Re: spin takedown steps [Re: PTP] #83132
08/22/06 03:41 PM
08/22/06 03:41 PM
Victoria, Australia
C2 Mike Offline
C2 Mike  Offline
Victoria, Australia
it isn't always the crews fault <img src="http://www.catsailor.com/forums/images/graemlins/smile.gif" alt="" />
I want my crew to be as involved in tactics/planning as I am. It is so much more fun when it is a collaborative effort
Yeah it is. The beauty of collaborative efforts is that when a wrong call is made, the crew should have pushed harder for the correct course of action. Of course when the right call is made, the crew should always congratulate the skipper on a great piece of strategy etc <img src="http://www.catsailor.com/forums/images/graemlins/grin.gif" alt="" />
Tiger Mike
Re: spin takedown steps [Re: C2 Mike] #83133
08/26/06 11:45 PM
08/26/06 11:45 PM
Tornado_ALIVE Offline
Spinlock cleat for tack line on the inside of the front beam.
Trip line tied to top of Spinlock cleat.
Re: spin takedown steps [Re: Tornado_ALIVE] #83134
08/26/06 11:52 PM
08/26/06 11:52 PM
Tack line comes from under tramp and through a small swivel pully to allow you to pull the tack from any angle. The Spinnlock cleat has a wedge block (supplied) under it so as you pull the tack, the Spinnlock automaticly cleats. The Tack then sucks into the front beam through a single exit block and pulled tought with bungie with about 3 wraps up and down inside the beam. The bungie is sewn inside the tack line to allow for the bungie to pass through the block too.
The use of the exit block reduces the friction from the system a lot.
Re: spin takedown steps [Re: Tornado_ALIVE] #83135
08/26/06 11:54 PM
08/26/06 11:54 PM
Trip line for the Spinnlock travels around the dolphin striker and splits of into 3 lines that run to various points around the tramp.
Re: spin takedown steps [Re: Tornado_ALIVE] #83136
08/26/06 11:56 PM
08/26/06 11:56 PM
First trip line comes out beside the retrieval line for crew's access.
Re: spin takedown steps [Re: Tornado_ALIVE] #83137
08/27/06 12:03 AM
08/27/06 12:03 AM
2nd and 3rd trip lines travel to the rear corners of the tramp for skipper's access both on and off the wire.
It comes up through eyelets in the tramp and ties of on the beam end cap. I have drilled a small hole in the end caps and tied a stopper not behind. I have also added a tie ball to make it a little easier to grap line but now think it is not neccasary.
Re: spin takedown steps [Re: Tornado_ALIVE] #83138
08/27/06 01:44 PM
08/27/06 01:44 PM
Thanks mate, very nice. What happens on harbour courses with stbd roundings? Do you send Brent down to get a face full of spray?
When you've got a minute to spare, would you mind knitting me a new jumper? It looks like you've had practice.
Re: spin takedown steps [Re: Tornado_ALIVE] #83139
08/27/06 03:08 PM
08/27/06 03:08 PM
Love it - thanks a bunch, Steve. This is much cleaner than a couple of other attempts I've looked at. Assuming that I prove to myself in the next two races that I really need this, it will be my pre-Tradewinds project over Christmastime. Talking with the other NA Cap owners, the seperate tack line takes three pulls off the eleven needed to hoist using the stock, single-line system. Along with being able to pull the tack out (and release it) from the wire, it sounds like a serious time-saver and can really put a couple of boat-lengths on the competition at a crowded A-pin.
Thanks again for taking the time to post some pics. <img src="http://www.catsailor.com/forums/images/graemlins/grin.gif" alt="" />
Re: spin takedown steps [Re: Tornado_ALIVE] #83140
08/27/06 07:31 PM
08/27/06 07:31 PM
catman Offline
catman  Offline
Thanks for the PIC's Mike.
Re: spin takedown steps [Re: ] #83141
08/28/06 02:34 AM
08/28/06 02:34 AM
0 registered members (), 296 guests, and 8 spiders.
Posts267,059
