I bought a '91 P19MX last week, and I'm in the process of cleaning it up and trying to set it up according to all the great info from previous posts (mast rake, prebend, etc.) but I've run into a problem setting the rudder rake. All the directions I've found recommend running a straight edge along the transom and down the rudder blade, and measuring how far the blade extends in front of the straight edge. My transoms are slightly concave, and therefore the placement of the straightedge along the curve changes its position relative to the blade. Do you place the straightedge at the top and bottom points of the transom to do this measurement? And because the leading edge of the blades is also curved, where do you do this measuring? At the point where it sticks furthest forward of the straightedge, or at some other point further down? (I have the round-tipped,"long" rudders.) I hope I've explained this clearly. The Prindle manual shows this measurement being done on a P18, with straight transoms, and was of little use.
