/05 08:01 AM
10/17/05 08:01 AM
Crofton, MD
Chris9 Offline
Chris9  Offline
Crofton, MD
Tack line (Green) / Halyard (White with green and red fleck)
Chris Allen
Nacra 20 Gertie
www.wrcra.org
Re: adding a spin to N6.0 [Re: Chris9] #58923
10/17/05 08:06 AM
10/17/05 08:06 AM
Crofton, MD
Chris9 Offline
Chris9  Offline
Crofton, MD
Chris Allen
Nacra 20 Gertie
www.wrcra.org
Re: adding a spin to N6.0 [Re: Chris9] #58924
10/17/05 08:09 AM
10/17/05 08:09 AM
Crofton, MD
Chris9 Offline
Chris9  Offline
Crofton, MD
snuff head, Yellow Line holds sock in place, Flange on snuffer head is to small and flexible.
Chris Allen
Nacra 20 Gertie
www.wrcra.org
Re: adding a spin to N6.0 [Re: Chris9] #58925
10/17/05 08:11 AM
10/17/05 08:11 AM
Crofton, MD
Chris9 Offline
Chris9  Offline
Crofton, MD
over done attachment to foil
Chris Allen
Nacra 20 Gertie
www.wrcra.org
Re: adding a spin to N6.0 [Re: Chris9] #58926
10/17/05 08:13 AM
10/17/05 08:13 AM
Crofton, MD
Chris9 Offline
Chris9  Offline
Crofton, MD
hiking straps underside of Tramp
Chris Allen
Nacra 20 Gertie
www.wrcra.org
Page 3 of 4 1 2 3 4
0 registered members (), 680 guests, and 32 spiders.
