Nacra 5.0 owners , Please help ! #7282
05/24/02 09:48 AM
05/24/02 09:48 AM
Anonymous OP
Anonymous OP
Could you tell me what the torque values are for the crossarms of a 5.0 ?
Re: Nacra 5.0 owners , Please help ! #7283
05/24/02 10:34 AM
05/24/02 10:34 AM
USA
NaCl H20 Offline
NaCl H20  Offline
USA
You can download a Nacra assembly manual from the Performance Cat web site - www.performancecat.com
The manual says 16-18 ft/lbs. That sounds a little tight to me.
Also make sure you grease the bolts with white grease.
I always use an adjustable wrench on the chips to keep them from turning and thus putting more preasure on one side of the beam strap than the other.
Have fun. If you haven't sailed a 5.0 yet, it's a great boat
Re: Nacra 5.0 owners , Please help ! [Re: NaCl H20] #7284
05/24/02 02:10 PM
05/24/02 02:10 PM
I also found that this torque setting was a bit high for my old Nacra 5.2 as the hull started to compress and I could never reach the torque setting - I settled at about 10 - 12ftlbs and haven't had a problem (1 year and a lot of sailing since).
Re: Nacra 5.0 owners , Please help ! #7285
05/25/02 11:38 AM
05/25/02 11:38 AM
Andrew Offline
Andrew  Offline
A major Performance cat dealer told me never to go over 13 ft/lbs, that 18 is way too much. He uses Never-Seize and the bolts have to be retorqued several times as the beams settle in.
Hope this helps.
0 registered members (), 534 guests, and 34 spiders.
