Page 2 of 3 1 2 3
Re: Inter 17 advice [Re: brobru] #968
07/30/01 05:34 AM
07/30/01 05:34 AM
Bruce,
<br>
<br>Just wondering if your traveller was still centred when you eased the outhaul.
<br>My findings are that these two have to be set relative to one another allowing the appropriate sheet tension. When the match is right it all works.
<br> If the traveller is too close to centre you may not be able to apply enough sheet tension to get the top of the sail working properly.
<br>Also if you release the outhaul too much relative to the traveller the helm will increase. It depends on the setup of the rudders if the magnitude of this is felt. But it can slow the boat.
<br>When this is wrong on my Taipan I can feel it and when it's right I can also feel it. (It feels like you need to dig your toe nails into the boat to stay with it)
<br>
<br>What was happenning at the top of the sail?
<br>Maybe ease the traveller a little and sheet on harder.
<br>It's hard to know for sure without seeing it
<br>
<br>Maybe you could experiment a little more with both outhaul (more/less) ,traveller and mainsheet tension?
<br>
<br>I'd be interested to hear how the experiments go.<br><br>
1164- (20 downloads)
Re: Inter 17 advice [Re: phill] #969
07/30/01 12:54 PM
07/30/01 12:54 PM
brobru Offline OP
brobru  Offline OP
Phill,
<br>1. I was out Saturday in the front end of a tropical wave,...so the wind was 20+ gusts.
<br>2. I have to travel down starting about 12-14........that day I was 10-12 inches off of center,......I mainsheeted tight,....notice the top flutter a little, so I sheeted harder to get rid of it
<br>3. By this time downhaul is 100%,...
<br>4. I was training with a I-20,..I made them promise to leave the spinn ashore!
<br>5. THEN I RELEASE 3 inches on the OUTHAUL,....boat settled like it never did before,....it would lift up in a gust and stay right there! (...before this adjustment I would be 5 feet off the water and rounding up to keep it together!)
<br>This was exactly what I was looking for,...now I need to regain the 20% lost speed,...suggestions?
<br>Bruce
<br>St. Croix
<br>ps. Tom on his I-20 was 'wild thinging' like a pro....said it was good to sail downwind without the chute, for practice.....he would totally wipe me out ...ha!<br><br>
Re: Inter 17 advice [Re: brobru] #970
07/31/01 07:46 AM
07/31/01 07:46 AM
Bruce,
<br>
<br>Three things to consider. In order that I would try.
<br>
<br>First Downhaul- let it off and reapply it until the boat is just under control. It is important to have it on but if you have applied more than needed it can kill the boat
<br>It bends the mast too much and the top of the sail lays off too much and stops working (you said it was fluttering). To make it work you increased sheet tension which may also make the leach in the bottom of the sail a little too tight.
<br>This boat will feel very easy to handle but a bit like you left the hand brake on.
<br>
<br>Second look at rotation.
<br>If I carry too much on my Taipan it can affect the boats inclination to drive forward and hence slow you down.
<br>
<br>The last thing I'd consider is back to the outhaul. Possibly 3 inches is too much.
<br>
<br>I hope this helps.
<br>Phill <br><br>
1229- (17 downloads)
Re: Inter 17 advice [Re: phill] #971
07/31/01 08:04 PM
07/31/01 08:04 PM
brobru Offline OP
brobru  Offline OP
Phill,
<br>1. Will do as you instructed.
<br>2. Will start with downhaul off,...then adjust as needed.
<br>3. I had rotator pointing at the centerboards,....that will be about 45-50 degree rotation. You thinking too much? What do you suggest?
<br>4. There is a range of 6 inches ( I believe,...now I will check this) in the outhaul adjustment. You suggest 1-2 inches?
<br>Thanks ,...this is a great way to share info,....I appreciate the help and interest!
<br>regards,
<br>Bruce
<br>ps, will be out tomorrow to try this info out<br><br>
Re: Inter 17 advice [Re: brobru] #972
08/02/01 06:05 PM
08/02/01 06:05 PM
Bruce,
<br>On my boat 45deg in those conditions would be too much.
<br>The spanner would be pointing at the rear beam probably where it meets the hull. This will vary from boat to boat and even with different main sails. It really is a case of experimenting with your particular setup, but I think you will do better with less rotation.
<br>I have a tell tale an inch or so back from the luff of my sail about half way up. I use this to set my rotation in light to med conditions. Looking for laminar flow on both sides. But once the breese really kicks in I go by feel as they stream over a much wider range of angles.
<br>As far as ouhaul goes it also depends on the cut of your sail
<br>so once again all I can suggest is experiment, preferabley with a training partner to guage progress.
