by Karl_Brogger. 12/29/24 05:14 PM
Page 4 of 6 1 2 3 4 5 6
Re: Capsize kills tourist [Re: Seeker] #70014
03/24/06 02:31 PM
03/24/06 02:31 PM
"Why not a small gas powered life preserver type thing on the top of the mast that inflates on consistent contact with water? Or has some type of pull thing that you could run down the middle of the mast. Wouldn't be as big as a bob.
This could be easily replaced and relatively cheap."
That may be fine for the boats that are already in existence...but why can't the boat manufactures just do it right when designing them...what’s so hard about making the mast sufficiently buoyant in the fist place by increasing the section size? This is by far the simplest and easiest way to solve the problem? It doesn’t have to look like a giant football or tootsie pop on the top of the mast.
If my mast were any heavier I would need a crane to put it up or I just wouldn't sail at all. If all the masts in the future are carbon then I guess it could work, but until then, making bigger masts may not be the answer.
Re: Capsize kills tourist [Re: fin.] #70015
03/24/06 02:32 PM
03/24/06 02:32 PM
Checking mast for leaks? Submerge it in a pool and watch for bubble?
If it isn't a very active leak is it a safety issue?
Re: Capsize kills tourist [Re: fin.] #70016
03/24/06 02:41 PM
03/24/06 02:41 PM
Maybe pressurizing it through a screw hole and look for leaks with soap. In the end though, you may end up creating leaks with the pressure!
Re: Capsize kills tourist [Re: PTP] #70017
03/24/06 03:26 PM
03/24/06 03:26 PM
On a nice warm day toss your mast into a nice cool lake or ocean, check base, top and hound, no pressurization necessary.
Re: Capsize kills tourist [Re: _flatlander_] #70018
03/24/06 04:06 PM
03/24/06 04:06 PM
Ft. Pierce, Fl. USA
Seeker Offline
Seeker  Offline
Ft. Pierce, Fl. USA
"If my mast were any heavier I would need a crane to put it up or I just wouldn't sail at all. If all the masts in the future are carbon then I guess it could work, but until then, making bigger masts may not be the answer."
It works on the Supercat 17,19,20, the ARC 17, 21, & 22 Why not for other similar size cats?
Re: Capsize kills tourist [Re: Rolf_Nilsen] #70019
03/24/06 06:01 PM
03/24/06 06:01 PM
Give me a few days and I'll get the pics of my idea and send it too you.
Re: Capsize kills tourist [Re: Seeker] #70020
03/24/06 06:08 PM
03/24/06 06:08 PM
Yet it hasn't been addressed by anyone in the primary phase of boat design, other than Bill Roberts. His Supercat and ARC catamarans are the only ones, that I am aware of, that build a large enough mast section to provide sufficient buoyancy to keep the boat from going turtle in all but the most extreme circumstances, this is not by accident …but by design..
Awww, please that is just nonsense.
Other designs with the same mast bouyancy characteristics :
All the Taipans (4.9's, 5.7's and even the F16's)
There is no way you can turtle a modern A-cat.
All F16's with the superwing mast have the same volumenious mast sections.
I seem the remember I-20's were pretty turtle resistant as well.
I'm sure a few others can add design to this listing.
This problem of turtling is a well know issue. Why hasn't anyone else followed suite.
The question is more why you think that others DIDN'T. You must not believe everything Bill R. says. In this case Bill was talking nonsense when he claimed no other designer ever took this into account.
Yes you have the Hobie Bob, but that is nothing but an awkward band aid that hurts (or is perceived to hurt) performance. Why not adapt this simple solution to a potentially horrific problem. The increase in mast section size never seems to slow down Bill or Eric on the race course.
Re: Capsize kills tourist [Re: Wouter] #70021
03/24/06 07:35 PM
03/24/06 07:35 PM
California
mmiller Offline
mmiller  Offline
California
The Hobie Bob floats offer very streamlined shapes that have less wind resistance than a crew members head...
