Re: mast floats [Re: MarkW_F18] #81642
08/03/06 06:11 PM
08/03/06 06:11 PM
“an island in the Pacifi...
hobie1616 Offline
hobie1616  Offline
...if a Tiger were flying the spinaker and was traveling West at 24 knots were to colide bow to bow with a H16 traveling north and close hauled at 16 knots, which boat would incur the most damage.
Last century's technology will chew up the Tiger and use the mast for a tooth pick. <img src="http://www.catsailor.com/forums/images/graemlins/smirk.gif" alt="" />
US Sail Level 2 Instructor
US Sail Level 3 Coach
Re: mast floats [Re: mbounds] #81643
08/04/06 08:16 AM
08/04/06 08:16 AM
Charlottesville, VA
sruffner Offline
sruffner  Offline
Charlottesville, VA
Tami - I'm a diver and a former chemist too. Here's a few things about neoprene:
- blown foam neoprene ala wetsuits does absorb some moisture; solid neoprene ala mechanical seals does not do so nearly so quickly. This has much less to do with the chemical structure of neoprene, than the construction of the material.
- sweaters work the same way as wetsuits do - air can get through your sweater, but the sweater traps a layer of air you've warmed with your body heat as an insulative layer. Air is not as conductive as other things. Although sweaters work to keep you warm (just wear one on a sunny day), you notice that cold air does still get through (why you still need a windbreaker on a chilly windy day). Neoprene wetsuits aren't nearly so permeable, but they are still permeable. This is less a physical property of the compounds in question than a mechanical property of their assembly.
- wetsuits do have pockets of air trapped in the foam 'matrix' - that accounts for bouyancy - but some water does get in through there. As Matt the Hobie guy says, a mast full of mostly air is more bouyant - that's because that air amounts to a giant air pocket/bubble, instead of lots of tiny ones.
Water molecules are rather small, just like, say, diatomic helium (think balloons), and they are capable of getting through very small "holes" in the 'matrix' of most solid compounds. You will notice that a helium balloon loses gas slowly, over a couple of days. That's because there are lots of very tiny holes - spaces between the rubber molecules - in the rubber of the balloon - and the gas leaks out very slowly through those holes, but it does.
Similarly, in neoprene foam, there are lots of tiny "faults" and voids in the neoprene, in addition to the air pockets. Water makes it's way in there. I think it's likely that neoprene that spends it's time at the top of a mast 99.9% of the time would stay pretty dry. But, Polystyrene (good old foam cooler material) foam is probably lower density. That stuff is also water-permiable, BTW. IIRC, the only mast float I've ever seen, on an Aqua-Cat, had a plastic skin around a polystyrene core - the skin helped provide mechanical protection, while the core provided bouyancy.
Finally - that's a great avatar.
Re: mast floats [Re: sruffner] #81644
08/04/06 08:23 AM
08/04/06 08:23 AM
Portrait?
Re: mast floats [Re: sruffner] #81645
08/04/06 09:10 AM
08/04/06 09:10 AM
Dunedin Causeway, FL
David Parker Offline
Good science about neoprene, up until the [color:"red"]"diatomic helium" [/color] comment. <img src="http://www.catsailor.com/forums/images/graemlins/confused.gif" alt="" />
Perhaps it can be found near Cap'n Kirk's dilithium crystals. <img src="http://www.catsailor.com/forums/images/graemlins/grin.gif" alt="" />
Re: mast floats [Re: David Parker] #81646
08/04/06 09:42 AM
08/04/06 09:42 AM
Charlottesville, VA
sruffner Offline
sruffner  Offline
Charlottesville, VA
diatomic == di-atomic == two atoms bonded == He2
http://en.wikipedia.org/wiki/Diatomic
Helium is an ideal/inert gas, so, truthfully, He2 is not really stable - you have to pop some serious energy into it to get it to form, and it will quickly decay from that state back to a lower-energy (2)He (unbonded atoms). H2 is what was in my head, but then I though, nobody uses that anymore (at least since the Hindenburg!), so it would be a poor reference.
I should've picked a different (and better) example. H20 is a much larger molecule/structure than a simple He atom. Nevertheless, I think the explanation still stands and is completely valid.
I'm sure the mechanical engineers immediately thought of a mechanical seal, not unlike, say, the rear main oil seal on the crankshaft of your car (though neoprene pretty much rocks for all sorts of mechanical seals plenty of which are "watertight"). Because Water (H20) and oil (hydrocarbons - C(n)H(2n+2)) are much larger structures, they don't seep through as quickly.
The real point of all this is: the bouyancy of the wetsuit is due to the air bubbles in the foam. The same properties make it susceptible to absorbing moisture. The older the suit, the more it will absorb, due to UV damage (breakdown of the neoprene) and mechanical breakdown (the little bubbles get broken open).
