| Re: A-class help
[Re: andrewLB]
#96600 01/20/07 07:46 AM 01/20/07 07:46 AM |
Posts: 9,582 North-West Europe | the appeal of the f16 is "the thrill of the 700 but with stabilisers on" which probably shows my total ignorance and misguided beliefs about cat sailing . would this be even vaguely acurate?
I've done a bit of 49-er sailing myself (after I had about 7 years of catsailing on my resume) and it is my opinion that the two experiences are considerable different. Not so much better or worse but different. The exciting of a skiff (for me at least) is the high octane adrenaline rush when you are succesful keeping the boat upright and executing the manouvres with ballet like control. I found this to be a high pitched rush, but also extremely tiring. Over halve the time your mind is with control and staying on your toes, the racing comes second. Catamarans, even when fitted with spinnakers, do not provide this high pitched thrill unless it is blowing nuclear. Not that there isn't a thrill to cats, there certainly is, but it is a different kind of thrill. The cats produce a much more lower pitch excitement that humms away over long periods of time. The excitement of cats is the speed and going faster and faster while being in full control. Racing cats is more like fox hunting. You can zero in on your opponent and battle him for as long as 1, 2, 3 hours or even more and still be going strong. The excitement comes from knowing the other won't tip it in or crash and that you'll have to run him down by superior trimming and smart moves. I found sailing the cats to be far more a game of planning and strategic moves then tactics like tacking on a shift. Even with a simple manouvre like tacking on a shift you have to think it over. Is the gain large enough to correct out over the initial loss, which on cats is quite big. Tacking on most shifts is a sure way to loose a race on cats as it kills your speed too much. And all this does happen at noticeably higher speeds. So the excitement builds up during the race but is less high strung, it is more of a game of who blinks first. I personally find this dueling much more enjoyable. Also because on our club race day we can do this for about 2 to 3 hours. When I sailed 49-ers I would be so tired after 30 minutes of hard sailing that my concentration would drop off leading to more and more capsizes and mishaps. I also found a Hobie 16 to simply pass us on the upwind legs EVEN if we were planing upwind. The boat demanding so much attention that I have hardly any memories of the scenery or the conditions during sailing. In cat sailing I do have several of those where the sun breaks through after a rainy start, where I've been duelling another boat for 3 hours during a long distance race. With the crews chatting when side by side beam reaching at 15-18 knots. Arguing whether the losing boat should buy the other a crate of beer or a box of wine while keeping the pedal to the metal all the time. A catamaran is more than a skiff with stabilizers on. The are faster, especially upwind. The way they are sailed is different. The setup of racing is different and the type of exitement they produce is different in my experience. I tried to do a short distance race on a skiff once, never doing that again. Cats also allow you to take some inexperienced friend along and have them experience fast sailing. Last season my crew brought a friend with her and after 10 to 15 minutes of getting used to the boat she was trapezing off the boat handling the spinnaker sheet. Granted the water was relatively flat with a nice and stable force 3 to 4 wind but then again even in those conditions I would never have done that on a skiff like dinghy, with or without a spinnaker. When a neighbouring club invited our club to their races then we sail our boats over. Takes about 60 minutes to do so but it won't have much effect on how well our racing goes later in the day. Wouter
| | | Re: A-class help
[Re: JeffS]
#96601 01/20/07 05:58 PM 01/20/07 05:58 PM |
Joined: Sep 2006 Posts: 613 New Hampshire, USA windswept
Posts: 613 New Hampshire, USA | For Heavier Sailors in Order
DK-17 The Tool Geltek Flyer 2 Bim XJ or MM's A3
The tool though is a production boat made for heavier sailors. The DK17 is more of a one off design that evidently can be built for you. The A3 seems to be less likely for heavier sailors. I took a close look at the DK17 during the NA's in Bristol and was very impressed with the quality and workmanship.
