| Re: 12 foot
[Re: Rolf_Nilsen]
#97895 04/23/07 05:58 AM 04/23/07 05:58 AM |
Posts: 1,449 | Rolf, I've been out of the loop for some time with a PC melt down and I'm just going through old posts and found this one. I think you are right on the mark. Sure when it's blowing dogs off chains the wider beam is handy but how often do we sail in those conditions compared to conditions under 15 knots where the difference is likely to be balanced out by the slower tacking of a wider platform. Then look at the amount of time you sail lighter winds where lifting the windward hull becomes an advantage due to the reduction in wetted surface and corresponding reduction in drag. It's worth trialling a 10ft beam on a modern hull shape. The desigbn could have two jib options. A self tacker for bouy racing and larger overlapping jib for distance stuff. Designing a platform to take a standard T rig makes good sense and is in fact a part of my plan with the additional jib option for distance stuff. However I think to build such a boat in commercial numbers it will probably have to have an 8 ft beam. When trying to appeal to larger numbers you can't beat convenience.
Just the way I see it.
Regards, Phill
| | | Re: 12 foot
[Re: Rolf_Nilsen]
#97897 04/23/07 04:24 PM 04/23/07 04:24 PM |
The motherboard died in my lap top. After a very long time they elected to replace the lap top rather than fix/replace the motherboard.
I agree about getting a prototype on the water. Hopefully the 3rd quarter this year or 1st next should see a prototype sailing.
Regards, Phill
| | | Re: any updates on new 20 ft cat designs -classes
[Re: arbo06]
#97899 04/24/07 01:38 PM 04/24/07 01:38 PM |
Posts: 5,590 Naples, FL | Lambert's old M20 or another one?
[Re: arbo06]
#97901 05/01/07 01:57 PM 05/01/07 01:57 PM |
Posts: 5,590 Naples, FL | Hey, what would a wing mast do on the N20?
Besides violate the SMOD regulations....
[Re: Will_R]
#97907 05/15/07 04:09 PM 05/15/07 04:09 PM |
Posts: 1,449 | Will,
Do you know the weight of the M20 AND CFR20?
M20 sloop rig 120kg?
CFR 20?
Regards, Phill
[Re: Rolf_Nilsen]
#97912 05/23/07 01:12 AM 05/23/07 01:12 AM |
Posts: 9,582 North-West Europe | I think people are finding out now how hard it is to start a new sailing class.
1 registered members (Xarisaz),
629
guests, and 80
Mod | | Forums26 Topics22,405 Posts267,058 Members8,150 | Most Online2,167 Dec 19th, 2022 | | |
