Pictures of Nacras Infusion "hot off the press" #65469
01/26/06 11:21 AM
01/26/06 11:21 AM
2017 F18 Americas Site
Dan_Delave Offline OP
[color:"red"]"IT'S REAL!"[/color] I was down at the club yesterday to see the first looks of the new boat. The picture on the water it Peter Vink and Pete Melvin sailing. I will have to post all the pictures that Peter sent me on the Photos site. I will tell you when they are all up.
Later,
Dan
Re: Pictures of Nacras Infusion "hot off the press [Re: Dan_Delave] #65470
01/26/06 11:55 AM
01/26/06 11:55 AM
I wondered when someone was going to figure out how to get the spinnaker pole lower. That's a neat attachment of the bridle wires...not on the upper edge of the deck but down the inside of the hull. Looks like the jib is really low and has a higher aspect ratio too.
Re: Pictures of Nacras Infusion "hot off the press" [Re: Dan_Delave] #65471
01/26/06 12:01 PM
01/26/06 12:01 PM
BUCKWHEAT PART 3
Re: Pictures of Nacras Infusion "hot off the press [Re: Jake] #65472
01/26/06 12:07 PM
01/26/06 12:07 PM
uk
TEAMVMG Offline
TEAMVMG  Offline
uk
Yes, the bottom of that kite looks parallel with the deck
Dan, are there into production of the hulls yet? i know peter is still trialing jibs.
I need my boat now
Paul [infusion #?]
Re: Pictures of Nacras Infusion "hot off the press [Re: TEAMVMG] #65473
01/26/06 01:05 PM
01/26/06 01:05 PM
This is a production hull, Hull #1. They are at the factory today sorting out all the stuff they are sending with the boat. That is, the list of materials, line lenghts, etc. They have molds enough to make two full boats at a time. That is four hull molds as starboard and port hulls are distinct from one another. Infusion production techniques will allow pulling of parts more quickly. There are over 50 orders with money down, right now, if I understand correctly. There are also about 20 others waiting in the wings. Better start pumping them out Jack.
If you want some more shots of the boat try they gallery and look up my name. Infusion Photos
Jake: The bridle does attach a bit lower on the hull. The pole shrouds are still about the same place.
Dan
Re: Pictures of Nacras Infusion "hot off the press [Re: Jake] #65474
01/26/06 01:31 PM
01/26/06 01:31 PM
Eastern NC, USA
tshan Offline
tshan  Offline
Eastern NC, USA
The spin does look lower than the other NF18s. Some boats use a compression strut that runs from the point of bridle/forestay attachment to the spin pole. See attachment. I guess this would allow for more spin shapes that still fit within class rules?
Re: Pictures of Nacras Infusion "hot off the press [Re: tshan] #65475
01/26/06 01:31 PM
01/26/06 01:31 PM
Eastern NC, USA
tshan Offline
tshan  Offline
Eastern NC, USA
Another pic of the strut. The infusion looks like a very cool boat.
Re: Pictures of Nacras Infusion "hot off the press [Re: Jake] #65476
01/26/06 05:21 PM
01/26/06 05:21 PM
Those someones where Martin Fisher and Greg Goodall when it comes down to F18's. They figured it out in 2003/2004 with their Capricorn F18; see picture.
Sorry mates, that feature is not new. Actually I the idea is alot older then that as well as the KL catamarans had it back in the 90's already.
Re: Pictures of Nacras Infusion "hot off the press [Re: Wouter] #65477
01/26/06 11:45 PM
01/26/06 11:45 PM
Tornado_ALIVE Offline
We now have a Landy kite on the Capricorn which is longer in the luff than the Goodall.
Our pole is about 6 inches lower at the bridle than this one. Because it is so low, we added another bridle (spectra) from the pole to the bridle chainplates just like the Tornadoes.
Yesterday I raced a Marathon and set the Capricorn up with my Tornado kite. Pole tip was level with the bow and had to raise the halyard pully slightly. Looked mean. Some serious depth down wind too....
Re: Pictures of Nacras Infusion "hot off the press" [Re: Dan_Delave] #65478
01/27/06 03:01 AM
01/27/06 03:01 AM
uk
TEAMVMG Offline
TEAMVMG  Offline
uk
Good pictures Dan, I can see what I am getting now!
Performance have yet again gone to a lot of trouble [and expense] to incorporate a rotation system that can be trimmed from the wire. This time they are using an 'ankle bruiser' type that the Tornadoes were using a while back. The previous nacra/prindle over-boom system had a fair bit of friction and I always took out a purchase. This in contrast to Hobie who, even on the highest tec Tiger, stick with the jam cleat on top of the boom. Is this a difference in thinking between the two camps? I was always someone who let off the rotation to the max when the kite was hoisted, firstly to go faster but also to keep the mast pointing upward. But now that we are all sailing hotter and harder downwind, is this necessary?