Tom Siders A-Cat USA-79 Tornado US775
| | | Re: A-class help
[Re: windswept]
#96602 01/20/07 06:07 PM 01/20/07 06:07 PM | Anonymous
| Anonymous
Unregistered | Who makes The Tool and DK-17 | | | Re: A-class help
[Re: bvining]
#96603 01/20/07 06:58 PM 01/20/07 06:58 PM |
Posts: 613 New Hampshire, USA | Andrew, I am about your weight and sail a DK17, I built it last winter with Steve Clark's help. The Hulls were designed for a larger person, with more volume high in the stern. Both Steve and Dirk as couple other DK owners are all heavier than you. Dirk Kramer (DK) designed the hulls, (17 for the 17th version of the design). Dirk is an Alighi designer. Steve's experience was that more volume in the stern would keep the boat from squatting downwind. His experience on the Flyer was that he couldnt sit far enough forward in moderate air downwind while going wild. Both Steve and Dirk went from the Flyer to the DK17. If you are interested, PM me and I'll put you in contact with Steve, he might be willing to make you a set of Hulls and ship them over in a Vanguard container bound for Europe. We've got a good low cost source for carbon beams too ( www.forterts.com), so you'd only need to buy a Mast, rudders, daggers locally and fit them to the boat. We've got a good source for tramps too, Kinder Industries in RI. That could easily go in the container with the hulls and beams. That is about the DK17 This below is about the tool http://www.a-cat.org/id102.htmAfter the maiden trip of the first prototype in January this year the TOOL, an Australian design by Wayne Mercer, is now in full production. The new hull shape has proven to be very good in all conditions, upwind as well as downwind. Due to the new hull shape, which has more buoyancy placed through the length of the hull it is a balanced catamaran in flat water as well as in conditions with wind and waves. The wider hull shape at the rear beam provides a stiff platform to connect the rear beam to which makes it the stiffest A-cat available to date. The bow section has been designed to handle waves in rough conditions and the rear transoms have enough buoyancy to prevent the rear beam hitting the water. This makes the platform also better for those heavier sailors who have been restricted in choice by the designs available to date. All this gives the new TOOL a very nice character to sail in all conditions and makes it an all round racing machine. Of course the latest designs of foils is used giving the lowest resistance especially at higher speeds. The Australian built hulls are the insurance for a high quality standard and durability as down under they are forced to build strong hulls for the environment they normally sail in. The results so far in regattas already indicate that the TOOL will evolve into the cat to beat. The TOOL will be assembled for the European market by Piet Saarberg, to keep the cost of transport down. The expected price will be from EUR 13900 exclusive VAT, ready to sail. There are already a few boats available and a normal time between order and delivery can be expected due to the capacity of Boyer Fibrecraft. Enquiries to: T.B. PESA Piet Saarberg Celsiusstraat 210 2041TR Zandvoort Netherlands Tel: + 31 235718695 Fax: + 31 235730102 E-mail: psaarberg@planet.nlMobile : +31 653408075
| | | Re: A-class help
[Re: windswept]
#96604 01/21/07 07:08 AM 01/21/07 07:08 AM |
Posts: 9,582 North-West Europe | The TOOL will be assembled for the European market by Piet Saarberg, to keep the cost of transport down. The expected price will be from EUR 13900 exclusive VAT, ready to sail.
VAT is 19 % overhere (and that applies to any customer from the European Union) 16.541 Euro's in total excluding the shipping to your home. If you're picking it up yourself then that will add about 500 Euro's to the price. I heard a few comments on this price from a very reliable source. So if you want to have one build at this price then first ask what the general layout is and what is made out of carbon and what is made out of aluminium/other materials. Plus what sailmaker did the sail etc. I'm really not against aluminium, as is well known, but when comparing to other A's and other boats it is of course wise to know how the boats relate to eachother and to include VAT in the prices. Wouter
| | | Re: A-class help
[Re: Wouter]
#96605 01/21/07 11:08 AM 01/21/07 11:08 AM |
Posts: 221 Netherlands | If you want to know about the Tool than the best is to ask Piet about it and not assume a lot of things. I can tell you that the most parts are carbon and than we are talking about 95% or maybe more. The platform is extremly stiff and reliable. I can tell you this because Piet is my father and i am close to the development of The Tool as you can be for the European market. I think also that the Tool will be the A-class to beat the coming time, if seen the downwind performance of that boat with 18 to 20 knots and it is really flying and no other type could do this, his was during the A-cat Nationals in Holland. With less wind the boat was also quicker (down and up wind) On the website of Catamaranparts ( www.catamaranparts.nl)there will be soon more info about the boat. The price for the boat is also not to bad if you see the carbon prices the last time . Regards, Hans | | | Re: A-class help
[Re: Hans_Ned_111]
#96606 01/21/07 11:50 AM 01/21/07 11:50 AM | Anonymous
| Anonymous
Unregistered | Links on website don't work. Will it be shiipped to US? | | |
356
guests, and 110
Mod | | Forums26 Topics22,405 Posts267,059 Members8,150 | Most Online2,167 Dec 19th, 2022 | | |