<br>
<br>Good Luck,
<br>Phill<br><br>
Re: Inter 17 advice [Re: phill] #973
08/02/01 07:51 PM
08/02/01 07:51 PM
brobru Offline OP
brobru  Offline OP
Phill,
<br>1. Thanks for the continued help. Thee are no other Uni's in St. Croix,..so I train with a I-20 and a Fox.
<br>2. I changed the mast diamond spreader configuration. It was sweptback at a bout 3+ inches at center. Set it at 1 inch.
<br>3. The range of outhaul on the I17 is 4 inches. I measured. So I adjust it to 1 inch now from 'full tight'.
<br>4. I put less rake in,..adjusted it forward" one hole" on the side stays.
<br>5. Wind was out of the SE today,..so sailed in the lee of the island,...what a joy, no waves to speak of...wind was 10 mph max,...what another joy,.....boat tacked effortlessly.
<br>Keep the info coming Phill,...I am thankful for it!
<br>
<br>regards,
<br>Bruce
<br>St. Croix<br><br>
You have a wing mast Phill aren't rotated less ? [Re: phill] #974
08/02/01 08:43 PM
08/02/01 08:43 PM
You have a wing mast Phill and aren't they rotated less rthan normal crossection masts ?
<br>
<br>Wouter<br><br>
1310- (18 downloads)
Re: You have a wing mast Phill aren't rotated less ? [Re: Wouter] #975
08/03/01 07:47 PM
08/03/01 07:47 PM
<br>In answer to your questions.
<br>Yes I do have a wing mast on my Taipan and it does carry less rotation but this is more evident in lighter conditions.
<br>
<br>As the wind strength increases the difference between rotation angles decreases.
<br>
<br>From memory I would not be carrying any more rotation in the 15 to 20 range on my Cobra which had a conventional shaped mast, than on my Taipan.
<br>
<br>From your post I gather the I17 does not have a wing mast.
<br>This surprises me.
<br>
<br>If the I17 has a conventional mast ,because of turbulence from the mast, it is more difficult to use luff tell tales to set rotation.
<br>
<br><br><br>
1336- (18 downloads)
I-17 with no wing mast is my believe, I may wrong [Re: phill] #976
08/03/01 08:11 PM
08/03/01 08:11 PM
Wouter<br><br>
Re: I-17 with no wing mast is my believe, I may wrong [Re: Wouter] #977
08/04/01 10:02 AM
08/04/01 10:02 AM
brobru Offline OP
brobru  Offline OP
Wouter, Phill, others,
<br>1. To my eye, the Inter masts ( carbon or aluminum) LOOK similar to the Prindle and Nacra stock mast (...I walked around looking at them,...probaly looked strange..oh well..)
<br>2. I talked the I 20 (Tom) into leaving his jib onshore and sail it alone,...he was a little uncertian at first,....but,..he is turned on to the fact that he can one man a I 20 w main alone and have fun too,...plus I got someone to train with.
<br>3. Will sail tomorrow,...make report,....set up downhaul extension to trap line with thicker 'handle',...
<br>Thanks to all,...and go sailing!
<br>Bruce
single handing in chop and high wind [Re: brobru] #978
08/04/01 03:13 PM
08/04/01 03:13 PM
All of the discussion so far has been good but controling the wind is only half the battle. As a single handed sailor it is often difficult to control the rock of the boat in waves. Especialy when the boat has a shorter waterline length. My recomendation when encountering any waves going upwind (Boat waves, chop, swells) is to move your body weight aft. By doing so on a small light boat it raises the bows a good 3-6 inches, reduces the rock of the boat, and allows the daggerboards/rudders on the windward hull to stay in the water. Many of you will say this will drag the transoms but in waves with the boat punching and bouncing through the water it allows the boat attack the waves at an angle which is what you want.
<br> One thing I wouldn't do is rake your mast back. I have seen H-17s do this but with lighter I-17s and T4.9 I would think it would give you so much weather helm you would be fighting the boat in a hard puff to keep it from going into irons. I will probably regret giving you all this information on the race course.
<br>
<br>Keep sailing
<br>J.P. the Terrible
<br>Isotope #186 the Shark Boat <br><br>
1343- (24 downloads)
Re: How about upwind on a I-20 [Re: Mark Meis] #979
08/05/01 04:04 AM
08/05/01 04:04 AM
Mark,
<br>
<br>I dont remember how the jib sheeting is arranged on the I20, other than it sheets to the front beam.
<br>
<br>When my old N6.0 started to feel the way you describe, i knew it was time to move the jib trims outboard/aft, to allow the top of the jib to twist off and depower at the top.
<br>
<br>Give it try...