The key to the safety of the Bob is getting the needed floatation out at the end of the mast lever arm where it is most needed.
There were attempts at mast wraps for floatation. These offered larger areas of drag and less effective floatation.
The Bobs are great solutions for recreational sailing.
Hobie Cat Forums
Matt Miller
Hobie Cat Company
Re: Capsize kills tourist [Re: mmiller] #70022
03/24/06 07:45 PM
03/24/06 07:45 PM
“an island in the Pacifi...
hobie1616 Offline
hobie1616  Offline
Matt, have you ever been picketed by the Crew Union? I see labor unrest at Hobie's Galactic HQ soon.
US Sail Level 2 Instructor
US Sail Level 3 Coach
Re: Capsize kills tourist [Re: mmiller] #70023
03/24/06 08:19 PM
03/24/06 08:19 PM
Darryl_Barrett Offline
WOW did this thread get a response? When I went home last night there were just three replies, this morning there were 67!!.
Although I fully sympathise with the fact that an eleven-year-old child died, I still have to say that I consider it one of those very unfortunate occasions that do and will happen, regardless of whatever steps we take to avoid. Whether we like it or not. Circumstances outside our control or as some would call it “fate”, does seem to play a part in all our lives. From personal experience I was placed in a “life and death” situation on a cat some years ago, where I was “trapped” not as in this case by the rigging or trapeze wire, but by a mainsheet line around the ankle. I was on a small cat on fresh, flat water with a wind of only about 6 knots when I had to make a sudden tack to avoid a dingy on starboard. When going under the boom my foot became entangled in the main sheet and some how I found myself in the water on the other side of the boat being dragged along by the ankle with my head under water. This was a very worrying situation as, for some reason unknown to me to this day I couldn’t get my head above water and the force of the water was very powerful even in those light conditions. It didn’t help that the rope attached to my ankle kept pulling the main on tighter and tighter. I couldn’t reach forward to get the line against the water flow and I couldn’t raise my head above the water. Just as I had visions of not seeing my family again, the line suddenly went slack and my head bobbed above the surface. Another cat sailing close by had seen what had happened and run his boat into my bows so putting it into irons. As soon as the pressure had ceased the line literally just fell off of my ankle. I think back on that time occasionally and realise that IF the grim reaper really wants you there are no regulations, no steps, no circumstances that you can put into place to avoid his steely grip. Should all mainsheets be eliminated? Even if I had a knife I couldn't have used it (other than cutting off my leg - if I could have reached it -). Some tragedies “just happen” regardless of what we do. It’s called LIFE, and all who live will someday die and no one can change that.
Re: Capsize kills tourist [Re: Darryl_Barrett] #70024
03/25/06 12:30 AM
03/25/06 12:30 AM
Tornado_ALIVE Offline
Just a thought, but has anybody also considered mounting a knife to the underside of the rear beam...... That way anybody close can grab and cut.
Remember one of the comments from officials at I believe it was SPA regatta where a Tornado crew died whilst trapped under the tramp. "The rescue boat did not have a knife on board and was unable to cut the tramp"...... A knife on the back beam could have saved this guys life.
Also regarding A cats will not go turtle....... I have seen it quiet a few times now and have even seen thier rigs snap from bouncing on the bottom.
Re: Capsize kills tourist [Re: Tornado_ALIVE] #70025
03/25/06 01:16 AM
03/25/06 01:16 AM
Steve, just getting the facts right. The Tornado accident was 2002, Palma de Mallorca during the "Princesa Sofia" trophy. A prolonged tragedy where one of the Haupl brothers, Johannes, was trapped in his trapeeze under the tramp. First coach boats that arrived did not have a knife onboard, so they resorted to trying to lift the boat up sufficiently to get some air to him. The danes coach boat arrived with a knife, but alas..
Good idea to have a knife on the mainbeam. If you need corrector weights, you can perhaps replace them with a wire cutter?
