Toe straps #90961
12/01/06 04:36 AM
12/01/06 04:36 AM
Oxford, UK
pdwarren Offline OP
pdwarren  Offline OP
Oxford, UK
I've just bought a couple of windsurf toe straps to put on the back of my Blade. I'm planning to mount them on the rounded top edge of the boat (the gunwale?) so that they at about a 45 deg angle.
What sort of re-inforcement have people used when doing this?
Re: Toe straps [Re: pdwarren] #90962
12/01/06 09:12 AM
12/01/06 09:12 AM
I used big one inch to one and half inch stainless washers. I did not use the hardware that was included with the straps though.
Re: Toe straps [Re: pdwarren] #90963
12/01/06 09:35 AM
12/01/06 09:35 AM
Mark P Offline
Mark P  Offline
I can see where Robi is coming from but I would be more inclined to pop down to your nearest DIY store and look for for thickest walled pipe which matches the internal radius of your decks. Cut this to desired length and chop in half along the length, then use smaller washers (12mm). This may help to spread the loads implied when you and your boat are about to go A.o.T (head over heels)
MP*MULTIHULLS
Re: Toe straps [Re: Mark P] #90964
12/01/06 09:59 AM
12/01/06 09:59 AM
Knokke-Heist - Belgium
Gilo Offline
Gilo  Offline
Hi Mark,
I'm planning on putting some on my Blade to next season. Since I'm not native English speaking, your explanation is somewhat difficult to me. Could you explain it in another way ?
Thanks,
Gill
Re: Toe straps [Re: Robi] #90965
12/01/06 10:58 AM
12/01/06 10:58 AM
I did what Robi did- I went and bought the largest washers possible and you can bend them into the form of your hull. I think the PVC would crack, but I see your point.
Re: Toe straps [Re: PTP] #90966
12/01/06 11:17 AM
12/01/06 11:17 AM
Oxford, UK
pdwarren Offline OP
pdwarren  Offline OP
Oxford, UK
The plastic piping is an interesting idea.
How did you go about bending the washers? The big washers that I've got are pretty hard to bend.
Re: Toe straps [Re: PTP] #90967
12/01/06 11:53 AM
12/01/06 11:53 AM
Mark P Offline
Mark P  Offline
Yes, some plastics would crack but a more alcathene based plastic used in gas and water pipes are very durable, the walls are also quite thick in order to prevent punctures!! Bending washers is also OK, use a big washer next to hull to start off with then a couple of small washers so the nut can really tighten up without snagging on the curvature of the first washer.
MP*MULTIHULLS
Re: Toe straps [Re: pdwarren] #90968
12/01/06 12:19 PM
12/01/06 12:19 PM
vice (vise??) grips, two of them or one and a pipe wrench, crescent wrench... that would work.
Re: Toe straps [Re: pdwarren] #90969
12/01/06 12:46 PM
12/01/06 12:46 PM
Mark P Offline
Mark P  Offline
Hi Paul, I was in a B&Q Warehouse this week and they were selling Aluminium strips 1000mm long 50mm wide and 1mm thick it was approx £6.00. You could cut four lengths at approx 75-100mm long and bend this to the desired curve. Due to the increased length bending could be made easier and again you're increasing surface load area.
MP*MULTIHULLS
Re: Toe straps [Re: Mark P] #90970
12/01/06 01:30 PM
12/01/06 01:30 PM
Oxford, UK
pdwarren Offline OP
pdwarren  Offline OP
Oxford, UK
Thanks for the tip. I'll try to pick some up tomorrow.
Re: Toe straps [Re: pdwarren] #90971
12/01/06 04:30 PM
12/01/06 04:30 PM
Victoria, Oztralia
mattaipan Offline
mattaipan  Offline
Victoria, Oztralia
Hi All
We have over here, poly risers that come in various lengths from probably 100mm to 750mm, and several diameters 12mm to 50mm. They are black, like the poly pipe used by farmers and the like, but these are less flexible - quite rigid. When you have a poly pipe in the ground, these rigid risers can be attached for taps/sprinklers etc..
Anyway thats just an idea, we've used here for all sorts of things, not just plumbing.
Regards
Re: Toe straps [Re: mattaipan] #90972
12/04/06 01:43 AM
12/04/06 01:43 AM
ncik Offline
ncik  Offline
Where I come from, toe straps are another name for hiking straps. What you are refering to are called Frooties or Fruit Loops; named after the multicoloured sugary breakfast cereal with Toucan Sam on the box...skiffs tend to just use a bit of pre-stretch rope or 1/2" webbing threaded through a plastic tube. The ends are either tied off through the gunwale, or in our case they can be bolted onto the beam at one end and through the deck at the other. Using the beam at one end keeps the frooty from falling over which makes it easy to get the foot into it. I think there are photos in the forum already...somewhere.
Re: Toe straps [Re: ncik] #90973
12/04/06 11:01 AM
12/04/06 11:01 AM
I use the DaKine foot straps that or about $35 a set. The first ones lasted 6 years of use and outside storage. I think the outside storage is what killed them. I love them in heavy weather on my 17. Just use them for back foot for stability and in case of bow stuffing,
Doug Snell
Hobie 17
"Stress Free"
#007
0 registered members (), 335 guests, and 18 spiders.
Posts267,059