<br>
<br>Mike Parsons
<br>F24 mkII #121 Littlewing
<br>A-cat USA 151<br><br>
1345- (22 downloads)
Re: single handing in chop and high wind #980
08/05/01 02:11 PM
08/05/01 02:11 PM
J.P.
<br>
<br>Unortunately I've never had the priveledge of sailing an Isotope, but from what you say it may behave a little differently than my Taipan.
<br>
<br>I agree there are certain conditions where trapesing further back is a definite plus.
<br>
<br>I spent a season trapesing back in the heavy stuff to finally conclude it didn't pay off every time.
<br>
<br> Now I consider the situation carefully as trapesing back on the boat does affect the boats pointing.
<br>Not a lot but just enough to make a difference when you need it.
<br>This is particularly bad in conditions where the increased windage from lifting the bows helps you to be blown to leeward from the tops of the waves. If I can manage it, in these conditions bow down works better.
<br>
<br>But like everything else in sailing it's just getting the right balance because everything is a compromise.
<br>
<br>So I trapese as far forwad as I can without taking the waves hard on the front beam as this slows the boat. If this is happenning I move back, suffer the loss of pointing, and rewarded with higher speed and a good ride.
<br>
<br>The thing that really gets me is big waves or chop and light to moderate wind.I always find this a real pain. <br><br>
1354- (20 downloads)
Brobru, more accurate thrust/heeling graphs at... [Re: brobru] #981
08/06/01 05:31 AM
08/06/01 05:31 AM
Go to :
<br>
<br>http://www.geocities.com/kustzeilen/heeling_pitchpole.html
<br>
<br>and see how at example 0,4 speed of wind boat velocity the heeling reduces by 11 % when steering up and the trust by 33 % !!
<br>
<br>
<br>Wouter
<br>
<br>Wouter<br><br>
1366- (23 downloads)
Re: single handing in chop and high wind [Re: phill] #982
08/06/01 08:07 AM
08/06/01 08:07 AM
brobru Offline OP
brobru  Offline OP
JP, Phill and all,
<br>1. I was out yesterday,..a changed the mast rake,..foward one hole on the aft,...funny thing,..it took 2 hole forward on the bow plates to 'tension' it correctly (...the split forwards are not a 1:1 relationship to the aft plates??)
<br>RESULT,....weather helm (...it was 100% neutral before)....do not know if I like or not.....the neutral helm is comfortable,....but I always wondered how close I 'really' was to optimal pointing,..as you can agree, .1 to 2 degree angle on a 30 minute upwind leg is going to add up.
<br>2. The comment I have on the 'big wave' jumping,.....I hit a few yesterday,...there is an area off the North shore where the seas pile up( steep, not a ocean swell),.....upwind , in a big sea(starting at 4+feet crest to trough),..the boat flies off the crest( winds 20ish E),.....no problem,....it is the wind that now 'sees' the bottom of the tramp as a sail too,...this is the problem for me,...I need to keep up the speed to get thru this zone of 'exposed tramp-sail area",.....so bow-down and speed-up,...is essential for me at this point. I usually am around the centerboard for weight placement.
<br>regards,
<br>Bruce
<br>St. Croix
<br>ps. going sailing after work today,...gonna look at this weather helm thing more...??<br><br>
Re: single handing in chop and high wind [Re: brobru] #983
08/06/01 09:40 AM
08/06/01 09:40 AM
Bruce,
<br>
<br>I know what you mean about wind under the tramp.
<br>I was sailing in about 20 knots or so (on a 16ft Cobra) in a big swell with a Hobie 16 just to leeward (you could almost step from one boat to the other). We were beating into the wind and swell. We went over this big one and the wind got under the Hobies tramp and, the Hobie became airborne, thefirst thing to touch the water was the tip of the Hobies mast. This really got my attention as we were so close.
<br>This was nearly 20 years ago and in that one instant I realised the value of bow down in those conditions.
<br>
<br>If I understand your post correctly you are saying you raked your mast forward and got weather helm?
<br>
<br>This is most peculiar.
<br>Raking my mast forward speeds up my tacking but as it moves the C/E in the sails forward it can reduce helm and possibly reduce pointing angle,
<br>
<br>It may pay to recheck your other settings to make sure nothing else changed that could account for the increased helm. I always check to make sure only one thing is changed at a time and evaluated before a second change.
<br>
<br>
<br>Anyway I envy you. It sounds like your having a good time.
<br>I have another month before our sailing season gets underway.
