Which rudders for which boat? #60077
11/01/05 09:56 AM
11/01/05 09:56 AM
Dunedin Causeway, FL
David Parker Offline OP
Hello new forum users!
My Mystere 5.0XL came with little rudders. They stalled every time the hull started to lift! I replaced them with a bigger pair from a M6.0 and now all is well. What were these rudders from? Is this what is used on the Mystere 4.3?
If these fit on a 4.3 I'd be glad to sell these little rudders! They're like new. Does anyone need them?
Re: Which rudders for which boat? [Re: David Parker] #60078
11/01/05 02:13 PM
11/01/05 02:13 PM
BobG Offline
BobG  Offline
I thought 5.5 and 6.0 rudder system was the same. 5.0 has a skeg so it would use a smaller blade!When you say stalling was it cavatating (rudder)so there was no steerage or what was happening.And your pretty brave to open up with Mystere rudder issues.
Re: Which rudders for which boat? [Re: David Parker] #60079
11/02/05 12:42 PM
11/02/05 12:42 PM
Hi David -
Those do indeed look like the 4.3 rudders. Please measure them (approx length, width and thickness) and e-mail me how much you want at williamsjohn at cox dot net.
Thanks!
Re: Which rudders for which boat? [Re: John Williams] #60080
11/04/05 09:49 PM
11/04/05 09:49 PM
Hi John,
For general interest I'll post the numbers. The small blades are 33 inches long and 8" at the widest. The big ones are 37.5" long and 10 wide. Since all Mysteres use the same castings the thickness is moot. I'd like to get $5000 for the pair but I'd take less.
The little blades were useless on the 5.0XL. Under any load at all you could see them "aspirate"...air bubbles traveled down the leading edge and flowed off about a foot underwater. As soon as the boat heats up with slight weather helm the rudders slam sideways within the air pocket, the boat stops and rounds up, and it takes several seconds for clean water to "reattach" to the blades. By now you're in irons and really pissed off. I repeated this event about 50 times. If I sailed gently like a little girl it would be OK but the Opti prams would pass me. Now with the BIG blades this boat is solid as a rock and loves big air and rough water.
Just don't rake the mast...but that's a different topic.
Re: Which rudders for which boat? [Re: David Parker] #60081
11/07/05 11:36 PM
11/07/05 11:36 PM
catman Offline
catman  Offline
I was just lookin around and I found this! Nice.
As far as those rudders go they are usless on anything but a 4.3. Stevie had those on his M5.0 and after he put the larger sail plan on the boat they really got bad. He put the 6.0 blades on and loved it.
Thickness is not moot [Re: David Parker] #60082
11/08/05 02:40 AM
11/08/05 02:40 AM
US Western Continental Shelf
hobiegary Offline
hobiegary  Offline
As a subsequent owner of Rob Daniel's M6.0 #310, I took ownership of a M6.0 with an "extra" set of rudder blades. They were shaped like the curvey blades that you exhibited here, but were larger than yours.
When you said...
I had to object because of the fact that my two sets of blades were very different in thickness. The curvey ones are thinner than the larger ones. The curvey ones fit into a set of Hobie 16 castings, (with a little modifications to the perimeter sizing), while the standard 6.0 castings and blades were thicker.
GARY
Santa Monica Bay
Re: Thickness is not moot [Re: hobiegary] #60083
11/08/05 12:29 PM
11/08/05 12:29 PM
hobiegary Offline
hobiegary  Offline
I should have also mentioned that my curvey ones are longer than the 4.3 model rudders shown earlier. They appear to share a similar perimiterical shape with the 4.3 rudders, but are of a larger scale.
GARY
Santa Monica Bay
Re: Which rudders for which boat? [Re: David Parker] #60084
11/09/05 11:53 PM
11/09/05 11:53 PM
cyberspeed Offline
cyberspeed  Offline
I think I found out your problem as to why the wider rudder is thicker. It has a hammer attached to it. That seems to be something that Bob had a hand in.
