| Re: Hobie 18' Missing Hull Floatation Blocks
[Re: Cat_Centric]
#38931 10/11/04 08:46 PM 10/11/04 08:46 PM |
Posts: 12,310 South Carolina | Go to Walmart and buy several of the cheap long 'floating noodle' kids pool toys. Cut them into manageable lengths, insert them into the hull port and VIOLA! Hull floatation made easy...they are made of closed cell foam and perfectly suited for this task.
Jake Kohl | | | Re: Hobie 18' Missing Hull Floatation Blocks
[Re: wyatt]
#38934 10/13/04 06:47 PM 10/13/04 06:47 PM |
Posts: 12,310 South Carolina | But I can atest (please don't ask me how) that a Hobie 18 completely swamped in both hulls and void of air will still stay on the surface of the water....
[Re: mmiller]
#38939 11/10/04 12:23 AM 11/10/04 12:23 AM |
Posts: 1,658 Florida Suncoast, Dunedin Caus... | The blocks are large. Get a stick or something like it and probe through the port toward the aft end. You should find it. If it's not there then someone removed them. How? Certain chemicals will turn foam into liquid and it will pour out the drain holes. Why? To remove weight from the boat.
| | | Re: Why the foam is a really good idea
[Re: hobiesailor]
#38943 11/10/04 01:14 PM 11/10/04 01:14 PM |
Posts: 12,310 South Carolina | You guys might be able to salvage one good boat between ya!
Jake Kohl | | | Re: Why the foam is a really good idea
[Re: arbo06]
#38947 11/10/04 08:53 PM 11/10/04 08:53 PM |
Posts: 1,911 South Florida & the Keys | Oh, and by the way, there was foam flotation all over Biscayne Bay after the "incident" and the boat never sank. I say flotation is critical!
Eric Arbogast ARC 2101 Miami Yacht Club | | | Where do you buy Pour foam? NM
[Re: carlbohannon]
#38948 11/13/04 05:13 AM 11/13/04 05:13 AM |
Posts: 208 | | | | Re: Where do you buy Pour foam? NM
[Re: Skipshot]
#38953 10/12/05 07:07 PM 10/12/05 07:07 PM |
Posts: 1,658 Florida Suncoast, Dunedin Caus... | Skipshot, The problem with those hulls occurred mid 80's. Keep in mind while looking for a boat you don't have to avoid a boat of those years. Many of those boats received upgraded replacement hulls. There might be a way to tell if they've been warrantied by looking at the VIN. # on the back of the hulls. Maybe Matt might be able to tell you how to find that info out. When looking at boats check under the shear by the front beam. If you find cracks in the gel coat that extend more than a couple of inches be careful. If they're 10 inches long run away. I had a 81 that I bought in 85 and there were some cracks 2-3 inches when I got it and after 17 years of heavy use they never got any bigger. Good boats.
[Re: carlbohannon]
#38954 10/13/05 08:22 PM 10/13/05 08:22 PM |
Posts: 805 Gainesville, FL 32607 USA | I saw anchor plates on several of the busted TheMightyHobie18 hulls. Excess load from wings, and lightened boats under design weight....may = trouble. At a Nationals in Florida, Larry Mondragon was putting his brand new TheMightyHobie18 into the water- weight only 408 pounds! (YAYAYAY- a real winner!) HULL BROKE ON THE BEACH; never even made it to the water!
334
guests, and 99
Mod | | Forums26 Topics22,405 Posts267,058 Members8,150 | Most Online2,167 Dec 19th, 2022 | | |