<br>
<br>Phill<br><br>
1373- (28 downloads)
Rake a little less. [Re: brobru] #984
08/06/01 10:13 AM
08/06/01 10:13 AM
Personally I don't believe in sailing with much weather helm on the I-17. The daggerboards are the same as those of the I-18 and therefor are bigger than needed for the loads of the single hander. I would de-rake the mast. Move up one whole aft and tension the rig with the turnbuckle in the forestay. Best trick is to place one aft stay one hole up and the other 2 holes up. Now tigthen the forestay (not to much) rig your mainsheet system to a trapwire move traveller out and pull hard on mainsheet. The aft stay that was moved up two hole will be easy to put in the right hole. Rig is now nice and firm.
<br>
<br>Why not much rake on I-17. Baords are already big (bigger than Nacra unis etc) and neatral helm is nice. You might want a lttle weather helm (not as much as you have now) so that the rudder are not just extra wetted surface drag but contribute a little to pointing too, this is more efficient. So I would say something between what you have now and perfect neutral helm.
<br>
<br>Wouter<br><br>
1376- (21 downloads)
Re: single handing in chop and high wind [Re: phill] #985
08/06/01 08:44 PM
08/06/01 08:44 PM
brobru Offline OP
brobru  Offline OP
Phill,
<br>What part of the world do you sail in?
<br>Bruce
Re: Rake a little less. [Re: Wouter] #986
08/06/01 08:53 PM
08/06/01 08:53 PM
brobru Offline OP
brobru  Offline OP
WOuter,
<br>1. OK,..will do.
<br>2. Actually, the boards and rudders are the same on ALL the INTER line,....17, 18 and 20. (...at least here in the USA)
<br>3. Exactly where are you from Wouter?
<br>regards,
<br>Bruce
Click on my name and you'll see my personal info [Re: brobru] #987
08/07/01 03:35 AM
08/07/01 03:35 AM
Click on my name and you'll see my personal info. You can do the same with Phill's name and see where he sails.
<br>
<br>Anyways, I'm from the Netherlands.
<br>
<br>OKay I've read my own post again and thought that I should explain the "not so much weather helm" better. As you said boards are all the same on the I-XX line. Now you rig will produce considerable less sailforce than the I-18 for which the original boards were designed / optimized.
<br>
<br>Your maximum righting moment Ratio is about 60 % (assuming you are 75 kg's and boat width is 2,6 mtr. and boat weights 150 kg's; I-18 150 kg crew weight, 2.6 mtr wide and 180 kg's boat)
<br>
<br>Your rated sailarea ratio = 12,31 / 14,80 = 83 %
<br>Mastheight ratio = 8,5 / 9 = 94 %
<br>
<br>Heeling moment rig ratio = sailarea ratio * mastheight ratio = 78 %
<br>
<br>So your rig is producing about 78 % of the heeling force as a I-18 would in the same windforce. Your maximum righting moment is only 60 % of that of the I-18. Your thrust ratio and heeling force ratio are then = 60 % / 78 % = 77 % of that of the I-18. This means that your daggerboards are about 1/77 % = 130 % is about 30 % to big for your loades. The daggerboards won't be working at their optimal angle of attack on your boat but at smaller angles. There is often a range of rather optimal angle but 30 % to big might be pushing it a bit. So when you go for alot of weather helm like many asymmetric sailor are eager to advice than the only thing you'll do in relatity is to take load from the already underlaoded daggerboard and load up you rudders. Thus the angle of attack of the daggerboards descreases even more and efficiency drops even more. You could end up (in the extreme case) with annoying weatherhelm and equal or less pointing ability due to a rapid decrease efficiency as a result of small angles of attack. You might want to lift your boards a bit before the other boats do for the same reason.
<br>
<br>Anyways, with perfect neutral helm your daggerboards might be working rather acceptable but your rudders are simply added wetted surface only creating drag when not used for steering.
<br>
<br>What is wise ?
<br>
<br>Well, it can be argumented that alot of weatherhelm is bad. Perfect neutral helm can work quite well but is almost certainly not optimal for your rudder are doing nothing most of the time excepot adding drag. Best bet would be to lift your boards a bit and to induce a little weather helm This way you :
<br>
<br>- Load up the daggerboards more per sq.ft. and go back to the optimal design angle of attack
<br>
<br>- reduce daggerboard wetted surface that you don't really need
<br>
<br>- Open up the possibility to induce weatherhelm without a negative backlash. This weatherhelm will load up your rudders so they will need to contribute to the sideforce resistance. Your rudders will still create drag but at least they now contribute positively. With neutral helm you will never use the rudders even when you lift the boards.
<br>
<br>wel 30 % to big would make raising your boards by 30 % a good starting point.
<br>
<br>Guys (Phill ?) , please correct me when I made an error
<br>
<br>Wouter
<br>
<br>(designing is all about striking the optimal balance between different features)
<br>
<br><br><br>
1402- (19 downloads)
Page 2 of 3 1 2 3
1 registered members (Team_Cat_Fever), 338 guests, and 35 spiders.
