Newbie - Tieing up the main and sail bags... #81339
07/31/06 10:42 AM
07/31/06 10:42 AM
M
Michael_Imhoff Offline OP
M
Hey Everyone,
I thought I tied up a fairly good (and small) bowline to the mainsail hook on my P-18. To my dismay, I had to pull the boat over to manually unhook the main as the knot was hitting the top of the mast. Am I missing something? Tieing shotty knots? Any tips or tricks or suggestions are much appreciated.
Also, are there any tricks for hoisting and lowering a jib snorkel so that it doesn't require the main halyard? I would prefer to rig something up where I can pull the snorkel to the top of the jib and sail with it in place. Was thinking about adding a block to the mast tang and connecting another to the bridles with a new "snorkel halyard" in place...
One last item, anyone know where I can buy a sail bag that goes around the mast and boom to cover the sail just like a normal monohull sail/boom cover?
Cheers for any help you can provide!
Have a great day,
Michael
Re: Newbie - Tieing up the main and sail bags... [Re: Michael_Imhoff] #81340
07/31/06 10:14 PM
07/31/06 10:14 PM
Colorado
SteveT Offline
SteveT  Offline
Colorado
Try this site for your sail hook problem.
www.animatedknots.com
H-20 #896
Re: Newbie - Tieing up the main and sail bags... [Re: Michael_Imhoff] #81341
07/31/06 10:40 PM
07/31/06 10:40 PM
“an island in the Pacifi...
hobie1616 Offline
hobie1616  Offline
Try the buntline. They're designed to never come undone.
http://www.realknots.com/knots/hitches.htm#buntline
US Sail Level 2 Instructor
US Sail Level 3 Coach
Re: Newbie - Tieing up the main and sail bags... [Re: Michael_Imhoff] #81342
08/01/06 06:38 AM
08/01/06 06:38 AM
If you want a knot that will not take up much space, run the halyard through whatever you are tieing, then tie a simple square knot in the very end of the halyard on it's own. Then tie the halyard back around itself with a figure eight. You can substitute another square knot for the figure eight (it will be slightly smaller) but it will be more difficult to undo later.
I have a spinnaker that uses ALL the available hoist height and I've been tieing the clew and head this way for a while.
Re: Newbie - Tieing up the main and sail bags... [Re: Jake] #81343
08/01/06 08:57 AM
08/01/06 08:57 AM
M
M
Wow -- Good websites and great suggestions...
Thanks guys!
Re: Newbie - Tieing up the main and sail bags... [Re: SteveT] #81344
08/01/06 03:39 PM
08/01/06 03:39 PM
Bay of Islands, NZ
warbird Offline
warbird  Offline
Bay of Islands, NZ
You might set up a flat cover which goes over the boom/sail and out to cover the tramp also.
1 registered members (Team_Cat_Fever), 338 guests, and 35 spiders.