Be careful in this forum. Mutiny might be afoot.
craig van eaton
Supercat 20
TEAM CYBERSPEED
www.TeamCyberspeed.com
Endurance Series
www.SailSeries.com
Re: Which rudders for which boat? [Re: cyberspeed] #60085
11/10/05 12:52 AM
11/10/05 12:52 AM
BobG Offline
BobG  Offline
Craig want me to put a good word in for you about a Supercat forum !
Re: Which rudders for which boat? [Re: BobG] #60086
11/10/05 09:55 AM
11/10/05 09:55 AM
cyberspeed Offline
cyberspeed  Offline
You better wait till I figure out my long term plans...
craig van eaton
Supercat 20
TEAM CYBERSPEED
Endurance Series
www.SailSeries.com
Re: Thickness is not moot [Re: hobiegary] #60087
11/10/05 10:53 AM
11/10/05 10:53 AM
BobG Offline
BobG  Offline
Gary are the thinner rudders from a m5.0 in the photo?.
Re: Thickness is not moot [Re: BobG] #60088
11/10/05 11:18 AM
11/10/05 11:18 AM
hobiegary Offline
hobiegary  Offline
I don't know what they came from. Some Mystere, I suppose.
GARY
Santa Monica Bay
Re: Thickness is not moot [Re: BobG] #60089
11/10/05 11:21 AM
11/10/05 11:21 AM
I have three sets of rudders, the little ones in my first photo, the larger set from a 6.0, and a nearly identical pair from a 5.5. All 6 blades have the same thickness for the white plastic hole insert. The insert is about 1 mm thicker than the blades for 2 of the sets. However, the 5.5 blades have a thicker gel coat that makes them impossible to get into the castings without some sanding (which I haven't done yet). Since the 6.0 blades fit, I use them.
Re: Which rudders for which boat? [Re: David Parker] #60090
12/18/05 10:56 PM
12/18/05 10:56 PM
M
mystereS Offline
mystereS  Offline
M
I am dating myself and my boat to suggest that the rudder on the left came from a Mystere "S". If the pair is still available (for a little less that $5K!) I would be interested.
Re: Which rudders for which boat? [Re: mystereS] #60091
12/19/05 04:32 PM
12/19/05 04:32 PM
mystereS...Please check your PM at this site.
Re: Which rudders for which boat? [Re: mystereS] #60092
01/12/06 08:52 PM
01/12/06 08:52 PM
catman Offline
catman  Offline
I guess the next question is, what's a Mystere "S"?
Re: Which rudders for which boat? [Re: catman] #60093
01/15/06 09:31 AM
01/15/06 09:31 AM
BobG Offline
BobG  Offline
Is the "S", the start of the 5.5 line. Stands for "Sexy" as hell, Yeah baby Yeah!
Re: Which rudders for which boat? [Re: BobG] #60094
01/19/06 10:25 PM
01/19/06 10:25 PM
M
mystereS Offline
mystereS  Offline
M
From what I can tell from my sales brochure the Mystre "S" is an evolution of the original Mystere. They added 2 feet to the original mast to take it to 28 feet, added double trapeze etc. The boat is just shy of 18 feet and is a 7/8 scale Tornodo (sp?). I bought mine new in 1983 which dates both the boat and the skipper!!
The 5.5 line was the next interation if I am not mistaken. The two boats have litte in common other than two hulls and the rudders.
Re: Which rudders for which boat? [Re: mystereS] #60095
01/23/06 07:27 PM
01/23/06 07:27 PM
catman Offline
catman  Offline
Thank's "S". Didn't even know Mystere was building boats that long.
Re: Which rudders for which boat? [Re: catman] #60096
01/28/06 10:53 PM
01/28/06 10:53 PM
M
mystereS Offline
mystereS  Offline
M
I might add that I recall a regatta at our local club in Toronto where the Mystere folks showed up with a factory boat and the designer. They smoked the entire field including several Tornados (in an identical boat we languished mid field!!). I was humbled by the skills of the skipper/designer who it turns out was some Olympic class sailor from England - wish I could remember his name.
"S"
0 registered members (), 175 guests, and 109 spiders.
Posts267,058
