| Re: As a result of the upgrade I lost ....
[Re: Wouter]
#74880 05/11/06 05:43 PM 05/11/06 05:43 PM |
Posts: 3,528 Looking for a Job, I got credi... |
I would like to vote for entlarging the search time frame.
Currently it is 1 year and that is too short.
Maybe we can have it default at 1 year but still allow longer time frames.
I personally use the search function alot to do fact checking. Also thread dealing with trim, spi sailing are often out side of the year timeframe.
I also miss the "or" / "and" option in the keyword search. With the new search engine you can much less fine tune your search parameters.
All, Agree with Wouter that 1 year is not enough. As for searching, use + to include a term, and - to exclude. so if you want to find posts that mention 'spi' but not 'sheet' put this in the search box +spi -sheetIf you want 'or' searching, just use spi sheet and this will return anything with either spi or sheet, if you want ONLY "spi sheet" use "spi sheet"You can build these up, but UBB does eventually get confused!
F16 - GBR 553 - SOLD I also talk sport here | | | Re: As a result of the upgrade I lost ....
[Re: Mary]
#74884 05/12/06 12:47 PM 05/12/06 12:47 PM | Anonymous
| Anonymous
Unregistered | Does anyone else have to logon everytime they go to site? It doesn't remember me. Still would like to see new post highlighted like before.
Doug | | | Re: As a result of the upgrade I lost ....
[Re: ]
#74885 05/12/06 01:01 PM 05/12/06 01:01 PM | Anonymous
| Anonymous
Unregistered | I changed the search setting to allow you to go back 5 years. Keep in mind that when a search is done that goes back that far, it will take up more system resources and can slow things down while the search is in progress for everyone. If this becomes a problem, we may need to shorten the search length again.
As for logging in each time, I have not tried it, but there is a checkbox at the login screen to remember you when you come back. If this is not working, please post it here and I will take a look at it. | | | Re: As a result of the upgrade I lost ....
[Re: Mary]
#74888 05/12/06 06:14 PM 05/12/06 06:14 PM | Anonymous
| Anonymous
Unregistered | The Instant Graemlins are now working...... <img src="http://www.catsailor.com/forums/images/graemlins/ooo.gif" alt="" /> <img src="http://www.catsailor.com/forums/images/graemlins/mad.gif" alt="" /> <img src="http://www.catsailor.com/forums/images/graemlins/cool.gif" alt="" /> <img src="http://www.catsailor.com/forums/images/graemlins/smile.gif" alt="" /> <img src="http://www.catsailor.com/forums/images/graemlins/frown.gif" alt="" /> <img src="http://www.catsailor.com/forums/images/graemlins/blush.gif" alt="" /> <img src="http://www.catsailor.com/forums/images/graemlins/grin.gif" alt="" /> <img src="http://www.catsailor.com/forums/images/graemlins/confused.gif" alt="" /> <img src="http://www.catsailor.com/forums/images/graemlins/smirk.gif" alt="" /> <img src="http://www.catsailor.com/forums/images/graemlins/shocked.gif" alt="" /> <img src="http://www.catsailor.com/forums/images/graemlins/laugh.gif" alt="" /> <img src="http://www.catsailor.com/forums/images/graemlins/crazy.gif" alt="" /> <img src="http://www.catsailor.com/forums/images/graemlins/wink.gif" alt="" /> <img src="http://www.catsailor.com/forums/images/graemlins/tongue.gif" alt="" /> | | | Re: As a result of the upgrade I lost ....
[Re: Tony_F18]
#74891 05/13/06 03:14 AM 05/13/06 03:14 AM | Anonymous
| Anonymous
Unregistered | Can you fix it where we don't have to login everytime we go to the site? It won't remember me.
[Re: ]
#74893 05/13/06 11:11 AM 05/13/06 11:11 AM |
Posts: 3,528 Looking for a Job, I got credi... | Can you fix it where we don't have to login everytime we go to the site? It won't remember me.
Doug Check your cookie setting on your firewall. This may be the problem
[Re: Mary]
#74894 05/13/06 11:15 AM 05/13/06 11:15 AM |
Posts: 3,528 Looking for a Job, I got credi... | Thanks for the info on how to do a search. I will see if Rick can add that to the FAQ or put it in a sticky at the top. No problem. It's all in the UBB guide somewhere (Yes, I have read it) and you can do other things too ! I'm in the process off setting up a site using vBulltin and it's so much better than UBB, and cheraper too ! Might be worth considering next time you have to pay an upgrade. I'm also (probably) going to be involved in a mass migration from UBB to vB so if you are interested I can let you know how it goes.
[Re: scooby_simon]
#74895 05/14/06 07:09 PM 05/14/06 07:09 PM | Anonymous
| Anonymous
Unregistered | The read numbers that show unread threads does not show up anymore?
[Re: ]
#74896 05/15/06 11:31 PM 05/15/06 11:31 PM | Anonymous
| Anonymous
Unregistered | As I said the little red numbers are no longer there. You have to login every time, it doesn't remember you. Also the dates are off. It already shows the 16th.
Doug Snell | | | Re: As a result of the upgrade I lost ....
[Re: ]
#74897 05/16/06 12:02 AM 05/16/06 12:02 AM |
Joined: Dec 2005 Posts: 443 Edmonton, Alberta, Canada bobcat
Posts: 443 Edmonton, Alberta, Canada | Doug It seems like a cookie thing. Do you have a privacy/antispyware type program installed that may be blocking all cookies? I have to say that the unread post counter seems broken. It tends to point me at posts that I have already read. BTW When you emailed me a couple of weeks ago, I noticed that your system clock was off by about a week.
Edit:
Hey you are right. This post was made tomorrow!
[Re: bobcat]
#74898 05/15/06 04:07 PM 05/15/06 04:07 PM | Anonymous
| Anonymous
Unregistered | Bobcat:
Clock is right now on my computer seems to be an intermittent problem. Red numbers are there now. Comes and goes. May be a bug. Going to crash for a while. Worked to many hours this weekend.
Doug
749
guests, and 86
Mod | | Forums26 Topics22,405 Posts267,059 Members8,150 | Most Online2,167 Dec 19th, 2022 | | |