Re: Capsize kills tourist [Re: Rolf_Nilsen] #70026
03/25/06 01:32 AM
03/25/06 01:32 AM
Thanks Rolf for correcting me...... Been a while since the incident. Did not hear that he was caught in his trapeze when I orignaly heard the story..... Can you elaborate further on this at all.
Knife and wire cutters.... Good idea. Would not be a stupid idea to make it part of class rules. The F-18s currently must carry a compass, paddle, tow rope......
Re: Capsize kills tourist [Re: Tornado_ALIVE] #70027
03/25/06 02:17 AM
03/25/06 02:17 AM
Sorry Steve, I dont have more specific information on how he got tangled up under the tramp. Always wondered about that myself, and have missed a proper examination/discussion by the class.
Knife compulsory in class rules ? [Re: Tornado_ALIVE] #70028
03/25/06 04:44 AM
03/25/06 04:44 AM
I had too say it but indeed carrying a knife is compulsory in the F16 class rules !
Geez this rules setup is well though out.
Re: Capsize kills tourist [Re: fin.] #70029
03/25/06 05:06 AM
03/25/06 05:06 AM
Thailand
Buccaneer Offline
Buccaneer  Offline
Thailand
[/quote]
If I had a young child, I would have been parenting that child and not have left the responsibility to others. [/quote]
I’d guess that's where the negligence played in. Cause of death however was most likely drowning by harness entrapment.
The ball system would prevent the hook from getting snagged but not the harness.
Re: Capsize kills tourist [Re: Buccaneer] #70030
03/25/06 06:41 AM
03/25/06 06:41 AM
Northfield,NH USA
bullswan Offline
bullswan  Offline
Northfield,NH USA
Wasn't there a problem with the ball and socket harness a while back? Something about the materials used breaking prematurely or something like that? I thought they were pulled from The Store for some kind of defect. Has that been resolved because I plan on replacing mine this spring and I'd like to have confidence that it won't crack or whatever?
Greg
Re: Capsize kills tourist [Re: bullswan] #70031
03/25/06 07:26 AM
03/25/06 07:26 AM
The carbon harnesses don't break. It was the plastic ones they pulled. May go this route on my 17. Knife and cutters for sure.
Doug Snell
Hobie 17
www.tcdyc.com
Re: Capsize kills tourist [Re: Buccaneer] #70032
03/25/06 09:07 AM
03/25/06 09:07 AM
FL
sail7seas Offline
sail7seas  Offline
FL
On a long (about a hour) wild reach back to the beach in Puerto Rico, 2 meter swell, traveler almost all the way out, double trapped on a H16, I lost my concentation, capsized, turtled, and was held under the boat, by the shockcord wraped around my legs. I remained calm, but at some point wondered if I would ever figure out how to untangle myself.
A knife on my person or crew would of been helpful, I now carry a knife.
A quick release for the harness would have been ineffective as the problem was the bungee cord around my legs (unhooking was a no brainer).
A quick release of the shock cord in my case would have been more effective.
Re: Capsize kills tourist [Re: sail7seas] #70033
03/25/06 09:47 AM
03/25/06 09:47 AM
Santiago, Chile
Andinista Offline
Andinista  Offline
Santiago, Chile
The risk, in fact is not only associated with the trapeze, all sailboats have plenty of ropes and other stuff to get stucked with. I know of somebody that got trapped on a capsized Laser, with the tiller inside his lifevest, he managed to unmount the tiller, but recognized that it wasn´t easy to remain calm and figure out what to do.
I think it´s better that each one carries his own kinfe instead of storing it in somewhere in the boat where it can be out of reach. In the case I mentioned, the first thing the crew did after capsizing was to swim to recover the daggerboard that came out of the boat. She didn´t even think his partner was trapped down the boat and it took her a couple of minutes to get back to the boat.
0 registered members (), 284 guests, and 71 spiders.
Posts267,059