[Infusion #?]
Re: Pictures of Nacras Infusion "hot off the press [Re: Dan_Delave] #65479
01/27/06 11:02 AM
01/27/06 11:02 AM
US Western Continental Shelf
hobiegary Offline
hobiegary  Offline
Wow, look at how tiny those hulls are, forward of the mast!
Santa Monica Bay
Re: Pictures of Nacras Infusion "hot off the press [Re: hobiegary] #65480
01/27/06 12:59 PM
01/27/06 12:59 PM
Paul:
I sail a Tiger and reworked my rotation adjustment making it similar to the Nacras with cleats to the side of the boat. Even if going Mach I think it still makes sense to let the rotation off downwind. Eileen and I were being lazy one day and did not ease the rotation, while Pease and Jay Glaser were watching us. They said it made big difference if we did not let it rotate forward, as the sail is a completely different shape. This may have something to do with how the spinnaker pulls at the mast when up. I think that the Tornado’s may be going back to the way this new boat is rigged. We used to sail a Hobie 20 with the rotation on the trampoline like this. It works better due to the friction you mentioned. I think it is nice to have it out of the way and on the boom…but at what cost? I may move mine to trampoline to try for an afternoon out. Just to see how we like it. We will see.
Hobie Gary:
This boat may look on the picture to be thin but that is relative. The hulls are very wide and able to float a lot of weight. The hull from the crossbar forward may look, in the pics, to be narrow. They are not.
Later,
Dan
Re: Pictures of Nacras Infusion "hot off the press [Re: Dan_Delave] #65481
01/27/06 05:02 PM
01/27/06 05:02 PM
For some reason I LOVE the looks of this boat. To me it looks like a big ocean racer scaled down.
Re: Pictures of Nacras Infusion "hot off the press [Re: Mary] #65482
01/28/06 07:15 AM
01/28/06 07:15 AM
Bob_Curry Offline
Bob_Curry  Offline
Just looking at the sails, is the Infusion going to come with the Euro sails pictured or EPs?
Bob
Re: Pictures of Nacras Infusion "hot off the press [Re: Bob_Curry] #65483
01/30/06 09:47 AM
01/30/06 09:47 AM
uk
TEAMVMG Offline
TEAMVMG  Offline
uk
Bob
All the European Nacras have 'Performance sails' . The fact that Peter Vink is the main man at performance sails and is now co-owner of Nacra Europe [Was deBoers] will only reinforce this.
Re: Pictures of Nacras Infusion "hot off the press [Re: Dan_Delave] #65484
01/30/06 12:37 PM
01/30/06 12:37 PM
hobiegary Offline
hobiegary  Offline
The way the foredeck ramps-up to the top of the cross bar, exagerates the illusion of having a lot of taper.
GARY
Santa Monica Bay
Re: Pictures of Nacras Infusion "hot off the press [Re: Bob_Curry] #65485
02/06/06 03:14 PM
02/06/06 03:14 PM
Bob,
I understand that even the US Infusions will have Vink's sails.
Wout,
Yeah - I discovered that later after making that post.
More F18i pictures [Re: Jake] #65486
02/23/06 03:47 AM
02/23/06 03:47 AM
First test sail in the land of cheese by nacra europe.
Its hard to make out the profile of the masts's wingshape from the pics. Maybe I can take some pics at the boatshow next week.
Re: Pictures of Nacras Infusion "hot off the press [Re: Jake] #65487
04/05/06 05:16 AM
04/05/06 05:16 AM
Marcus F16 Offline
Marcus F16  Offline
I think you guys have missed the most important reason why the bridle tangs are so low. The lower you want set the jib on a formula eighteen the shallower the bridle becomes - unless you place the fitting much lower down the inside of the hull.
We did this on the blade formula eighteen - yes we got the idea from the capricorn and acknowledged that they were on the right path.
We placed the fitting about one hundred mm down from the gunnal and reduced the load on the hulls, bridle etc.
It will be interesting to see how the new nacra will go against the capricorns and tigers.
Marcus
Marcus Towell
Re: Pictures of Nacras Infusion "hot off the press [Re: Marcus F16] #65488
04/05/06 09:30 AM
04/05/06 09:30 AM
Marcus:
How does the Blade do against the Capricorn? Did you put more volume in the hulls? What are some of the differences in the overall design?
Dan
0 registered members (), 178 guests, and 37 spiders.
Posts267,059