Re: mast floats [Re: David Parker] #81647
08/04/06 12:20 PM
08/04/06 12:20 PM
Can they be smoked?
Re: mast floats [Re: fin.] #81648
08/04/06 01:57 PM
08/04/06 01:57 PM
South Louisiana, USA
Clayton Offline
Clayton  Offline
Can they be smoked?
Judging from your pic... somebody has???? <img src="http://www.catsailor.com/forums/images/graemlins/wink.gif" alt="" />
Re: mast floats [Re: Clayton] #81649
08/04/06 02:13 PM
08/04/06 02:13 PM
<img src="http://www.catsailor.com/forums/images/graemlins/grin.gif" alt="" /> <img src="http://www.catsailor.com/forums/images/graemlins/grin.gif" alt="" /> <img src="http://www.catsailor.com/forums/images/graemlins/grin.gif" alt="" />
Re: mast floats [Re: sruffner] #81650
08/04/06 04:13 PM
08/04/06 04:13 PM
[color:"red"] "Helium is an ideal/inert gas, so, truthfully, He2 is not really stable" [/color]
Right, it's NEVER been seen under terrestrial conditions, ever. You're right about He being small and a ballon is porous to it.
However, your comment about H2 not being used anymore, here's a bit in use. <img src="http://www.catsailor.com/forums/images/graemlins/cool.gif" alt="" />
Re: mast floats [Re: David Parker] #81651
08/04/06 04:24 PM
08/04/06 04:24 PM
Clayton Offline
Clayton  Offline
Nothing like a little excess to make a point! <img src="http://www.catsailor.com/forums/images/graemlins/smile.gif" alt="" />
Clayton
Re: mast floats [Re: Clayton] #81652
08/04/06 04:44 PM
08/04/06 04:44 PM
Charlottesville, VA
sruffner Offline
sruffner  Offline
Charlottesville, VA
Well, ok, not in use for balloons...making water - that's some serious exo-thermal action going on. For real oxidation.
He2 has been seen in some labs on earth that I've been in, but, yeah, not in ambient conditions.
Actually, the website on fiberglass delamination/blistering has a good explanation of this notion too. We'd still consider our hulls "waterproof".
Re: mast floats [Re: bvining] #81653
08/04/06 05:57 PM
08/04/06 05:57 PM
srm Offline
srm  Offline
Beating a dead horse no doubt, but I do NOT believe neoprene absorbs water. It's rubber. The reason your suit is full of water is because the cloth bonded to the neoprene holds water. My newest wetsuit, a prolimit windsurfing suit, is entirely smooth skin on the outside. Very nice as far as evaporative cooling is concerned because there is no cloth holding water (it is however very susceptible to abrasion).
Many Drysuits have been made of neoprene (like back in the 80's and 90's). They look just like wetsuits, but with waterproof zippers. There are two reasons your suit gets wet inside- because you sweat and because the suit leaks. If your suit has waterproof glued and taped seams and a waterproof zipper, it will let very little water in.
Getting water in the suit is actually a bad thing. The reason a wetsuit has to fit tightly is so that a minimum amount of water gets in. The more water in the suit, the more water your body ends up heating- the less body heat retained.
sm
Re: mast floats [Re: srm] #81654
08/04/06 08:48 PM
08/04/06 08:48 PM
Atlanta
bvining Offline
bvining  Offline
Atlanta
try this experiment.
Weigh your neoprene wetsuit. Go sit in the water for a hour. Get out of the water. Shake the water off the suit. Weight it again.
report your finding here.
Re: mast floats [Re: bvining] #81655
08/04/06 10:13 PM
08/04/06 10:13 PM
Doesn't Hobie use a glued on neoprene anti-slip panel along the tramp frame? Does that feel spongy or water-filled?
Remember those thin neoprene bikinis back in the 80's? They were pure rubber, very thin with no fabric backing. They never seemed to get soggy. In fact, they seemed pretty hot at the time! I doubt if what looked good then looks as good now. See attached.
Re: mast floats [Re: David Parker] #81656
08/05/06 04:04 PM
08/05/06 04:04 PM
Kingston SE South Australia
JeffS Offline
JeffS  Offline
Your my kind of scientist David.
Jeff Southall
Current boats
Nacra 5.8 1667 Ram Raider
Nacra 18 Square
Arrow 1576
Re: mast floats [Re: David Parker] #81657
08/07/06 10:45 AM
08/07/06 10:45 AM
Clayton Offline
Clayton  Offline
I sure didn't need that image today! <img src="http://www.catsailor.com/forums/images/graemlins/crazy.gif" alt="" />
0 registered members (), 728 guests, and 115 spiders.
Posts267,058
